tranny help please (UPDATED)
#1287620
08/19/12 01:23 AM
08/19/12 01:23 AM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
70 road runner 440,727 torque flight,driving home after a 40 min cruise on a less then 300 mile tranny rebuild,goosed it to pass an older gentleman who decided to stop in the middle of road,at the point i heard a loud whinning sound from tranny,sounded like a fan belt,got home,noticed at speed and not accelerating noise gone,but got terrible again at the stop light.Got home,let it cool,fluid perfect,no burnet smell,and full.Start it up all normall,until i put in drive or reverse with foot on brake,back to park or neutral no whinning sound,any thoughts where to begin? or do i need to pull the tranny after only 300 miles,any direction would be appreciated,thank you,
Re: tranny help please
[Re: moparjo68]
#1287623
08/19/12 10:23 AM
08/19/12 10:23 AM
meepmeep70
weymouth,mass.
thank you,and i did eliminate it,with no change,any other thoughts? wanted to hopefuuly diagnoise,and if it has to be pulled,start pulling,crawling under it now.
[Re: meepmeep70]
#1287624
08/19/12 10:31 AM
08/19/12 10:31 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Make sure it has enough fluid hot and idling in Neutral. look for foam or air in the fluid. check your flex plate bolts may have lossened off?
[Re: Dodgem]
#1287625
08/19/12 10:45 AM
08/19/12 10:45 AM
meepmeep70
weymouth,mass.
thank you,fluid is good,no foam,and full in neutral,i'm so bummed because i wanted to come home and head out to a show,i hoped to solve this problem,before heading to niagra falls canada(your area)so i'm not worried about it on my vacation
[Re: meepmeep70]
#1287632
08/19/12 01:09 PM
08/19/12 01:09 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Rather than pulling the tranny which would mean taking it apart blind take the car to a tranny shop & have them drive the car... As mentioned it could be fliud bypassing the pressure regulator causing a resonating buzz/whine... It could be the front pump or it could be the convertor... A guy that has done trannies for a living should be able to pinpoint the noise & & if it's the pressure regulator the trans stays in the car....
[Re: Greg Ducato]
#1287639
08/20/12 10:39 AM
08/20/12 10:39 AM
Dodgem
Ontario, Canada
Whining when loaded in gear is usually caused by pump restriction, such as clogged filter, or by a bad torque converter.
and bad cheap converters usually fill the pan full of junk!
course could be a malfuntioning valve body to??
