tranny help please (UPDATED) #1287620
08/19/12 01:23 AM
08/19/12 01:23 AM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
70 road runner 440,727 torque flight,driving home after a 40 min cruise on a less then 300 mile tranny rebuild,goosed it to pass an older gentleman who decided to stop in the middle of road,at the point i heard a loud whinning sound from tranny,sounded like a fan belt,got home,noticed at speed and not accelerating noise gone,but got terrible again at the stop light.Got home,let it cool,fluid perfect,no burnet smell,and full.Start it up all normall,until i put in drive or reverse with foot on brake,back to park or neutral no whinning sound,any thoughts where to begin? or do i need to pull the tranny after only 300 miles,any direction would be appreciated,thank you,
Re: tranny help please [Re: meepmeep70] #1287621
08/19/12 02:00 AM
08/19/12 02:00 AM
weymouth,mass.
weymouth,mass.
no thoughts?
Re: tranny help please [Re: meepmeep70] #1287622
08/19/12 03:50 AM
08/19/12 03:50 AM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
Sounds exactly what I went thru with my 727 tranny. I heard a loud whinny noise only during certain RPM's of the engine. Its very hard to track down engine noises but I thought it was coming from the tranny. I would put it in gear, hold my foot on the brake while in drive and I heard the noise. Put it back into park and the noise stopped. Then one day noise seemed to be coming from PCV valve. I replaced the PCV valve and my whinny noises went away. Try eliminating the pcv valve while your testing or if you have another laying on the shelve, just try trading it out. Let me know.
Re: tranny help please [Re: moparjo68] #1287623
08/19/12 10:23 AM
08/19/12 10:23 AM
weymouth,mass.
weymouth,mass.
thank you,and i did eliminate it,with no change,any other thoughts? wanted to hopefuuly diagnoise,and if it has to be pulled,start pulling,crawling under it now.
Re: tranny help please [Re: meepmeep70] #1287624
08/19/12 10:31 AM
08/19/12 10:31 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Make sure it has enough fluid hot and idling in Neutral. look for foam or air in the fluid.
check your flex plate bolts may have lossened off?
Re: tranny help please [Re: Dodgem] #1287625
08/19/12 10:45 AM
08/19/12 10:45 AM
weymouth,mass.
weymouth,mass.
thank you,fluid is good,no foam,and full in neutral,i'm so bummed because i wanted to come home and head out to a show,i hoped to solve this problem,before heading to niagra falls canada(your area)so i'm not worried about it on my vacation
Re: tranny help please [Re: moparjo68] #1287626
08/19/12 10:46 AM
08/19/12 10:46 AM
weymouth,mass.
weymouth,mass.
checking flex plate bolts next i'll report back
Re: tranny help please [Re: meepmeep70] #1287627
08/19/12 11:13 AM
08/19/12 11:13 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
wonder if the flex plate is cracked?? they will wine if the suck air?
strange??
Re: tranny help please [Re: Dodgem] #1287628
08/19/12 11:19 AM
08/19/12 11:19 AM
katakan
lilred Offline
lilred  Offline
katakan
Had something similar on my 1977 power wagon 440/727, it was almost like a whine, it ended up being the front pump and it burned out the trans in time, had a similar noise in my 2002 superduty diesel and it was also the pump, hope you have better luck.
Re: tranny help please [Re: lilred] #1287629
08/19/12 11:47 AM
08/19/12 11:47 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
in the tranny part of my manual says low fluid (sucks air) front pump, malfuntioning valve body or sprag race failour!
Re: tranny help please [Re: lilred] #1287630
08/19/12 11:49 AM
08/19/12 11:49 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
It could be pump whining, but I suspect it is the pressure regulator valve doing it.
Re: tranny help please [Re: fox] #1287631
08/19/12 01:03 PM
08/19/12 01:03 PM
weymouth,mass.
weymouth,mass.
thanks for replys,flex plate bolts are tight,and visual inspection shows no crack,so it seems i have to pull the tranny
Re: tranny help please [Re: meepmeep70] #1287632
08/19/12 01:09 PM
08/19/12 01:09 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Rather than pulling the tranny which would mean taking it apart blind take the car to a tranny shop & have them drive the car... As mentioned it could be fliud bypassing the pressure regulator causing a resonating buzz/whine... It could be the front pump or it could be the convertor... A guy that has done trannies for a living should be able to pinpoint the noise & & if it's the pressure regulator the trans stays in the car....
Re: tranny help please [Re: 1_WILD_RT] #1287633
08/19/12 01:14 PM
08/19/12 01:14 PM
weymouth,mass.
weymouth,mass.
thank you Randy,really hoping that your suggestion is the problem hope all is well with you
Re: tranny help please [Re: meepmeep70] #1287634
08/19/12 01:17 PM
08/19/12 01:17 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Sitting at the airport, be in a plant in Jersey tomorrow AM.. Back home mid week, short car cruise & BBQ next Saturday... Not a bad week..
Re: tranny help please [Re: 1_WILD_RT] #1287635
08/19/12 01:39 PM
08/19/12 01:39 PM
weymouth,mass.
weymouth,mass.
can i test presure regulator? how to find out?
Re: tranny help please [Re: meepmeep70] #1287636
08/19/12 05:23 PM
08/19/12 05:23 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
no thoughts?
I have one...learn how too use the space bar.
Re: tranny help please [Re: John_Kunkel] #1287637
08/19/12 05:28 PM
08/19/12 05:28 PM
weymouth,mass.
weymouth,mass.
no thoughts?
uhmm o k
Re: tranny help please [Re: meepmeep70] #1287638
08/20/12 10:34 AM
08/20/12 10:34 AM
Weatherford Texas
Greg Ducato Offline
Greg Ducato  Offline
Weatherford Texas
Whining when loaded in gear is usually caused by pump restriction, such as clogged filter, or by a bad torque converter.
Re: tranny help please [Re: Greg Ducato] #1287639
08/20/12 10:39 AM
08/20/12 10:39 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
and bad cheap converters usually fill the pan full of junk!
course could be a malfuntioning valve body to??
