Can someone recommend a good electric fuel pump? #1287099
08/17/12 07:00 PM
08/17/12 07:00 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
I'm looking for a good quality electric fuel pump for a carbureated daily driver. One that isn't made in China (okay, maybe I'm asking for too much).
Any recommendations?
Re: Can someone recommend a good electric fuel pump? [Re: dustergirl340] #1287100
08/17/12 07:02 PM
08/17/12 07:02 PM
dogdays Offline
dogdays  Offline
Carter P4070.
R.
Re: Can someone recommend a good electric fuel pump? [Re: dogdays] #1287101
08/17/12 07:36 PM
08/17/12 07:36 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
thanks!
Re: Can someone recommend a good electric fuel pump? [Re: dustergirl340] #1287102
08/17/12 08:44 PM
08/17/12 08:44 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Carter's a good one & so is this Holley Gerator pump.
Had it on my Hemi Challenger & its quiet compared
to most. Here's the Summit link
http://www.summitracing.com/parts/HLY-12-150/
Re: Can someone recommend a good electric fuel pump? [Re: Triggerfish] #1287103
08/17/12 09:52 PM
08/17/12 09:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We have had the red Holley pump on my sons Dart since 1997. Its the one that does not require a seperate regulator. If a little noise dont bother you it works great but some dont like the noise. Ron
Re: Can someone recommend a good electric fuel pump? [Re: dustergirl340] #1287104
08/17/12 09:54 PM
08/17/12 09:54 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Holley Red is what I'd use.
Nautilus Racing-
Re: Can someone recommend a good electric fuel pump? [Re: Chris2581] #1287105
08/18/12 12:25 AM
08/18/12 12:25 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Mallory 4110 pump doesn't need a regulator and would work good.
Re: Can someone recommend a good electric fuel pump? [Re: 383man] #1287106
08/18/12 12:37 AM
08/18/12 12:37 AM
fullmetaljacket Offline
Ron. Hoping that the finances allow you to come up to E-town for the NSS trials. Would like to meet you and put a magnifying glass on that sleeper of yours.
Re: Can someone recommend a good electric fuel pump? [Re: Azzkikrcuda] #1287107
08/18/12 02:37 AM
08/18/12 02:37 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Mallorys are great and they are quiet.
Ride eternal, shiny and chrome
Re: Can someone recommend a good electric fuel pump? [Re: fullmetaljacket] #1287108
08/18/12 05:01 AM
08/18/12 05:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Not looking good for me right now. What is the date ? Thanks , Ron
Re: Can someone recommend a good electric fuel pump? [Re: dustergirl340] #1287109
08/18/12 07:49 AM
08/18/12 07:49 AM
Annapolis Maryland/WV
dmnrr04 Offline
dmnrr04  Offline
I like the Carter as well.......
Re: Can someone recommend a good electric fuel pump? [Re: dustergirl340] #1287110
08/18/12 07:51 AM
08/18/12 07:51 AM
dmnrr04 Offline
dmnrr04  Offline
I like running the Carter electric to the Carter mechanical, never run low on pressure or run too much pressure to need a regulator...
Re: Can someone recommend a good electric fuel pump? [Re: 383man] #1287111
08/18/12 10:34 AM
08/18/12 10:34 AM
August 24th-25th. Basically next week end.
If the weather holds out, I feel a good turn out is possible.
I'm planning on running in the NSS AF/X class while fine tuning.
Re: Can someone recommend a good electric fuel pump? [Re: fullmetaljacket] #1287112
08/18/12 11:37 AM
08/18/12 11:37 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Carter p4070 here too, just put mine on a few weeks ago.
Re: Can someone recommend a good electric fuel pump? [Re: Exit1965] #1287113
08/18/12 12:01 PM
08/18/12 12:01 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
thanks guys...
Re: Can someone recommend a good electric fuel pump? [Re: Exit1965] #1287114
08/18/12 12:13 PM
08/18/12 12:13 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I here to help you, so please hear me out.
That fuel line setup won't work for you.I'm talking about the suction side only. The filter you have is very fine filter made for use after the pump, electric pump will cavatate on a warm day or under hi demand. Your line is too small also. I also don't see the need for a ball valve in the line, just more weight and another place for leaks. If the valve stem leaks on it it's gonna let air get to the pump and cause problems.
I would use a #10 Male AN fitting with a cone shaped screen stuck in the end for your fuel pump strainer. This fitting is #10 inlet flare X #10 male flare. If your cell is tapered pipe fittings the you use the pipe X #10 flare fitting. That fitting goes into the tank, then a #10 line to the fuel pump. Use a #10 AN fitting in the inlet of the fuel pump. The feed line should always be at least one size larger than the discharge.
If you have 2 #8 on the discharge of your cell then use one of them or better yet both of them tied into one #10 line.
Or even just a single #8 would be better than what you have now, bigger is better for the inlet side. Discharge could be 5/16" just about all the way up front, I'm only talking about the suction side.
Kinsler and others sell sell some real slick cone shaped strainers they go in between the male and female AN fitting to be used as a strainer if you can't get the strainer in the discharge fitting. Yours looks welded to the tank?
Fuel pumps need strainers in front of them and filters after them, there is a difference.
Always use a funnel with fine screen in the end for when you fill your fuel cell.
Just trying to save you some trouble.
Re: Can someone recommend a good electric fuel pump? [Re: Challenger 1] #1287115
08/18/12 03:10 PM
08/18/12 03:10 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Thanks man, that is helpful. I originally put this on just to take care of hot starting issues (and it worked perfectly), I have put a few good runs on it and it seems OK. But like you say it could help it to have more flow before the pump. I'll probably add that to my list of winter projects.
Re: Can someone recommend a good electric fuel pump? [Re: Exit1965] #1287116
08/18/12 03:20 PM
08/18/12 03:20 PM
Cincinnati, Ohio
Cincinnati, Ohio
Cool, the fuel pump is perfectly located, close and below the sump and behind the fuel cell.
And being so close to the outlet helps a bunch and may even allow it to work for you most of the time the way it is.
But a non restricted flow of gas to your pump will make the pump last longer and operate quieter.
It will shorten the life of the pump at the very least the way it is now.
Re: Can someone recommend a good electric fuel pump? [Re: dustergirl340] #1287117
08/18/12 03:54 PM
08/18/12 03:54 PM
tucson az
frank Offline
frank  Offline
tucson az
I went with an Aeromotive stealth 340. It mounts in the tank.
Re: Can someone recommend a good electric fuel pump? [Re: frank] #1287118
08/18/12 04:30 PM
08/18/12 04:30 PM
Cincinnati, Ohio
Cincinnati, Ohio
That's also a very good idea...
