Re: Need to lose weight o my 71 Dart [Re: 80arrow] #1286477
08/18/12 06:40 PM
08/18/12 06:40 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
The scales might be off, but they were running super gas, super comp., and stockers that weekend. If the scales were off I'd think that they would have caught it???? There's alot of added weight with a procharger, i/c, and meth injection with the tank.
Re: Need to lose weight o my 71 Dart [Re: cgall] #1286478
08/18/12 06:42 PM
08/18/12 06:42 PM
8
80arrow Offline OP
80arrow  Offline OP
Fuel cell
chromemoly cage
gun-drilled axles
split monos
lighter driver...
Got the fuel cell, the halo and down bars on the cage are chromoly, has split monos, and I only weigh about 170 or so . I'll look at gun drilled axles tho, Thanks
Re: Need to lose weight o my 71 Dart [Re: cudadoug] #1286479
08/18/12 06:43 PM
08/18/12 06:43 PM
8
80arrow Offline OP
80arrow  Offline OP
I'd LOVE to see pics of this Dart...
I'll try to get some for you
Re: Need to lose weight o my 71 Dart [Re: 80arrow] #1286480
08/18/12 06:45 PM
08/18/12 06:45 PM
8
80arrow Offline OP
80arrow  Offline OP
Greg, I'll probably do the strurt rods in the rear windows like you said, good idea, thanks
Re: Need to lose weight o my 71 Dart [Re: 80arrow] #1286481
08/20/12 05:34 PM
08/20/12 05:34 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I will b running at muscle car. Hopefully we will see you there. I really wouldnt be to worried about your weight. That setup seems to be making plenty of steam. Or maybe you are going for the 7.50 cert cage? lol! Maybe a couple sand bags in the trunk??? Real bias slicks?
67' charger 499 RB 10.57 at 127
Re: Need to lose weight o my 71 Dart [Re: dragram440] #1286482
08/20/12 05:45 PM
08/20/12 05:45 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
72 Swingers are probably not comparable, but mine weighs 3610 with me in it. Small block, aluminum heads and radiator, 727, 6 point rollbar, plastic fuel cell, bench seats, factory column shifter, factory glass and regulators, no heater box, no fiberglass, 3 1/2" exhaust to the back bumper, convo pros, mini tubbed, procharger, intercooler, factory disc brakes, 8 3/4 rear...
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: Need to lose weight o my 71 Dart [Re: DconD100] #1286483
08/20/12 08:46 PM
08/20/12 08:46 PM
La Fontaine IN
Brian Finney Offline
La Fontaine IN
72 Dart iron head 360 2900 lbs minus rear seat and no driver.
Re: Need to lose weight o my 71 Dart [Re: Brian Finney] #1286484
09/03/12 10:13 AM
09/03/12 10:13 AM
8
80arrow Offline OP
80arrow  Offline OP
Well I put discs all the way around on my car last week, way lighter and stops way better. I used Wilwoods Pro Street kits front and back. I weighed stuff on a bathroom scale, not super accurate but gives me a rough idea.
Front brakes saved 44 lbs
rear brakes saved 12 lbs
pulled heater core and blower motor 15 lbs
total 71 lbs
Went and weighed it at the track Friday morning and they said it was 3555 What the....Before I did the brakes it was 3550,
