Is this the correct dist vacuum advance? #1285377
08/14/12 05:50 PM
08/14/12 05:50 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
Saw this picture on e-bay on the blue 69 gtx for sale. I wonder how it runs with the vacuum advance hooked up to the same port as the pvc valve?
Al & Sheila
Re: Is this the correct dist vacuum advance? [Re: 3twos] #1285378
08/14/12 06:08 PM
08/14/12 06:08 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
depends on how the dist? is set. The way its plumbed its timed to run on full vacume advance. Some people do it this way and others do it the factory way.
I am truckless..
Re: Is this the correct dist vacuum advance? [Re: 340SHORTY] #1285379
08/15/12 01:22 PM
08/15/12 01:22 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Mine's (stock) on full time vacuum and it runs well...
Re: Is this the correct dist vacuum advance? [Re: bobs66440] #1285380
08/15/12 03:53 PM
08/15/12 03:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
But full time vacuum is not (stock) ...
Re: Is this the correct dist vacuum advance? [Re: JohnRR] #1285381
08/16/12 06:45 AM
08/16/12 06:45 AM
bobs66440 Offline
bobs66440  Offline
True. I meant my distributor/vacuum advance is stock...
Re: Is this the correct dist vacuum advance? [Re: 3twos] #1285382
08/16/12 07:54 AM
08/16/12 07:54 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Hooked to the manifold, idle will be unstable, mainly w/ automatic trans. The tighter the t/conv., the worse it gets.
Rick
Re: Is this the correct dist vacuum advance? [Re: Rick_Ehrenberg] #1285383
08/16/12 08:27 AM
08/16/12 08:27 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""Hooked to the manifold, idle will be unstable, mainly w/ automatic trans.""
Only if the in D idle vacuum is lower than the vacuum rating of the distributor can. If you have enough vacuum in D at an idle to keep the vacuum can fully engaged, then the in D idle will be fine.
I would guess that allot of people that decide to use manifold vacuum just swap the vacuum hose and then wonder why they can't get the idle to work.
Note: For those who want to run manifold vacuum, chose the appropriate distributor can that is rated lower then your in D idle vacuum.
Re: Is this the correct dist vacuum advance? [Re: YO7_A66] #1285384
08/16/12 10:25 AM
08/16/12 10:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Easier said then done , if we were dealing with a chevy or ford no problem ...
Re: Is this the correct dist vacuum advance? [Re: JohnRR] #1285385
08/16/12 10:46 AM
08/16/12 10:46 AM
I've never ran manifold but from what I've read on it it intrigued me enough to wanna try sometime. I'll just adj the allen wrench clockwise as far as possible if need be to get it all in at the lowest in hg with the can that is on there & see what develops and I have a vacuum pump with a gauge which should be a big help
Re: Is this the correct dist vacuum advance? [Re: RapidRobert] #1285386
08/16/12 11:42 AM
08/16/12 11:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pretty sure the number on the can is the MINIMUM vac required to move the can arm , adjusting the spring will not make it lower , just come in faster ... at minimum ... , or slower , higher vac ???
Re: Is this the correct dist vacuum advance? [Re: JohnRR] #1285387
08/16/12 11:48 AM
08/16/12 11:48 AM
I'm thinking the # on the arm is the amt of (dist) degrees a can offers
Re: Is this the correct dist vacuum advance? [Re: RapidRobert] #1285388
08/16/12 12:19 PM
08/16/12 12:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
