Is this the correct dist vacuum advance?
#1285377
08/14/12 05:50 PM
08/14/12 05:50 PM
Posts: 3,905 Minnesota
3twos
Minnesota
Saw this picture on e-bay on the blue 69 gtx for sale. I wonder how it runs with the vacuum advance hooked up to the same port as the pvc valve?
Al & Sheila
Re: Is this the correct dist vacuum advance?
[Re: 3twos]
#1285378
08/14/12 06:08 PM
08/14/12 06:08 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
depends on how the dist? is set. The way its plumbed its timed to run on full vacume advance. Some people do it this way and others do it the factory way.
I am truckless..
[Re: JohnRR]
#1285381
08/16/12 06:45 AM
08/16/12 06:45 AM
Posts: 1,880 Out in Left Field, NY
bobs66440
Mine's (stock) on full time vacuum and it runs well...
But full time vacuum is not (stock) ...
True. I meant my distributor/vacuum advance is stock...
[Re: Rick_Ehrenberg]
#1285383
08/16/12 08:27 AM
08/16/12 08:27 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
""Hooked to the manifold, idle will be unstable, mainly w/ automatic trans."" Only if the in D idle vacuum is lower than the vacuum rating of the distributor can. If you have enough vacuum in D at an idle to keep the vacuum can fully engaged, then the in D idle will be fine. I would guess that allot of people that decide to use manifold vacuum just swap the vacuum hose and then wonder why they can't get the idle to work. Note: For those who want to run manifold vacuum, chose the appropriate distributor can that is rated lower then your in D idle vacuum.
[Re: YO7_A66]
#1285384
08/16/12 10:25 AM
08/16/12 10:25 AM
Posts: 75,087 A Banana Republic near you.
JohnRR
Easier said then done , if we were dealing with a chevy or ford no problem ...
[Re: JohnRR]
#1285385
08/16/12 10:46 AM
08/16/12 10:46 AM
RapidRobert
I've never ran manifold but from what I've read on it it intrigued me enough to wanna try sometime. I'll just adj the allen wrench clockwise as far as possible if need be to get it all in at the lowest in hg with the can that is on there & see what develops and I have a vacuum pump with a gauge which should be a big help
[Re: RapidRobert]
#1285386
08/16/12 11:42 AM
08/16/12 11:42 AM
JohnRR
Pretty sure the number on the can is the MINIMUM vac required to move the can arm , adjusting the spring will not make it lower , just come in faster ... at minimum ... , or slower , higher vac ???
[Re: JohnRR]
#1285387
08/16/12 11:48 AM
08/16/12 11:48 AM
RapidRobert
I'm thinking the # on the arm is the amt of (dist) degrees a can offers
