LBP 7-1/4 Rear #1285037
08/13/12 10:47 PM
08/13/12 10:47 PM
CT..USA
catman56 Offline OP
catman56  Offline OP
CT..USA
Was there a 7-1/4 rear with a LBP ever produced in an A-Body and if so what year?
Re: LBP 7-1/4 Rear [Re: catman56] #1285038
08/14/12 12:21 AM
08/14/12 12:21 AM
'73-'76 A body. I believe only with BBP single piston discs up front
Re: LBP 7-1/4 Rear [Re: RapidRobert] #1285039
08/14/12 01:14 AM
08/14/12 01:14 AM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
My old 74 318 Valiant had the big bolt pattern 7-1/4.
Re: LBP 7-1/4 Rear [Re: RapidRobert] #1285040
08/14/12 01:47 AM
08/14/12 01:47 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Re: LBP 7-1/4 Rear [Re: catman56] #1285041
08/14/12 10:51 PM
08/14/12 10:51 PM
CT..USA
catman56 Offline OP
catman56  Offline OP
CT..USA
So I do have a set of LBP axles from a 73-76 7-1/4 rear..The next question is,will they fit in the SBP axled housing I have in my 71 Dart? From the bearing specs from NAPA,it does not seem so..The OD and ID of the bearings are different..
Re: LBP 7-1/4 Rear [Re: catman56] #1285042
08/14/12 10:57 PM
08/14/12 10:57 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I had a 76 Feather Duster with a LBP 7 1/4.
Re: LBP 7-1/4 Rear [Re: MPerry] #1285043
08/14/12 11:49 PM
08/14/12 11:49 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I believe that the axle housing and shafts are narrower on the 73-76 models.
Re: LBP 7-1/4 Rear [Re: Kern Dog] #1285044
08/15/12 02:43 AM
08/15/12 02:43 AM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I think they are the same width but they appear narrower because the front track is wider due to the disk brakes.
Re: LBP 7-1/4 Rear [Re: catman56] #1285045
08/15/12 10:42 AM
08/15/12 10:42 AM
iirc they dont interchange, as you said bearings etc I think are different
Re: LBP 7-1/4 Rear [Re: catman56] #1285046
08/15/12 12:04 PM
08/15/12 12:04 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
also realize you would have to change the brakes , the axle offset of the 2 are more than likely different .
I think you answered your own question , if the ID is different, that is the part the axle rides on , then the axle won't fit the bearing in your rear properly . If the OD is different then the bearing that fits the new axle will not fit the housing .
Re: LBP 7-1/4 Rear [Re: catman56] #1285047
08/15/12 12:50 PM
08/15/12 12:50 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The axles and housings are completely different, so they do not interchange.
Re: LBP 7-1/4 Rear [Re: catman56] #1285048
08/15/12 06:29 PM
08/15/12 06:29 PM
CT..USA
catman56 Offline OP
catman56  Offline OP
CT..USA
Thanks everyone for all the input..I was thinking I would cut the LBP axles .100" and use the SBP bearings..I would also switch the retaining plates due to the 5 vs 4 hole issue..The only thing that might be a problem is the brake back spacing as JohnRR stated..Just trying to avoid spending approx $1000 to set up an 8-3/4 with LBP axles right now..
Re: LBP 7-1/4 Rear [Re: catman56] #1285049
08/15/12 08:12 PM
08/15/12 08:12 PM
JohnRR Offline
JohnRR  Offline
You should be able to do an A body rear for a lot less than that even piecing one together.
Re: LBP 7-1/4 Rear [Re: JohnRR] #1285050
08/15/12 11:27 PM
08/15/12 11:27 PM
Washington State, USA
W
Winchester 73 Offline
W
dont forget aspen volare rears from the jyd-dang near a bolt in.
Re: LBP 7-1/4 Rear [Re: Winchester 73] #1285051
08/16/12 12:38 AM
08/16/12 12:38 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
If by "dang near" you mean spring pads that are several inches apart, sure.....Its real close.
Re: LBP 7-1/4 Rear [Re: Kern Dog] #1285052
08/16/12 03:35 AM
08/16/12 03:35 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
76-80 F rear is about 1" wider than a 72 A 7-1/4, perch to perch.
Re: LBP 7-1/4 Rear [Re: catman56] #1285053
08/16/12 05:49 AM
08/16/12 05:49 AM
Central Ohio
rtidd440 Offline
super street
rtidd440  Offline
super street
Central Ohio
Little bit off topic, but I heard that the guys who build lawn tractor pull tractors will actually pay real money for those 7 1/4 diffs.
Rob 70 Swinger 340 4spd FC7 4 sale 69 Charger auto Q5 14 Challenger SRT8 Core 6spd black Deposit on Hellcat
Re: LBP 7-1/4 Rear [Re: catman56] #1285054
08/16/12 08:31 PM
08/16/12 08:31 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
If my info is correct the BBP all have 10" drums. Just sold one.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: LBP 7-1/4 Rear [Re: Rug_Trucker] #1285055
08/16/12 08:48 PM
08/16/12 08:48 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I actually sold one of the too for $100 a couple weeks ago!
JB Rhinehart, Realist
A-Body's RULE!
