Fuel filler neck screws? #1282159
08/09/12 08:28 PM
08/09/12 08:28 PM
New Brunswick Canada
copperSwinger Offline OP
Someone snuck into my garage and stole my 4 screws for my 71 dart fuel filler tube (where mounts to the quarter panel) I cant remember what they looked like. The robber took nothing else.
Can someone show me?
Re: Fuel filler neck screws? [Re: copperSwinger] #1282160
08/09/12 09:50 PM
08/09/12 09:50 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here are some pics. Hope this helps!
Re: Fuel filler neck screws? [Re: moparfan53] #1282161
08/09/12 10:20 PM
08/09/12 10:20 PM
thanks a lot! I thought you had to slide the tube in from the outside, yours is different. interesting. Never would have thought of that. Now Ive got my work cut out for tomorrow.
High-five from a Local NBer
Re: Fuel filler neck screws? [Re: copperSwinger] #1282162
08/12/12 07:37 PM
08/12/12 07:37 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
#10 x 1/2" pan head, clear zinc, sheetmetal screw
Re: Fuel filler neck screws? [Re: copperSwinger] #1282163
08/12/12 09:36 PM
08/12/12 09:36 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Hah, he frequents my garage alot and it tools he after. then he leaves his soda cans, snack wrappers and skateboard junk everywhere. rumor has it he looks alot like my son!
Re: Fuel filler neck screws? [Re: copperSwinger] #1282164
08/13/12 10:46 AM
08/13/12 10:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Depends on the year , I don't know when the change occured but I do know that 67-69 A bodies the filler tube is inside the rear quarter, I have a tube that is supposed to be from a 72 and goes in from the outside.
One way to tell is if your filler tube has a vent line attached to it, nipple and bracket to hold it, the ones that slide in form the outside will have neither.
Re: Fuel filler neck screws? [Re: JohnRR] #1282165
08/13/12 11:36 AM
08/13/12 11:36 AM
It's a dry heat
It's a dry heat
My brothers 1971 duster is on the inside
Re: Fuel filler neck screws? [Re: JohnRR] #1282166
08/13/12 07:04 PM
08/13/12 07:04 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
JohnRR; Thanks for the info, I was not aware there was a design change.
copperSwinger; I should have specified the pics were of a 70 Swinger. I assumed (perhaps incorrectly) that 70 and 71 would be the same. Here is an inside filler tube pic for you to compare to your's.
High 5 back at ya from a fellow NBer!
Re: Fuel filler neck screws? [Re: moparfan53] #1282167
08/25/12 01:49 PM
08/25/12 01:49 PM
Texas
blewbyu2bad Offline
blewbyu2bad  Offline
Texas
I have this same filler neck for my 69 Dart with the vent tube. Can anyone tell me the purpose of it? It attaches to the fuel pickup assy so both ends of the vent tube always see the same pressures inside the tank. Can't figure out its purpose.
Friends Don't Let Friends Drive GM
Re: Fuel filler neck screws? [Re: blewbyu2bad] #1282168
08/25/12 07:00 PM
08/25/12 07:00 PM
Turns out mine slides in from the outside like I thought in the first place haha. had a hell of a time playing with it.
I guess the changeover took place sometime before april 71. interesting.
glad thats solved, thanks guys
