Re: Fuel filler neck screws?
[Re: copperSwinger]
#1282163
08/12/12 09:36 PM
08/12/12 09:36 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Someone snuck into my garage and stole my 4 screws for my 71 dart fuel filler tube (where mounts to the quarter panel) I cant remember what they looked like. The robber took nothing else.
Can someone show me?
Hah, he frequents my garage alot and it tools he after. then he leaves his soda cans, snack wrappers and skateboard junk everywhere. rumor has it he looks alot like my son!
[Re: copperSwinger]
#1282164
08/13/12 10:46 AM
08/13/12 10:46 AM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
thanks a lot! I thought you had to slide the tube in from the outside, yours is different. interesting. Never would have thought of that. Now Ive got my work cut out for tomorrow.
High-five from a Local NBer
Depends on the year , I don't know when the change occured but I do know that 67-69 A bodies the filler tube is inside the rear quarter, I have a tube that is supposed to be from a 72 and goes in from the outside.
One way to tell is if your filler tube has a vent line attached to it, nipple and bracket to hold it, the ones that slide in form the outside will have neither.
[Re: JohnRR]
#1282165
08/13/12 11:36 AM
08/13/12 11:36 AM
Posts: 21,406 It's a dry heat
gtx6970
It's a dry heat
My brothers 1971 duster is on the inside
[Re: JohnRR]
#1282166
08/13/12 07:04 PM
08/13/12 07:04 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
JohnRR; Thanks for the info, I was not aware there was a design change.
copperSwinger; I should have specified the pics were of a 70 Swinger. I assumed (perhaps incorrectly) that 70 and 71 would be the same. Here is an inside filler tube pic for you to compare to your's.
High 5 back at ya from a fellow NBer!
[Re: moparfan53]
#1282167
08/25/12 01:49 PM
08/25/12 01:49 PM
Posts: 44 Texas
blewbyu2bad
Texas
I have this same filler neck for my 69 Dart with the vent tube. Can anyone tell me the purpose of it? It attaches to the fuel pickup assy so both ends of the vent tube always see the same pressures inside the tank. Can't figure out its purpose. Thanks
Friends Don't Let Friends Drive GM
