Circle Track Race Car Steering Help Needed #1279547
08/04/12 11:17 PM
08/04/12 11:17 PM
NC
BillNC Offline OP
BillNC  Offline OP
NC
Among other things, trashed my small sector power steering gear box when I couldn't miss a spinning car. Had a large sector reman box and pitman sitting on shelf, so put it in car. Now, the car steers way too far to the left and not far enough to the right. What are we missing which is different between small sector shaft steering components and large shaft components? Is there something we need to change or should we just find a small sector box?
Re: Circle Track Race Car Steering Help Needed [Re: BillNC] #1279548
08/05/12 12:45 AM
08/05/12 12:45 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds like the pitman arm wasn't installed with the steering gear box and wheels centered.
Re: Circle Track Race Car Steering Help Needed [Re: stumpy] #1279549
08/05/12 01:02 AM
08/05/12 01:02 AM
NC
BillNC Offline OP
BillNC  Offline OP
NC
That's what we thought first, tried it several times, same result. Large sector pitman indexes only 2 ways, original pitman clocked 4 ways. Seems like something else is different between the two series (small v. large sector).
Re: Circle Track Race Car Steering Help Needed [Re: BillNC] #1279550
08/05/12 02:15 AM
08/05/12 02:15 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Maybe wrong pitman? I know the C-body pitmans are clocked differently. They are longer too.
Re: Circle Track Race Car Steering Help Needed [Re: BillNC] #1279551
08/05/12 06:32 PM
08/05/12 06:32 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
File out the clocking teeth and install it where you need it. Problem solved.
Re: Circle Track Race Car Steering Help Needed [Re: mod5v] #1279552
08/05/12 09:06 PM
08/05/12 09:06 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Use the C-body centerlink, it will move the pitman closer to the center of the car. The clocking is different because the C-body center to center distance is less than a b-body between the pitman and idler. TIm
Re: Circle Track Race Car Steering Help Needed [Re: mod5v] #1279553
08/05/12 09:06 PM
08/05/12 09:06 PM
IN
ahy Offline
ahy  Offline
IN
If the pot connector is assembled 180 deg out of phase, it will favor one side. Try pulling apart the pot and re-assembling 180 degrees opposite.
Re: Circle Track Race Car Steering Help Needed [Re: BillNC] #1279554
08/06/12 12:19 AM
08/06/12 12:19 AM
NC
BillNC Offline OP
BillNC  Offline OP
NC
No pot connector used. As currently "fixed," can only get about 2.5 turns of steering wheel, on left turn tire hits frame rail. Still mystified.
Re: Circle Track Race Car Steering Help Needed [Re: BillNC] #1279555
08/06/12 07:42 AM
08/06/12 07:42 AM
IN
ahy Offline
ahy  Offline
IN
Just changing from small sector to large shouldn't cause the problem. I made the swap on a '70E when I got my box rebuilt. There is some other difference. If you are not using a pot do you have a U joint? Is it possible to clock the U joint or assemble 180 degrees different?
Re: Circle Track Race Car Steering Help Needed [Re: ahy] #1279556
08/06/12 12:35 PM
08/06/12 12:35 PM
NC
BillNC Offline OP
BillNC  Offline OP
NC
I agree that the difference in sector shafts alone wouldn't make the difference. But, with the larger sector and only 2 clocking positions, we can't get the thing to line up. And can't figure out why..... Is there enough adjustment in the centering valve to correct this? That's the only thing we haven't tried....
Re: Circle Track Race Car Steering Help Needed [Re: BillNC] #1279557
08/06/12 02:47 PM
08/06/12 02:47 PM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
I was thinking centering valve when I read this the other day but couldn't figure out the name. I think the FSM has instructions. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Circle Track Race Car Steering Help Needed [Re: HUSTLESTUFF] #1279558
08/06/12 06:25 PM
08/06/12 06:25 PM
NC
BillNC Offline OP
BillNC  Offline OP
NC
Well, so far we've still not figured it out.....
Re: Circle Track Race Car Steering Help Needed [Re: BillNC] #1279559
08/06/12 11:44 PM
08/06/12 11:44 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Did you check the entire front end out? If the pitman arm is clocked right then something has got to be bent? Check where the ball joint hits the LCA etc..?
Re: Circle Track Race Car Steering Help Needed [Re: brads70] #1279560
08/08/12 06:55 PM
08/08/12 06:55 PM
NC
BillNC Offline OP
BillNC  Offline OP
NC
Apparently, at some point the steering has been modified or customized. The pitman which came with the large sector steering box was different (longer) than the original pitman. It simply would not fit correctly with the existing steering setup. So, we are are going with the original pitman with a small sector firm feel rebuilt box. Will let you know what happens.
Re: Circle Track Race Car Steering Help Needed [Re: BillNC] #1279561
08/08/12 08:52 PM
08/08/12 08:52 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Just a thought.... are you sure it's not a quick ratio arm? I have one from Firm Feel and you can clock it it any position ( no master splines)
Re: Circle Track Race Car Steering Help Needed [Re: brads70] #1279562
08/09/12 12:24 AM
08/09/12 12:24 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think it could be a C-body arm. Some have splines that are clocked a lot different.
