Comp XE295HL with beehives? #1277071
07/31/12 01:09 PM
07/31/12 01:09 PM
IL
E
EchoSixMike Offline OP
E
IL
Looking at using the Comp XE295HL in a '499 lowdeck with Victor heads w/ 1.6:1 rockers. Just looking at the #'s, it seems I can pull more mass out of the valvetrain by using beehive springs than by using Comps toolsteel retainers with conventional springs. The PAC 1518 seems to be suitable with this cam, if a bit light on open pressure, compared to the recommended Comp 924-16 spring. Anyone done this before? S/F....Ken M
Re: Comp XE295HL with beehives? [Re: EchoSixMike] #1277072
07/31/12 02:54 PM
07/31/12 02:54 PM
dogdays Offline
dogdays  Offline
Haven't done it but it sounds reasonable to me. Two factors in your favor: 1. less weight; 2. beehives have much better resonance characteristics.
R.
Re: Comp XE295HL with beehives? [Re: EchoSixMike] #1277073
07/31/12 04:24 PM
07/31/12 04:24 PM
It is way better to have more seat and opended pressures to start with than a little bit to little, especailly on solid roller cams EDITED OOPs, that is the same cam I put in my 464 pump six pak motor, not a solid roller cam as I misread I set mine up at 160 lbs on the seats and around 365 to 375 lbs opened with i.6 rockers It runs good, dyno time and one year in the car racing and street driving , under 1500 miles total
Re: Comp XE295HL with beehives? [Re: Cab_Burge] #1277074
07/31/12 09:11 PM
07/31/12 09:11 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
The July 2010 issue of Popular Hot Rodding they build a killer 505 using the XR292HR-10 cam and 26120-16 beehives with 1.6 ratio rockers. You might want to find a copy. (Ask me why I know this edition )615hp and 611tq
Re: Comp XE295HL with beehives? [Re: EchoSixMike] #1277075
07/31/12 11:56 PM
07/31/12 11:56 PM
SoCal
Brian Hafliger Offline
SoCal
Use the 26120's and set them up at 1.875 I.H.
Brian Hafliger
Re: Comp XE295HL with beehives? [Re: Cudajon] #1277076
08/01/12 12:47 AM
08/01/12 12:47 AM
Utah
topbrent Offline
topbrent  Offline
Utah
AndyF built that one:
http://www.popularhotrodding.com/tech/1007phr_big_block_mopar_engines/viewall.html
