e body steering column slop? #1275909
07/29/12 04:22 PM
07/29/12 04:22 PM
Los Angeles, CA
71_dramaqueen Offline OP
Los Angeles, CA
I'm trying to track down about 15deg of play in the steering on an ebody. Everything is new (ball joints, arms, pwr steering box). Do the ebody columns have any internal connection that can wear and produce slop in the steering? The pot joint just got rebuilt and it is not causing it as far as i can tell.
1971 challenger. 6.2L Hellcat, T56 Magnum
Re: e body steering column slop? [Re: 71_dramaqueen] #1275910
07/29/12 04:49 PM
07/29/12 04:49 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You sure the you have the shoes installed properly in the "pot joint"?
Re: e body steering column slop? [Re: Challenger 1] #1275911
07/29/12 07:23 PM
07/29/12 07:23 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
That was my first guess too. The guy that replaced my power steering box put them in wrong and I had to pull the column and fix it myself.
Scott
1969 Super Bee, 383/4 speed
Re: e body steering column slop? [Re: StukaJU87] #1275912
07/30/12 05:34 PM
07/30/12 05:34 PM
Los Angeles, CA
Los Angeles, CA
I dont believe it is the pot joint. The company that makes the box also suggested i check the shoes as they could have been put in sideways. I cannot see a movement discrepancy between the shaft and pot. I also can put my hand on them while the wheel is being rocked and not feel any slack.
Re: e body steering column slop? [Re: 71_dramaqueen] #1275913
07/30/12 06:06 PM
07/30/12 06:06 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Have someone wiggle the wheel back and forth while you go under the car and put your hand on each suspension connection.
Make sure the steering box mounts on the K-member aren't broken. The factory welding job was poor.
There is some adjustment in the steering box. You loosen a jamb nut and use an allen wrench to adjust. The procedure should be in the FSM.
Re: e body steering column slop? [Re: burdar] #1275914
07/30/12 06:17 PM
07/30/12 06:17 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
There is a slip joint for the column to colapse but the design is such that slop isn't likely & 15 degrees isn't possible... If it's not in the coupler than my next question is are you sure it's in the column & not the box? And if it could be in the box are you checking with the engine off or the engine running? Cause engine off means you'll feel lots of what you perceive as slop but actually is the control valve opening a fluid passage in either direction....
Re: e body steering column slop? [Re: 1_WILD_RT] #1275915
07/30/12 07:17 PM
07/30/12 07:17 PM
Los Angeles, CA
Los Angeles, CA
How much play could the slip joint cause? It could it be adding to a problem elsewhere. How hard is it to check this if i pull the column?
And yes I do have it running while I check. With the car on the ground I can look from above and see the pot connector (and splined connection to box) move about 1/8 of a turn back and forth before seeing the steering arm wiggle. This does not seem right to me.
Welds are sold on the mount, I may try the gear adjustment as a last resort before pulling this NEW box.
-thanks for the advice
Re: e body steering column slop? [Re: 71_dramaqueen] #1275916
07/30/12 07:40 PM
07/30/12 07:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
To isolate if the slop is in the column or elsewhere use a par of jumbo channel locks grab the coupler pot with the jaws & lock the handle against the inner fender, while holding the channel locks have an assistant feel the steering wheel for slop... It should be pretty obvious if there is a problem or not....
Re: e body steering column slop? [Re: 1_WILD_RT] #1275917
07/30/12 07:46 PM
07/30/12 07:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Even new boxes may need a bit of adjustment.
Re: e body steering column slop? [Re: stumpy] #1275918
07/30/12 08:24 PM
07/30/12 08:24 PM
IN
ahy Offline
ahy  Offline
IN
For power steering are you testing with engine running? PS boxes with no power can feel sloppy but OK with the pump running.
Re: e body steering column slop? [Re: ahy] #1275919
07/30/12 08:31 PM
07/30/12 08:31 PM
WV
JohnH Offline
JohnH  Offline
WV
I installed my shoes in wrong, and had to re fix it.. Had the same problem as you have now..
Re: e body steering column slop? [Re: JohnH] #1275920
07/31/12 09:26 PM
07/31/12 09:26 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Get rid of that pot and put in a Flaming River coupler.
All the difference in the world.
Re: e body steering column slop? [Re: Cudajon] #1275921
07/31/12 10:17 PM
07/31/12 10:17 PM
Howell, Mi
Shatar4 Offline
Shatar4  Offline
Howell, Mi
What's the part number for that?
Re: e body steering column slop? [Re: Shatar4] #1275922
08/01/12 12:22 PM
08/01/12 12:22 PM
Los Angeles, CA
Los Angeles, CA
Hmmm I like that u-joint type. Second on the part #. I did put the shoes in right but the design inherently has a little slack.
So indeed after more diagnosis it is my NEW firm Feel box causing all the slop. I wonder if the warranty covers the many hours of cursing with the starter, headers and motor to get it out?........NOT
Re: e body steering column slop? [Re: 71_dramaqueen] #1275923
08/01/12 12:48 PM
08/01/12 12:48 PM
Cincinnati, Ohio
Cincinnati, Ohio
It's not Firm Feels fault, I'd bet a 1000 bucks their box is tight. I'd also bet a 1000 bucks you have the coupler togeather wrong.
Re: e body steering column slop? [Re: Shatar4] #1275924
08/01/12 01:13 PM
08/01/12 01:13 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
That is what I did on my 70 Challenger when i went to a custom made tubular column.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: e body steering column slop? [Re: 6PKRTSE] #1275925
08/01/12 03:54 PM
08/01/12 03:54 PM
NE
bigtail Offline
bigtail  Offline
NE
Part number is FR1506P. Bought one for my Challenger, but haven't installed it yet. New Firm Feel box, Stage 2 also not yet installed.
This page is made up completely of recycled electrons.
Re: e body steering column slop? [Re: bigtail] #1275926
08/01/12 05:29 PM
08/01/12 05:29 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
was there a little flat spring that held the little shoes out to full extension?
Re: e body steering column slop? [Re: savoy64] #1275927
08/01/12 08:08 PM
08/01/12 08:08 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Re: e body steering column slop? [Re: Cudajon] #1275928
08/01/12 10:34 PM
08/01/12 10:34 PM
NE
bigtail Offline
bigtail  Offline
NE
One major reason that I haven't installed the Flaming River u-joint, is that they don't tell you until after you buy it that it is NOT A SIMPLE BOLT IN DEAL. you have to cut your steering shaft off by 1 1/2" to install it on a factory power steering set up. I'm going to eventually replace my motor, and while that is being done, re-weld the K member and install the Firm Feel power unit all at the same time. No sense in doing things three times when you can do it all at once.
