The Hemi........Progress #1274313
07/26/12 08:48 AM
07/26/12 08:48 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
More money, more progress as the saying goes...
Re: The Hemi........Progress [Re: Dragula] #1274314
07/26/12 08:49 AM
07/26/12 08:49 AM
Dragula Offline OP
Dragula  Offline OP
Re: The Hemi........Progress [Re: Dragula] #1274315
07/26/12 08:50 AM
07/26/12 08:50 AM
Dragula Offline OP
Dragula  Offline OP
A pic for Zippy....
Re: The Hemi........Progress [Re: Dragula] #1274316
07/26/12 08:51 AM
07/26/12 08:51 AM
Dragula Offline OP
Dragula  Offline OP
Re: The Hemi........Progress [Re: Dragula] #1274317
07/27/12 01:59 AM
07/27/12 01:59 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Cool!
That's one of the benefits of building it yourself, progress pics.
Since someone else is building mine I won't have any pics till it comes back home.
Re: The Hemi........Progress [Re: SNK-EYZ] #1274318
07/27/12 07:03 AM
07/27/12 07:03 AM
Dragula Offline OP
Dragula  Offline OP
Cool!
Actually my engine builder is just up the road about 10 miles from me, and I am down there as much as possible.
Next step is cam and oiling. The cam quoted for this build is a really mild .589 lift with a 110CL and 260 duration at 50 or so....Still on a ledge about it, we will see.
Re: The Hemi........Progress [Re: Dragula] #1274319
07/27/12 08:39 AM
07/27/12 08:39 AM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
you better check the lifter bores i used that block and solid flat tappet 904 lifter would not go in the hole past half way good thing i was using a solid roller that fit just right "factory fu in my favor" but i did not relize the problem until i had the short block assembled!
Re: The Hemi........Progress [Re: Dragula] #1274320
07/27/12 09:35 AM
07/27/12 09:35 AM
ScatPackNick Offline
Lookin good, cant wait to see the finished product
Re: The Hemi........Progress [Re: Dragula] #1274321
07/27/12 09:44 AM
07/27/12 09:44 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Very nice
Cubic inch/bore and stroke?
Rich H.
Esse Quam Videri
Re: The Hemi........Progress [Re: ZIPPY] #1274322
07/27/12 10:12 AM
07/27/12 10:12 AM
Dragula Offline OP
Dragula  Offline OP
Very nice
484 cubes 4.310 bore (+.060) x 4.15 stroke
11.6:1 compression
Eagle crank
Manley rods
JE Pistons
Indy 426-1 heads
The block has tons of meat everywhere. The data sheet states it can bored to 4.600 safely, so room to grow for sure. I bought this for the rotating assembly I already had from my previous hemi.
I promise, the next one will be bigger....
Just not sure about the cam. Going from a .738" to .589 seems a little too big of a change.
Re: The Hemi........Progress [Re: Dragula] #1274323
07/27/12 11:35 PM
07/27/12 11:35 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Very nice build, great pictures. Put a bigger cam in it and let it eat.Dave
Re: The Hemi........Progress [Re: quickd100] #1274324
07/28/12 02:56 AM
07/28/12 02:56 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
yes a bigger cam...
Re: The Hemi........Progress [Re: 70blackfish] #1274325
07/28/12 10:20 AM
07/28/12 10:20 AM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
I know the feeling builder one now,Keep the pictures coming
Ain't nuthin like a HEMI !
Re: The Hemi........Progress [Re: Mulehead] #1274326
07/28/12 11:49 AM
07/28/12 11:49 AM
North Carolina
Huneycutt Offline
Huneycutt  Offline
North Carolina
Since you are near your engine builder, don't forget to share the dyno video!
Re: The Hemi........Progress [Re: Huneycutt] #1274327
07/28/12 05:39 PM
07/28/12 05:39 PM
Dragula Offline OP
Dragula  Offline OP
Have a choice of timing covers...I have a Milidon gear drive or a Cloyes billet roller timing chain, and a new cover I just received from a member on here...For now, I think I am going with the chain and new cover...Oil pump and cover should be here next week. And he already ordered the cam. I think its mild, but we will see. Seems my crappy 4.10 gears are a bit mild so they wanted the power band down lower.
For intake and carb, choices get a lot more interesting and pricey. Since I can't run my injection, I have a couple of choices:
1-Purchase an Indy 426-2 single plane for a 4150. The catch is, it will need to be gasket matched to match up with the heads.
2-Call BGR and have him make a tented top plate for my tunnel ram for a 4150 carb
3-dunno, find a used one for a good price.
Re: The Hemi........Progress [Re: Mulehead] #1274328
07/28/12 05:41 PM
07/28/12 05:41 PM
Dragula Offline OP
Dragula  Offline OP
Wish I could have sprung for the alum block...and a few more cubes. Looks awesome.
Re: The Hemi........Progress [Re: Dragula] #1274329
07/28/12 07:26 PM
07/28/12 07:26 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Why can't you use the injection setup again?
Re: The Hemi........Progress [Re: Defbob] #1274330
07/28/12 07:45 PM
07/28/12 07:45 PM
Dragula Offline OP
Dragula  Offline OP
Efi is not legal in the class I run...
Re: The Hemi........Progress [Re: Dragula] #1274331
07/29/12 07:15 AM
07/29/12 07:15 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've got one of those manifolds on the shelf. I tryed it with a 4500 adapter and a 1140cfm BG on the dyno. The tunnel ram and 2 thermoquads were 30hp better on the first pull with no tuning on my junk. If you'd like to try it I'll lend it to you. (You may have to mill it to fit your application but that's fine with me)Dave
Re: The Hemi........Progress [Re: quickd100] #1274332
07/29/12 10:31 AM
07/29/12 10:31 AM
Dragula Offline OP
Dragula  Offline OP
You have a PM on the single 4bbl intake...I should try your Thermo quads on my tunnel ram with a 2x4 top plate...Just not a fan of tuning duals for racing anymore.
