Re: The Hemi........Progress
[Re: Dragula]
#1274317
07/27/12 01:59 AM
07/27/12 01:59 AM
Posts: 10,168 A Red State
SNK-EYZ
A Red State
Cool! That's one of the benefits of building it yourself, progress pics. Since someone else is building mine I won't have any pics till it comes back home. ![](/ubbthreads/images/graemlins/tongue.gif)
[Re: SNK-EYZ]
#1274318
07/27/12 07:03 AM
07/27/12 07:03 AM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Cool!
Actually my engine builder is just up the road about 10 miles from me, and I am down there as much as possible.
Next step is cam and oiling. The cam quoted for this build is a really mild .589 lift with a 110CL and 260 duration at 50 or so....Still on a ledge about it, we will see.
[Re: Dragula]
#1274321
07/27/12 09:44 AM
07/27/12 09:44 AM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
Very nice Cubic inch/bore and stroke?
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1274322
07/27/12 10:12 AM
07/27/12 10:12 AM
Dragula
Very nice
484 cubes 4.310 bore (+.060) x 4.15 stroke 11.6:1 compression Eagle crank Manley rods JE Pistons Indy 426-1 heads
The block has tons of meat everywhere. The data sheet states it can bored to 4.600 safely, so room to grow for sure. I bought this for the rotating assembly I already had from my previous hemi.
I promise, the next one will be bigger.... ![](/ubbthreads/images/graemlins/hammer.gif)
Just not sure about the cam. Going from a .738" to .589 seems a little too big of a change.
[Re: Huneycutt]
#1274327
07/28/12 05:39 PM
07/28/12 05:39 PM
Dragula
Have a choice of timing covers...I have a Milidon gear drive or a Cloyes billet roller timing chain, and a new cover I just received from a member on here...For now, I think I am going with the chain and new cover...Oil pump and cover should be here next week. And he already ordered the cam. I think its mild, but we will see. Seems my crappy 4.10 gears are a bit mild so they wanted the power band down lower. For intake and carb, choices get a lot more interesting and pricey. Since I can't run my injection, I have a couple of choices: 1-Purchase an Indy 426-2 single plane for a 4150. The catch is, it will need to be gasket matched to match up with the heads. 2-Call BGR and have him make a tented top plate for my tunnel ram for a 4150 carb 3-dunno, find a used one for a good price. ![](/ubbthreads/images/graemlins/no.gif)
[Re: Mulehead]
#1274328
07/28/12 05:41 PM
07/28/12 05:41 PM
Dragula
I know the feeling builder one now,Keep the pictures coming
Wish I could have sprung for the alum block...and a few more cubes. Looks awesome.
[Re: quickd100]
#1274332
07/29/12 10:31 AM
07/29/12 10:31 AM
Dragula
I've got one of those manifolds on the shelf. I tryed it with a 4500 adapter and a 1140cfm BG on the dyno. The tunnel ram and 2 thermoquads were 30hp better on the first pull with no tuning on my junk. If you'd like to try it I'll lend it to you. (You may have to mill it to fit your application but that's fine with me)Dave
You have a PM on the single 4bbl intake...I should try your Thermo quads on my tunnel ram with a 2x4 top plate...Just not a fan of tuning duals for racing anymore.
