Re: Carter AFB Metering Rod number to decimal equivelency
[Re: az426john]
#1273258
07/24/12 08:49 PM
07/24/12 08:49 PM
RapidRobert
call the carburetor shop in Eldon Missouri 1-573-392-7378
[Re: RapidRobert]
#1273263
07/25/12 12:58 PM
07/25/12 12:58 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
We are trying to lean it out a little at idle.
wouldn't you want to be working on the idle circuit rather than the "cruise" step of the rods
At idle the metering rods and jets are not coming into play unless the throttle butterflies are open to far ...
[Re: 62maxwgn]
#1273266
09/12/13 07:51 PM
09/12/13 07:51 PM
Posts: 23 Canada
CdnValiant
Canada
Do you know the carb number for that rod ?I have all the Carter Svc/parts/tech information from 1955 through 1974,
16-403 and 16-405 are three step rods,if you can't read it PM me !!
62maxwgn...you have a pm.
[Re: 62maxwgn]
#1273267
09/12/13 09:18 PM
09/12/13 09:18 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Is it me, or do they have some numbers flipped around on that chart for the 403 and 405?
