Carter AFB Metering Rod number to decimal equivelency #1273256
07/24/12 07:06 PM
07/24/12 07:06 PM
Arizona
az426john Offline OP
Arizona
Does anyone know of a Carter AFB Metering Rod number to decimal equivalency chart that shows 16-XXX 2 step rod is .065 X 0.52 for old factory carbs? I am specifically looking for 16-403 and 16-405.
Re: Carter AFB Metering Rod number to decimal equivelency [Re: az426john] #1273257
07/24/12 07:50 PM
07/24/12 07:50 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the only info i know of that might come close is the edelbrock metering rod chart. they give rod numbers with rod sizes.
Re: Carter AFB Metering Rod number to decimal equivelency [Re: az426john] #1273258
07/24/12 08:49 PM
07/24/12 08:49 PM
call the carburetor shop in Eldon Missouri 1-573-392-7378
Re: Carter AFB Metering Rod number to decimal equivelency [Re: az426john] #1273259
07/24/12 09:07 PM
07/24/12 09:07 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
The .0650 X .0520 is 16-485 I don't see the other numbers in my book.
Re: Carter AFB Metering Rod number to decimal equivelency [Re: az426john] #1273260
07/24/12 09:18 PM
07/24/12 09:18 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Do you know the carb number for that rod ?I have all the Carter Svc/parts/tech information from 1955 through 1974,
16-403 and 16-405 are three step rods,if you can't read it PM me !!
Re: Carter AFB Metering Rod number to decimal equivelency [Re: 62maxwgn] #1273261
07/25/12 08:53 AM
07/25/12 08:53 AM
Arizona
Arizona
It's for a 66 273 4 barrel, 4 speed car, but the only book I have is for a 67 so I was using carb humber 4294S. We are trying to lean it out a little at idle. I will PM you.
Re: Carter AFB Metering Rod number to decimal equivelency [Re: az426john] #1273262
07/25/12 11:21 AM
07/25/12 11:21 AM
wouldn't you want to be working on the idle circuit rather than the "cruise" step of the rods
Re: Carter AFB Metering Rod number to decimal equivelency [Re: RapidRobert] #1273263
07/25/12 12:58 PM
07/25/12 12:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
At idle the metering rods and jets are not coming into play unless the throttle butterflies are open to far ...
Re: Carter AFB Metering Rod number to decimal equivelency [Re: JohnRR] #1273264
07/25/12 01:14 PM
07/25/12 01:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
also John, if this is your early build Valiant being discussed keep in mond that the carb and intake setup you have is oddball having a manifold with no provisions for a choke apparatus. You might have a different issue unrelated to jetting or rods.
Re: Carter AFB Metering Rod number to decimal equivelency [Re: az426john] #1273265
07/28/12 01:14 PM
07/28/12 01:14 PM
Arizona
Arizona
Many thanks to all that responded with excellent results.
John
Re: Carter AFB Metering Rod number to decimal equivelency [Re: 62maxwgn] #1273266
09/12/13 07:51 PM
09/12/13 07:51 PM
Canada
CdnValiant Offline
CdnValiant  Offline
Canada
62maxwgn...you have a pm.
Re: Carter AFB Metering Rod number to decimal equivelency [Re: 62maxwgn] #1273267
09/12/13 09:18 PM
09/12/13 09:18 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Is it me, or do they have some numbers flipped around on that chart for the 403 and 405?
Re: Carter AFB Metering Rod number to decimal equivelency [Re: BSB67] #1273268
09/12/13 09:40 PM
09/12/13 09:40 PM
Canada
CdnValiant Offline
CdnValiant  Offline
Canada
It's not you...I noticed that too. I've messaged 62maxwgn about it, but haven't rec'd a response yet.
