Cometic Head Gaskets - Aluminum Heads #1272860
07/23/12 07:52 PM
07/23/12 07:52 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Anyone running cometic gaskets with aluminum heads, namely Stealths? Hows it working and whats your compression ratio?
Re: Cometic Head Gaskets - Aluminum Heads [Re: GTX MATT] #1272861
07/23/12 08:07 PM
07/23/12 08:07 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I ran them with a 14.1-1 small block with aluminum heads with 0 issues
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Cometic Head Gaskets - Aluminum Heads [Re: dusturbd340W5] #1272862
07/23/12 08:30 PM
07/23/12 08:30 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
I ran them on my 451. Stock block with B1-BS heads and 12.7:1 compression. Had the heads off multiple times and kept reusing the gaskets. Clean them and coat with copper spray. Never an issue. I'm also using them on my new motor. 540 Mega Block with Ind heads and 13.9:1 compression.
Randy
Re: Cometic Head Gaskets - Aluminum Heads [Re: Dartin] #1272863
07/23/12 08:40 PM
07/23/12 08:40 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
MLS head gaskets are used on just about every new car made anymore. They are the best!
Re: Cometic Head Gaskets - Aluminum Heads [Re: WheelsUp73] #1272864
07/23/12 08:53 PM
07/23/12 08:53 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I'm using the .027 gaskets on mine with Stealth heads. So far ok except one seems to be seeping oil from the driver's side rear. I never heard of that before, but apparently it's not that uncommon. They said to re-torque the head to see if it stops. I haven't done it yet.
Re: Cometic Head Gaskets - Aluminum Heads [Re: WheelsUp73] #1272865
07/23/12 09:34 PM
07/23/12 09:34 PM
Guitar Jones Offline
This is true, but almost every new car made now also uses torque to yield head bolts.
Re: Cometic Head Gaskets - Aluminum Heads [Re: bobs66440] #1272866
07/23/12 09:53 PM
07/23/12 09:53 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
did u spray the gasket with copper coat,high tack
or anything?
Re: Cometic Head Gaskets - Aluminum Heads [Re: BIGSTROKER] #1272867
07/23/12 10:08 PM
07/23/12 10:08 PM
Mo.
racerx Offline
racerx  Offline
Mo.
stockblock....-1's....not a problem with 13.1
Re: Cometic Head Gaskets - Aluminum Heads [Re: GTX MATT] #1272868
07/23/12 10:33 PM
07/23/12 10:33 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Just like the rest, I run Cometics with Stealth heads and a stock block, 440 with 13.6:1 compression. Reused the gaskets 4 or 5 times so far, no problems. Just clean them and spray with copper spray coating.
Brian Dunnigan
Re: Cometic Head Gaskets - Aluminum Heads [Re: '72CudaRacer] #1272869
07/23/12 10:42 PM
07/23/12 10:42 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I run 40" Cometics with Aluminum block and 440-1 heads 13 to one comp two seasons no trouble the best head Gaskets i have run
Re: Cometic Head Gaskets - Aluminum Heads [Re: steeldust] #1272870
07/23/12 11:59 PM
07/23/12 11:59 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I run them with more compression than you would believe and 24lbs of boost.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Cometic Head Gaskets - Aluminum Heads [Re: bigtimeauto] #1272871
07/24/12 02:38 AM
07/24/12 02:38 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Alright sounds good to me! Are you guys using copper spray on the first use of them as well? I probably will, I love that stuff!
Re: Cometic Head Gaskets - Aluminum Heads [Re: GTX MATT] #1272872
07/24/12 08:09 AM
07/24/12 08:09 AM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
I put mine in dry new. Spray copper coat on the second and 3rd go round then toss. The viton seems about used up at this point. I've only used them to 14.25 to 1. Your mileage may vary.
Re: Cometic Head Gaskets - Aluminum Heads [Re: Maximus_Wedges] #1272873
07/24/12 09:44 AM
07/24/12 09:44 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Cometic's or Cooper with o-ringed head gaskets...which are best?
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Cometic Head Gaskets - Aluminum Heads [Re: MRMOPAR622] #1272874
07/24/12 02:43 PM
07/24/12 02:43 PM
Copper head gaskets have thier application, what do you want to use them on? Trying not to hijack this, I have used the Cometic on several applications, reused them also with no spray ever The Nitrile coating will come loose after several applications of reusing them, not sure that the copper spray will replace that
Re: Cometic Head Gaskets - Aluminum Heads [Re: Cab_Burge] #1272875
07/24/12 03:32 PM
07/24/12 03:32 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
I just talked this over with my local machine shop yesterday.
He actually prefers Fel-Pro MLS over Cometics. I didn't even know Fel-Pro made MLS Gaskets? none of his Fel-Pro MLS engines have.
He said he has had a few engines come in with Cometics blown and engine damage. But none of his FelPro MLS engines have had a problem yet. He builds a LOT of roundy-round and drag-race engines.
I mentioned the SCE Copper gaskets; He said they are good BUT you have to have the Receiver Grooves for the O-rings which is another step and head ache not needed with MLS.
Re: Cometic Head Gaskets - Aluminum Heads [Re: DakFink] #1272876
07/24/12 05:12 PM
07/24/12 05:12 PM
I've used several different brands and styles of copper head gaskets on blown street hemi motors. I have also use the SCE brand Titan copper head gaskets on wedges and hemi with no reciever groove with no problems at all on both bracket race motors and street only Hi Po motors The Titan sereis have a stainles steel O ring embedded in the copper and all the water and oil pasages are seal on both sides with embossed Teflon O rings On a new motor I wuld probally use the MLS gaskets and make sure the machine shop gets the proper RA finish done on both the heads and the block
