Cometic Head Gaskets - Aluminum Heads
#1272860
07/23/12 07:52 PM
07/23/12 07:52 PM
Posts: 5,166 CT
GTX MATT
CT
Anyone running cometic gaskets with aluminum heads, namely Stealths? Hows it working and whats your compression ratio?
Re: Cometic Head Gaskets - Aluminum Heads
[Re: GTX MATT]
#1272861
07/23/12 08:07 PM
07/23/12 08:07 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I ran them with a 14.1-1 small block with aluminum heads with 0 issues
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: WheelsUp73]
#1272865
07/23/12 09:34 PM
07/23/12 09:34 PM
Posts: 20,666 in a cattle trailer down by th...
Guitar Jones
MLS head gaskets are used on just about every new car made anymore. They are the best!
This is true, but almost every new car made now also uses torque to yield head bolts.
[Re: steeldust]
#1272870
07/23/12 11:59 PM
07/23/12 11:59 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I run them with more compression than you would believe and 24lbs of boost.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#1272871
07/24/12 02:38 AM
07/24/12 02:38 AM
Posts: 5,166 CT
GTX MATT
CT
Alright sounds good to me! Are you guys using copper spray on the first use of them as well? I probably will, I love that stuff!
[Re: Maximus_Wedges]
#1272873
07/24/12 09:44 AM
07/24/12 09:44 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Cometic's or Cooper with o-ringed head gaskets...which are best?
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: DakFink]
#1272876
07/24/12 05:12 PM
07/24/12 05:12 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
I've used several different brands and styles of copper head gaskets on blown street hemi motors. I have also use the SCE brand Titan copper head gaskets on wedges and hemi with no reciever groove with no problems at all on both bracket race motors and street only Hi Po motors The Titan sereis have a stainles steel O ring embedded in the copper and all the water and oil pasages are seal on both sides with embossed Teflon O rings On a new motor I wuld probally use the MLS gaskets and make sure the machine shop gets the proper RA finish done on both the heads and the block
