Left hand lug studs for a Dana 60 #1269541
07/17/12 02:27 PM
07/17/12 02:27 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
My shop guy is having trouble locating these lug studs for this. He says the lug stud knurl size is 673 measured on the old ones may be slightly larger new.
Does anyone know where to locate these in left hand thread?
believe they are different 8 3/4 to Dana.
Re: Left hand lug studs for a Dana 60 [Re: 696pack] #1269542
07/17/12 02:53 PM
07/17/12 02:53 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Same stud as the8 3/4. Put the right hand studs in. That way a rookie tire guy doesnt break the stud trying to get the nut off. You cant see which way the nuts go on if your worried about the purist look...
I am truckless..
Re: Left hand lug studs for a Dana 60 [Re: 340SHORTY] #1269543
07/17/12 03:53 PM
07/17/12 03:53 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
I have many sets of the chrome factory lug nuts that are left hand thread.
Re: Left hand lug studs for a Dana 60 [Re: 696pack] #1269544
07/17/12 10:59 PM
07/17/12 10:59 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Good luck finding them, they went out of production years ago and once the stock was sold out that was it.
Darryl , did you just fall off the turnip truck ? This subject has been covered more than once , or were you too busy defending FRAUD to notice ???
Re: Left hand lug studs for a Dana 60 [Re: JohnRR] #1269545
07/18/12 12:18 AM
07/18/12 12:18 AM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
It was my understanding that they were still available from some source or that there was a stockpile of them available somewhere.
Re: Left hand lug studs for a Dana 60 [Re: 696pack] #1269546
07/18/12 03:09 AM
07/18/12 03:09 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Reproduction LH wheel studs are available.
http://www.apexautosports.com/store/
Re: Left hand lug studs for a Dana 60 [Re: DoctorDiff] #1269547
07/18/12 09:19 AM
07/18/12 09:19 AM
JohnRR Offline
JohnRR  Offline
Re: Left hand lug studs for a Dana 60 [Re: DoctorDiff] #1269548
07/18/12 09:48 AM
07/18/12 09:48 AM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Thanks.
Re: Left hand lug studs for a Dana 60 *DELETED* *DELETED* *DELETED* *DELETED* *DELETED* *DELETED* *DELETED* [Re: JohnRR] #1269549
07/18/12 10:26 AM
07/18/12 10:26 AM
central,pa
P
ply64post Offline
ply64post  Offline
P
central,pa
Post deleted by ply64post
Re: Left hand lug studs for a Dana 60 [Re: ply64post] #1269550
07/18/12 11:23 AM
07/18/12 11:23 AM
JohnRR Offline
JohnRR  Offline
Was that really necessary ??
That was tame , you should have seen what hit the cutting room floor
Re: Left hand lug studs for a Dana 60 [Re: JohnRR] #1269551
07/18/12 12:13 PM
07/18/12 12:13 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
It fell on deaf ears.
Re: Left hand lug studs for a Dana 60 [Re: DoctorDiff] #1269552
07/18/12 12:23 PM
07/18/12 12:23 PM
USA
b54406barrel Offline
USA
That's great news. I was down to 2 for a drum, 'b'.
Re: Left hand lug studs for a Dana 60 [Re: 340SHORTY] #1269553
02/19/13 08:08 PM
02/19/13 08:08 PM
Northeast
edl Offline
edl  Offline
Northeast
if one wanted to go right hand, what is the correct part for a '66 belvedere 11" drum - 1/2" by 20 thread? - thanks
p.s. have tried apex a couple of times...haven't gotten through yet...
Re: Left hand lug studs for a Dana 60 [Re: edl] #1269554
02/20/13 10:57 AM
02/20/13 10:57 AM
JohnRR Offline
JohnRR  Offline
Yes it's 1/2-20 , dorman part number 610-103.1
the goods
Re: Left hand lug studs for a Dana 60 [Re: JohnRR] #1269555
02/20/13 11:37 AM
02/20/13 11:37 AM
Northeast
edl Offline
edl  Offline
Northeast
Many thanks, John
One aside: in the "Application Notes" it says -
Application Notes:
Rear; Right Hand Thread
would this part work equally well for the front (which is what i need)?
thanks
Re: Left hand lug studs for a Dana 60 [Re: edl] #1269556
02/20/13 12:12 PM
02/20/13 12:12 PM
JohnRR Offline
JohnRR  Offline
Many thanks, John
Application Notes:
thanks
No , the front is different , here is the application page from Dorman , there are 2 knurl sizes , pop one out of the front and measure it and pick the one it needs ...
610-132.1 with a .650 for motor wheel drums and hubs
98147 is a .625 knurl for kelsey hayes drums and hubs
the page
Also make note that front lugs are swaged on , you want to grind off the swage before driving it out or you risk damaging the drum and hub hole .
Re: Left hand lug studs for a Dana 60 [Re: JohnRR] #1269557
02/20/13 12:46 PM
02/20/13 12:46 PM
Northeast
edl Offline
edl  Offline
Northeast
fantastic, John - thank you
Re: Left hand lug studs for a Dana 60 [Re: edl] #1269558
02/20/13 03:19 PM
02/20/13 03:19 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree with JohnRR on the fronts.Had one guy try to take them out without cutting the swedge.Hub ruined.We used to have the setup at work to remove and install them with the swedge.Wish I had got them when the closed the shop and scraped it all.Rocky
Chrysler Firepower
Re: Left hand lug studs for a Dana 60 [Re: therocks] #1269559
02/20/13 04:08 PM
02/20/13 04:08 PM
Northeast
edl Offline
edl  Offline
Northeast
thanks Rocky
Re: Left hand lug studs for a Dana 60 [Re: JohnRR] #1269560
02/20/13 04:20 PM
02/20/13 04:20 PM
North Pole,New York
formula_s Online content
formula_s  Online Content
North Pole,New York
Anyone know where to find blank Broadcast Sheets ?
