Re: Left hand lug studs for a Dana 60
[Re: 696pack]
#1269542
07/17/12 02:53 PM
07/17/12 02:53 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Same stud as the8 3/4. Put the right hand studs in. That way a rookie tire guy doesnt break the stud trying to get the nut off. You cant see which way the nuts go on if your worried about the purist look...
I am truckless..
[Re: 696pack]
#1269544
07/17/12 10:59 PM
07/17/12 10:59 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
I have many sets of the chrome factory lug nuts that are left hand thread.
Good luck finding them, they went out of production years ago and once the stock was sold out that was it.
Darryl , did you just fall off the turnip truck ? This subject has been covered more than once , or were you too busy defending FRAUD to notice ???
[Re: DoctorDiff]
#1269548
07/18/12 09:48 AM
07/18/12 09:48 AM
Posts: 511 AZ.
696pack
AZ.
[Re: ply64post]
#1269550
07/18/12 11:23 AM
07/18/12 11:23 AM
JohnRR
Was that really necessary ??
That was tame , you should have seen what hit the cutting room floor ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: JohnRR]
#1269551
07/18/12 12:13 PM
07/18/12 12:13 PM
Posts: 511 AZ.
696pack
AZ.
[Re: 340SHORTY]
#1269553
02/19/13 08:08 PM
02/19/13 08:08 PM
Posts: 331 Northeast
edl
Northeast
if one wanted to go right hand, what is the correct part for a '66 belvedere 11" drum - 1/2" by 20 thread? - thanks
p.s. have tried apex a couple of times...haven't gotten through yet...
[Re: edl]
#1269556
02/20/13 12:12 PM
02/20/13 12:12 PM
JohnRR
Many thanks, John
One aside: in the "Application Notes" it says -
Application Notes: Rear; Right Hand Thread
would this part work equally well for the front (which is what i need)?
thanks
No , the front is different , here is the application page from Dorman , there are 2 knurl sizes , pop one out of the front and measure it and pick the one it needs ...
610-132.1 with a .650 for motor wheel drums and hubs
98147 is a .625 knurl for kelsey hayes drums and hubs
the page
Also make note that front lugs are swaged on , you want to grind off the swage before driving it out or you risk damaging the drum and hub hole .
[Re: edl]
#1269558
02/20/13 03:19 PM
02/20/13 03:19 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I agree with JohnRR on the fronts.Had one guy try to take them out without cutting the swedge.Hub ruined.We used to have the setup at work to remove and install them with the swedge.Wish I had got them when the closed the shop and scraped it all.Rocky
Chrysler Firepower
[Re: JohnRR]
#1269560
02/20/13 04:20 PM
02/20/13 04:20 PM
Posts: 4,999 North Pole,New York
formula_s
North Pole,New York
Anyone know where to find blank Broadcast Sheets ?
