451 Camshaft Questian #1268822
07/16/12 04:30 PM
07/16/12 04:30 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
Guy's I Am Putting Together A Low Deck 451 For Mostly Street Car, And Am Getting Ready To Decide What Camshaft That I Want. I Am Wanting Good Power But Not Something Too Terribly Rough Of An Idle. Every Body Says That With A Stroker You Can Get Away With Much More Duration, But Would That Count For A 451? Isn't It Just Basically A 440?
Re: 451 Camshaft Questian [Re: titan] #1268823
07/16/12 05:43 PM
07/16/12 05:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
WAY too many variables............weight, heads,gears comp. etc. but when in doubt a good ol .480-.500 lift cam w/230-235 dur. @ .050 has always got the job done for me on mild combos.
Re: 451 Camshaft Questian [Re: Thumperdart] #1268824
07/16/12 06:23 PM
07/16/12 06:23 PM
Renton Washington
Triple Threat Offline
Renton Washington
I agree with Thumper, for the best answer we need more information. Do you have any goals for the car? HP or ET wise? What is the rest of the combination?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 451 Camshaft Questian [Re: Triple Threat] #1268825
07/16/12 07:24 PM
07/16/12 07:24 PM
dogdays Offline
dogdays  Offline
Well basically you have a 440 with a bit shorter intake runners. It isn't a stroker except compared to a 383/400. So anything that would work for a 440 will work for your 451.
I'd say the Lunati Voodoo cam in the middle of the series would be about right. Something like the Comp XE268.
R.
Re: 451 Camshaft Questian [Re: dogdays] #1268826
07/16/12 07:33 PM
07/16/12 07:33 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
there are some variables here but the big one is; do you want to drive the car a bunch? i've got a 440 in my 65 coronet, good heads, 6-pak, torqueflite, 3.23 rear, 9.3:1 compression. it has an engle k65 solid; 238@.050-.510 lift. it's all the cam i want. it's got a little rumble, would probably have a little more "pop" with 10 or 10.5 compression. doesn't need much converter. low maintenance, easy break-in, and makes enough power for my old butt.
Re: 451 Camshaft Questian [Re: lewtot184] #1268827
07/16/12 07:37 PM
07/16/12 07:37 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Do you care if it is solid or hydraulic ? Or flat tappet or roller ? Ron
Re: 451 Camshaft Questian [Re: titan] #1268828
07/16/12 08:36 PM
07/16/12 08:36 PM
AndyF Offline
AndyF  Offline
The Mopar .528 solid works really well in that size of engine. It has a fairly smooth idle but it will pull hard up past 6000 rpm.
Re: 451 Camshaft Questian [Re: AndyF] #1268829
07/16/12 09:03 PM
07/16/12 09:03 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
That's The Cam I Was Planning On Using. Thanks
Re: 451 Camshaft Questian [Re: titan] #1268830
07/16/12 11:21 PM
07/16/12 11:21 PM
AndyF Offline
AndyF  Offline
I've done a fair amount of camshaft testing over the years. The articles are on my website in the tech article section.
www.arengineering.com is the address. I also covered the topic in my big block book.
Re: 451 Camshaft Questian [Re: titan] #1268831
07/17/12 01:59 AM
07/17/12 01:59 AM
New York
polyspheric Offline
polyspheric  Offline
New York
It's not a 440 unless you're using RB rods.
Boffin Emeritus
Re: 451 Camshaft Questian [Re: polyspheric] #1268832
07/17/12 12:43 PM
07/17/12 12:43 PM
dogdays Offline
dogdays  Offline
And most modern 451s do.....
R.
Re: 451 Camshaft Questian [Re: polyspheric] #1268833
07/17/12 05:08 PM
07/17/12 05:08 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Not sure if serious.....
Re: 451 Camshaft Questian [Re: Skeptic] #1268834
07/17/12 07:16 PM
07/17/12 07:16 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
if i build a 451 it will be short rods.
it has been said the longer rods seem laiser to the 60ft
than the shorter ones...
i am going to find out.
Re: 451 Camshaft Questian [Re: dmking] #1268835
07/17/12 07:21 PM
07/17/12 07:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
Its has been said many things by many people over the years,some of them are wrong, some of them are even Mopar guys The longer rod will help relieve cylinder wall stress and help you run a lighter piston, light is right Lightweight crank assemblys accelerate and slow down quicker also
Re: 451 Camshaft Questian [Re: titan] #1268836
07/17/12 07:53 PM
07/17/12 07:53 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
The next 451 I build will have a 383 rod in it. Thats still a 1.75 L/R (440 rod has 1.80 L/R) That way, you dont have the wrist pin penetrating the oil ring land.
I use a 214/224 on a 114 for my street car. Really happy with it.
Its similar to a 300HP/327 chevy grind from the 60's. I got it from Crane. Dont know if you can get it anymore though.
8.30's @3400 lbs
Re: 451 Camshaft Questian [Re: Mike Swann] #1268837
07/17/12 08:03 PM
07/17/12 08:03 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I just did my 451 with the 383/400 rod. I run the Racer Brown SSH/44
with 244* @.050. I've used this cam before in a 440 and it runs real
good on a street car with a 3500ish converter and a set of 3.55'-
4.10s in the back. The pistons are lighter than the ones made
for the stock stroke.
Re: 451 Camshaft Questian [Re: titan] #1268838
07/17/12 08:04 PM
07/17/12 08:04 PM
snook Offline
snook  Offline
Old school mopar 557 solid cam. Perfect for a street driven 451.
Re: 451 Camshaft Questian [Re: Skeptic] #1268839
07/17/12 08:43 PM
07/17/12 08:43 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Yes.
Why?
Boffin Emeritus
Re: 451 Camshaft Questian [Re: polyspheric] #1268840
07/17/12 09:43 PM
07/17/12 09:43 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Yes.
Why?
Rod Length has nothing to do with displacement
