Re: 451 Camshaft Questian
[Re: Thumperdart]
#1268824
07/16/12 06:23 PM
07/16/12 06:23 PM
Triple Threat
Renton Washington
I agree with Thumper, for the best answer we need more information. Do you have any goals for the car? HP or ET wise? What is the rest of the combination?
[Re: dogdays]
#1268826
07/16/12 07:33 PM
07/16/12 07:33 PM
Posts: 3,916 usa
lewtot184
usa
there are some variables here but the big one is; do you want to drive the car a bunch? i've got a 440 in my 65 coronet, good heads, 6-pak, torqueflite, 3.23 rear, 9.3:1 compression. it has an engle k65 solid; 238@.050-.510 lift. it's all the cam i want. it's got a little rumble, would probably have a little more "pop" with 10 or 10.5 compression. doesn't need much converter. low maintenance, easy break-in, and makes enough power for my old butt.
[Re: AndyF]
#1268829
07/16/12 09:03 PM
07/16/12 09:03 PM
Posts: 192 central Florida
titan
central Florida
The Mopar .528 solid works really well in that size of engine. It has a fairly smooth idle but it will pull hard up past 6000 rpm.
That's The Cam I Was Planning On Using. Thanks
[Re: titan]
#1268830
07/16/12 11:21 PM
07/16/12 11:21 PM
Posts: 31,043 Oregon
AndyF
I've done a fair amount of camshaft testing over the years. The articles are on my website in the tech article section. www.arengineering.com is the address. I also covered the topic in my big block book.
[Re: titan]
#1268831
07/17/12 01:59 AM
07/17/12 01:59 AM
Posts: 4,206 New York
polyspheric
New York
It's not a 440 unless you're using RB rods.
Boffin Emeritus
[Re: titan]
#1268836
07/17/12 07:53 PM
07/17/12 07:53 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
The next 451 I build will have a 383 rod in it. Thats still a 1.75 L/R (440 rod has 1.80 L/R) That way, you dont have the wrist pin penetrating the oil ring land.
I use a 214/224 on a 114 for my street car. Really happy with it.
Its similar to a 300HP/327 chevy grind from the 60's. I got it from Crane. Dont know if you can get it anymore though.
8.30's @3400 lbs
