i think my sprag went....Update With Pic. #1268545
07/15/12 10:15 PM
07/15/12 10:15 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Last season I had some valve body issues and corrected that with a manual Turbo action cheetah unit.
Today I get to the second round start the burnout and roll out in third gear. Get the car staged and take off. Then about 50 feet out it I get a bad chatter in first gear. I shifted to second and feels fine.
By that time I know the run is junk so shifted to third and back to the trailer.
Got home and drove it in the garage and in first and make ugly sounds really not looking forward to pulling the trans but...
I think the sprag took a dump what do you think?
Is it possible that it got hurt during the burnout?
Re: i think my sprag went.... [Re: Todd] #1268546
07/15/12 10:28 PM
07/15/12 10:28 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Sounds like to me , i think your correct.....have broken three in my years...fnally put in copes low band applie valve body and A&A sprag.no more issues pat
Re: i think my sprag went.... [Re: Todd] #1268547
07/15/12 10:35 PM
07/15/12 10:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just by chance... check the band to see if its
real loose
Re: i think my sprag went.... [Re: MR_P_BODY] #1268548
07/15/12 11:19 PM
07/15/12 11:19 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Thats what I was afraid of. I'm gonna drop the pan tommorrow see what I can find.
Here is a video of the Dash for cash race before eliminations started.
http://www.youtube.com/watch?v=0JkO-mC-GA8&feature=plcp
Re: i think my sprag went.... [Re: Todd] #1268549
07/16/12 10:58 AM
07/16/12 10:58 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Nice car If it the sprag do yourself a favor and get the sprag with more rollers. I put one in 3 years ago and no problems but I am very carefull about burnouts too.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: i think my sprag went.... [Re: slippery440] #1268550
07/16/12 01:31 PM
07/16/12 01:31 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
A few years ago when the trans was built we put a sprag in with all the extra rollers.
In the video that was 2 runs prior to Didn't get any video of when it happend.
Re: i think my sprag went.... [Re: Todd] #1268551
07/16/12 01:52 PM
07/16/12 01:52 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
with drive shaft disconnected transmission in neutral try turning the end to the right then left if it turns easy in both directions i would think the sprag is shot. if you have an spare slip yoke use that to turn it or the drive shaft itself
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: i think my sprag went.... [Re: Todd] #1268552
07/16/12 01:54 PM
07/16/12 01:54 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Is it possibe to make the valve body that I have a low band apply? IIRC the one thats in there now is a 17676. Manual forward pattern.
Re: i think my sprag went.... [Re: Todd] #1268553
07/17/12 09:14 AM
07/17/12 09:14 AM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Pulled the pan and found what looks like ground up springs out of the sprag.
Re: i think my sprag went.... [Re: Todd] #1268554
07/17/12 09:29 AM
07/17/12 09:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats what it looks like.... well its time to pull
the trans.... bummer
Re: i think my sprag went.... [Re: MR_P_BODY] #1268555
07/17/12 01:08 PM
07/17/12 01:08 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
I started on it last night gonna finish tonight after work then off to the trans guy. How much of that stuff got in the converter?
Re: i think my sprag went.... [Re: MR_P_BODY] #1268556
07/17/12 01:14 PM
07/17/12 01:14 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
I started to pull it last night probibly finish tonight after work. How much of that stuff got in the converter?
Re: i think my sprag went.... [Re: Todd] #1268557
07/17/12 02:20 PM
07/17/12 02:20 PM
Probally none, as long as you have a filter or screen on the valve body It's awfully hard for pieces that big to get suck through the filter
Re: i think my sprag went.... [Re: Todd] #1268558
07/17/12 03:54 PM
07/17/12 03:54 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
Nice car. I think that is my Dad's old chevelle in the other lane. Good luck with the transmission
Re: i think my sprag went.... [Re: mopar400] #1268559
07/17/12 07:34 PM
07/17/12 07:34 PM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
turbo action converted several of my 17676 valve bodies to low band apply several years back ... i think that part number was 17680. I see they don't show them on their website now so maybe they won't do it anymore.
Howard
Re: i think my sprag went.... [Re: mopar400] #1268560
07/17/12 08:12 PM
07/17/12 08:12 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Thanks. There is a lot of nice rides there.
I'm probably going to keep the same valve body. Just makes me wonder about the old one that was a homemade manual that I tried and never seemed to shift right may have damaged the spag then.
Well its not coming out tonight. Its too hot. Went swimming with the kids instead.
Re: i think my sprag went.... [Re: Todd] #1268561
07/18/12 01:26 AM
07/18/12 01:26 AM
Oh
His and Her 69's Offline
Oh
Make Sure you rinse out your tranny lines and cooler Good.
I always rinse them out after a trans issue just to be safe.
Just an FYI
David
Re: i think my sprag went.... [Re: Todd] #1268562
07/18/12 10:18 AM
07/18/12 10:18 AM
NC
440Jim Offline
440Jim  Offline
NC
So the trans already has either the A&A Ultimate sprag or the Coan Super sprag with 16 rollers? (vs the 12 roller Chryser).
It is likely that the valve body can be changed to low band apply, check with John Cope at CRT. He has done some in the past, but not all valve bodies can be changed.
Re: i think my sprag went....found stuff in pan... [Re: Todd] #1268563
07/18/12 10:33 AM
07/18/12 10:33 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....so are we sure the t/a valve body "corrected" the issue you were having? You just don't hear of this issue much with their manual valve body being used. I know I never had issues with mine. Too bad I don't live near you. Sold my race car, but still have the "back up" trans sitting here which I used for years prior to going full race trans. It has a TA valve body and I never had sprag issues.
Re: i think my sprag went....found stuff in pan... [Re: J_BODY] #1268564
07/18/12 11:07 AM
07/18/12 11:07 AM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Thanks for the offer. The prior valve body was a homemade manual one that a buddy had laying around let me try. Some times it it would work fine and the next pass wouldnt leave in first gear.
After changing to the turbo action unit been fine. Its got around 30 passes on this one with no problems until now.
