Page 1 of 6 1 2 3 4 5 6
440, 4-speed, A/C ? #1268413
07/15/12 09:39 PM
07/15/12 09:39 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
I don't remember if I have ever seen a GTX or R/T with a 4 speed and A/C. Did they make such animals?
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: 440, 4-speed, A/C ? [Re: 6T9Hemi] #1268414
07/15/12 09:57 PM
07/15/12 09:57 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
No 440-4 with 4 speed and A/C in a B or E body.
IIRC, A/C may have been available in 67 or 68 C-bodies with 440-4 and 4spd ???
Re: 440, 4-speed, A/C ? [Re: autoxcuda] #1268415
07/16/12 08:47 AM
07/16/12 08:47 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
No. Auto transmission only.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 440, 4-speed, A/C ? [Re: 69CoronetRT] #1268416
07/16/12 02:34 PM
07/16/12 02:34 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks.
In 64-66 426 or 413 with a 4spd in a C or B body availible with A/C?
Re: 440, 4-speed, A/C ? [Re: autoxcuda] #1268417
07/16/12 05:59 PM
07/16/12 05:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I don't think so. I *thought* the issue was that they didn't think the a/c compressor at the time would withstand the rpm you would be turning with a stick car wound out.
Re: 440, 4-speed, A/C ? [Re: DaytonaTurbo] #1268418
07/16/12 06:17 PM
07/16/12 06:17 PM
Alabama
BigMoneyLewis Offline
Alabama
It had alot to do with the fact that a 440 4spd car is going to be a dana car, so you will have at least a 3:54 gear (if not a 4:10)
With the 383 4-speed cars , A/C was available as most were 3:23
Greg
gregward@mchsi.com phone 256-852-0955
Re: 440, 4-speed, A/C ? [Re: BigMoneyLewis] #1268419
07/16/12 07:23 PM
07/16/12 07:23 PM
Castlegar, BC, Canada
That AMC Guy Offline
Could it have been special ordered? A friend of mine has a '69 440/4speed R/T SE and it's LOADED. Power Windows, Seat, Am/8track, Tach, Console, Hood Indicators, Power Discs, Wood Wheel, and yes, factory A/C. It's even a #'s matching car.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: 440, 4-speed, A/C ? [Re: That AMC Guy] #1268420
07/16/12 07:28 PM
07/16/12 07:28 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I call BS! ..... NO - ZERO - NONE exist!! Bring on the proof of a factory built car with a 440, 4-spd manual transmission and A/C.
Re: 440, 4-speed, A/C ? [Re: 6bblgt] #1268421
07/17/12 02:46 AM
07/17/12 02:46 AM
I'll look into it. He's had the car 20+ years and as long as he's had it, it's been a 4 speed. Might have been switched over the years. Whats fender tag code for 727? D34?
Re: 440, 4-speed, A/C ? [Re: That AMC Guy] #1268422
07/17/12 03:00 AM
07/17/12 03:00 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
special ordered Y39
440 E86
4speed D21
R/T XS29L9
SE A47
Power Windows P31
Seat C62
Am/8track R22
Tach N85
Console C16
Hood Indicators L31
Power Discs B41 & B51
Wood Wheel S81
A/C H51
automatic transmission D32
Re: 440, 4-speed, A/C ? [Re: 6bblgt] #1268423
07/17/12 03:12 AM
07/17/12 03:12 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 440, 4-speed, A/C ? [Re: 6T9Hemi] #1268424
07/17/12 08:30 AM
07/17/12 08:30 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I guess I can stop looking for one then....
Re: 440, 4-speed, A/C ? [Re: Commando1] #1268425
07/17/12 12:48 PM
07/17/12 12:48 PM
Oklahoma
V
VoodooCLD Offline
VoodooCLD  Offline
V
Oklahoma
What was their reasoning for such? I plan on building my 73 challenger to those exact specs. 440, 4 speed, and a/c. Why wouldn't they do it?
Sounds like the ultimate ride to me.
Re: 440, 4-speed, A/C ? [Re: VoodooCLD] #1268426
07/17/12 01:31 PM
07/17/12 01:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Go up and read Daytona turbos post.
Re: 440, 4-speed, A/C ? [Re: VoodooCLD] #1268427
07/17/12 01:32 PM
07/17/12 01:32 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
As I understand, and it wasn't just Chrysler, A/C compressors and axle ratios over about 3.23 were verboten. It had more to do with RPM's than anything else I know of. I would guess the new compressors can take more RPM's than the old ones? Build what you like!
As for C bodies from '67 to '68, they had Dana 53's with 4 speeds, I'm not familiar with the axle ratios available for them.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 440, 4-speed, A/C ? [Re: 3hundred] #1268428
07/17/12 02:12 PM
07/17/12 02:12 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Greg
You could get A/C with 3.55 gears so I'm not sure the rear end ratio was the sole reason.
Re: 440, 4-speed, A/C ? [Re: That AMC Guy] #1268429
07/17/12 02:40 PM
07/17/12 02:40 PM
AZ.
696pack Offline
696pack  Offline
AZ.
This is the second case I have heard of it. I have never seen one in person but don't doubt there may have been a few built. It likely would have been at the request of a high level factory executive that wanted one for themselves. They got what they wanted even if they would not built one for the public. Certainly all of the components were factory assembly line readily available so it would not be a big deal to do.
If the car has a broadcast sheet that will tell you if it was factory built.
Re: 440, 4-speed, A/C ? [Re: 696pack] #1268430
07/17/12 03:30 PM
07/17/12 03:30 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
...and until or unless said FT, BS or other document surfaces, then the right answer is "not available".
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 440, 4-speed, A/C ? [Re: DPelletier] #1268431
07/17/12 03:49 PM
07/17/12 03:49 PM
AZ.
696pack Offline
696pack  Offline
AZ.
No, the right answer is not available in the autorized dealer order guide.
Anything like this was available from any auto manufacturer if you were the right person.
Re: 440, 4-speed, A/C ? [Re: 696pack] #1268432
07/17/12 04:50 PM
07/17/12 04:50 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'Anything like this was available from any auto manufacturer if you were the right person.'
Bullseye...
We've talked to enough folks from Lynch Road, and Hamtramck to know this as fact...
