4 speed E-body, what is this and where can I buy one?
#1268391
07/15/12 09:30 PM
07/15/12 09:30 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
4 speed E-body. This is the the rubber access cover the goes over the hole where the end of the Z-bar bolts to the frame. It is located inside the driver's side front wheel well. What is it called and where can I buy one including the clips? Thanks. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: 4 speed E-body, what is this and where can I buy one?
[Re: KillerBee]
#1268392
07/15/12 10:35 PM
07/15/12 10:35 PM
Posts: 4,872 connecticut
pnypwr
connecticut
thats the alignment access cover...all the resto places have them
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: pnypwr]
#1268393
07/15/12 10:55 PM
07/15/12 10:55 PM
KillerBee
N.E. Ohio
Hmmm ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) This cover is located a fair bit behind any steering, suspension or alignment parts, I don't think you would be accessing those parts from under the cover. This cover is over just the area where the clutch Z-bar comes off the ball stud on the bellhousing and bolts to the frame and clutch adjusting rod. ![](/ubbthreads/images/graemlins/scope.gif)
[Re: KillerBee]
#1268394
07/15/12 11:01 PM
07/15/12 11:01 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
It's still the alignment access cover & personally I'd but it from Jim Filmore AKA 71 TA AKA DMT
[Re: 1_WILD_RT]
#1268395
07/15/12 11:09 PM
07/15/12 11:09 PM
KillerBee
N.E. Ohio
This attaches to the frame, no where near the front suspension.
Anyone got a picture of an alignment access cover in the car?
[Re: RoadRunner]
#1268397
07/15/12 11:19 PM
07/15/12 11:19 PM
KillerBee
N.E. Ohio
Its so you can access the upper control arm bolts. The opening is large enough to also access the ball joint. B bodies have a similar cover.
Found them. They are not located anywhere near the upper control arms or the inner fenders where they bolt to.
This is further back right over where the z bar bolts to the frame.
They are called splash shields and where they are located you couldn't get near any alignment parts. http://www.ebay.com/itm/DMT-70-E-Body-Sp...ies&vxp=mtr
[Re: KillerBee]
#1268398
07/15/12 11:34 PM
07/15/12 11:34 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Have you ever done alignment work? When adjusting the caster/camber your loosening the lock nuts on the upper control arm eccentrics from the wheel well & adjusting the eccentrics to set caster/camber... If you reach your hand in through the wheel well you'll find the locknut is about 3" ahead of the opening & is easily accessed with a ratchet & a deep socket... If it were for clutch access why it there one on the passenger side?
[Re: 1_WILD_RT]
#1268399
07/15/12 11:41 PM
07/15/12 11:41 PM
KillerBee
N.E. Ohio
LOL my wife thinks I'm nuts, just went out and took some Iphone pics, thankfully the car is up on my lift.
Is this the area you are speaking of, it is located on the frame behind the front tire on the drivers side?
I Googled "Mopar alignment access cover" in multiple variations and didn't find it, splash shield got many hits for mudflaps. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: KillerBee]
#1268401
07/15/12 11:59 PM
07/15/12 11:59 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Yep that picture shows the aliment adjustment hole
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: KillerBee]
#1268402
07/16/12 12:02 AM
07/16/12 12:02 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Reach through the hole & forward & see what you find.....
[Re: KillerBee]
#1268404
07/16/12 10:46 AM
07/16/12 10:46 AM
Posts: 39 AR
70_roadrunner
AR
It's funny how people will ask a question then argue with you when you give them an answer.
[Re: 70_roadrunner]
#1268405
07/16/12 11:09 AM
07/16/12 11:09 AM
Challenger 1
Cincinnati, Ohio
Exspecially when 1 Wild RT post the answer to your question, he's rarely wrong. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 70_roadrunner]
#1268406
07/16/12 11:42 AM
07/16/12 11:42 AM
KillerBee
N.E. Ohio
The answer I got didn't make sense, so I asked more questions and researched it myself.
I'm thankful to have people on this board who can help ![](/ubbthreads/images/graemlins/thumbs.gif)
