4 speed E-body, what is this and where can I buy one? #1268391
07/15/12 09:30 PM
07/15/12 09:30 PM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
4 speed E-body.
This is the the rubber access cover the goes over the hole where the end of the Z-bar bolts to the frame.
It is located inside the driver's side front wheel well.
What is it called and where can I buy one including the clips?
Thanks.
Re: 4 speed E-body, what is this and where can I buy one? [Re: KillerBee] #1268392
07/15/12 10:35 PM
07/15/12 10:35 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
thats the alignment access cover...all the resto places have them
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: 4 speed E-body, what is this and where can I buy one? [Re: pnypwr] #1268393
07/15/12 10:55 PM
07/15/12 10:55 PM
N.E. Ohio
K
K
N.E. Ohio
Hmmm
This cover is located a fair bit behind any steering, suspension or alignment parts, I don't think you would be accessing those parts from under the cover.
This cover is over just the area where the clutch Z-bar comes off the ball stud on the bellhousing and bolts to the frame and clutch adjusting rod.
Re: 4 speed E-body, what is this and where can I buy one? [Re: KillerBee] #1268394
07/15/12 11:01 PM
07/15/12 11:01 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It's still the alignment access cover & personally I'd but it from Jim Filmore AKA 71 TA AKA DMT
Re: 4 speed E-body, what is this and where can I buy one? [Re: 1_WILD_RT] #1268395
07/15/12 11:09 PM
07/15/12 11:09 PM
N.E. Ohio
K
K
N.E. Ohio
This attaches to the frame, no where near the front suspension.
Anyone got a picture of an alignment access cover in the car?
Re: 4 speed E-body, what is this and where can I buy one? [Re: KillerBee] #1268396
07/15/12 11:14 PM
07/15/12 11:14 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Its so you can access the upper control arm bolts. The opening is large enough to also access the ball joint. B bodies have a similar cover.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 4 speed E-body, what is this and where can I buy one? [Re: RoadRunner] #1268397
07/15/12 11:19 PM
07/15/12 11:19 PM
N.E. Ohio
K
K
N.E. Ohio
Found them.
They are not located anywhere near the upper control arms or the inner fenders where they bolt to.
This is further back right over where the z bar bolts to the frame.
They are called splash shields and where they are located you couldn't get near any alignment parts.
http://www.ebay.com/itm/DMT-70-E-Body-Sp...ies&vxp=mtr
Re: 4 speed E-body, what is this and where can I buy one? [Re: KillerBee] #1268398
07/15/12 11:34 PM
07/15/12 11:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Have you ever done alignment work? When adjusting the caster/camber your loosening the lock nuts on the upper control arm eccentrics from the wheel well & adjusting the eccentrics to set caster/camber... If you reach your hand in through the wheel well you'll find the locknut is about 3" ahead of the opening & is easily accessed with a ratchet & a deep socket... If it were for clutch access why it there one on the passenger side?
Re: 4 speed E-body, what is this and where can I buy one? [Re: 1_WILD_RT] #1268399
07/15/12 11:41 PM
07/15/12 11:41 PM
N.E. Ohio
K
K
N.E. Ohio
LOL my wife thinks I'm nuts, just went out and took some Iphone pics, thankfully the car is up on my lift.
Is this the area you are speaking of, it is located on the frame behind the front tire on the drivers side?
I Googled "Mopar alignment access cover" in multiple variations and didn't find it, splash shield got many hits for mudflaps.
Re: 4 speed E-body, what is this and where can I buy one? [Re: KillerBee] #1268400
07/15/12 11:57 PM
07/15/12 11:57 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
Think R/T Specialties has them.
R/T web page
What was I thinking....
Re: 4 speed E-body, what is this and where can I buy one? [Re: KillerBee] #1268401
07/15/12 11:59 PM
07/15/12 11:59 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Yep that picture shows the aliment adjustment hole
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 4 speed E-body, what is this and where can I buy one? [Re: KillerBee] #1268402
07/16/12 12:02 AM
07/16/12 12:02 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Reach through the hole & forward & see what you find.....
Re: 4 speed E-body, what is this and where can I buy one? [Re: 1_WILD_RT] #1268403
07/16/12 01:42 AM
07/16/12 01:42 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
That rubber flap is the same part manual trans and auto trans.
See those upper control arm adjusters on the front of the shock tower? well there are the same adjusters on the rear of the shock tower, you can adjust your alighment that way.
Re: 4 speed E-body, what is this and where can I buy one? [Re: KillerBee] #1268404
07/16/12 10:46 AM
07/16/12 10:46 AM
AR
70_roadrunner Offline
AR
It's funny how people will ask a question then argue with you when you give them an answer.
Re: 4 speed E-body, what is this and where can I buy one? [Re: 70_roadrunner] #1268405
07/16/12 11:09 AM
07/16/12 11:09 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Exspecially when 1 Wild RT post the answer to your question, he's rarely wrong.
Re: 4 speed E-body, what is this and where can I buy one? [Re: 70_roadrunner] #1268406
07/16/12 11:42 AM
07/16/12 11:42 AM
N.E. Ohio
K
K
N.E. Ohio
The answer I got didn't make sense, so I asked more questions and researched it myself.
I'm thankful to have people on this board who can help
Re: 4 speed E-body, what is this and where can I buy one? [Re: KillerBee] #1268407
07/16/12 08:40 PM
07/16/12 08:40 PM
Cincinnati, Ohio
Cincinnati, Ohio
Just happen to have a set in stock ready for my next car.
