MuuMuu's 68 Dart... It's a Learning Process...
#1267239
07/14/12 02:53 AM
07/14/12 02:53 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Re: MuuMuu's 68 Dart... It's a Learning Process...
[Re: MuuMuu101]
#1267242
07/14/12 03:52 AM
07/14/12 03:52 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
These are the goals I have for the project.
Now: Fix, Maintain, Drive, and Enjoy. There are little things that need to be fixed on the car to make it better. For instance the driver door is not original to the car and wasn't aligned when bought. I need to clean the rust in the trunk. I obviously need to replace the power steering hose after it blew up Tuesday turning into my garage. I need to fix the locks and probably add a kill switch. And other little things.
Short term: Disc brake, bigger rear end, and slightly bigger wheels and tires all in big bolt pattern. Subframe connectors. Upgrade/redo the audio (have a Sony player in the glove compartment with upgraded speakers). Fix the AC (I think someone exhanged the AC for power steering since the car isn't coded for PS but is for AC and it still has some Ac components).
Long term: Upgraded engine (I am thinking 3rd Gen Hemi or a turbo charged efi small block), T56 manual, new paint job (probably silver or blue), 18" wheels, big brakes, update the suspension (thinking Hotchkis TVS), upgraded interior, side exit exhaust, etc.
[Re: MuuMuu101]
#1267243
07/14/12 04:05 AM
07/14/12 04:05 AM
Posts: 27,465 So Cal
autoxcuda
So Cal
Is it not shutting right? Or does it just not look aligned?
Just use a brush and vacuum up the loose stuff. Then castrol super clean and rag and water to clean the dirt.
Was it the pressure or return hose? Did you get the hose yet?
What's wrong with the locks?
Why do you need a kill switch? Should be last on the list. I wouldn't mess with the electrical until you get the other stuff sorted out and put some miles on it making sure it's realible.
[Re: autoxcuda]
#1267245
07/14/12 12:58 PM
07/14/12 12:58 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
1) The driver's door doesn't shut right unless I really force it and the window overlaps the rear windows a decent amount. When you close the door you can here something is interfering with one another in the door latches.
2) Ok! Easy rust repair for the trunk. Thank you!
3) It was the pressure hose. Rockauto doesn't sell them so I was wondering what other places I should go to order them.
4) The lock in the passenger door doesn't work at all. Key won't go in completely and the locking mechanism (or tab inside) will not lock the door at all. You push the tab down and it doesn't go down. Almost as if it is just floating in its spot. The driver's side and ignition work fine.
5) I just thought the kill switch would be a nice idea to slow someone down if they were trying to steal the car.
[Re: NV69B7RR]
#1267246
07/14/12 01:00 PM
07/14/12 01:00 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Its really cool that you got that Dart. Should be a good runner, while you do your upgrades. A body parts are plentiful and usually cheap if you're patient. Post what parts you need, when you need them I'm sure we'll help you out. Keep your eyes out for a 73+ 4dr (w disc brakes) to part out and you might be able to get your big bolt conversion pretty cheap once you sell of the leftover parts. Congrats again!
PS, whatever upgrades you do for now be sure to keep the Dart running and driving, and make sure you have the $ for them before you tear into it.
Thanks! I definitely want to keep the car running and driving as long as possible. That's why a drivetrain swap isn't due till long term goals.
[Re: MuuMuu101]
#1267247
07/14/12 01:35 PM
07/14/12 01:35 PM
autoxcuda
So Cal
... 3) It was the pressure hose. Rockauto doesn't sell them so I was wondering what other places I should go to order them.
Is it a Federal or Saginaw pump? If you don't know off hand post a picture.
Some of the listings in RockAuto are incorrect. If you can get the correct part number, you can search from there.
You can just get it locally too.
[Re: autoxcuda]
#1267248
07/14/12 02:41 PM
07/14/12 02:41 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Here is a picture of the pump. If I recall correctly the 69 Dart service manual called it the 1.06" pump... With regards to the lock. This is how much the key and the locking mechanism go in (sorry for my poor descriptions)... And when it comes to the driver's side, there are actually a lot of things that need to be done as I started playing around. First off, this is the kind of overlap I am getting between the rear window and the door (Ignore the dirt, it's been sitting outside and it rained yesterday). As I started playing around rolling the windows down and trying to find out why things weren't working, this is what I found (some of which I figured out last week but I forgot). 1) The trim piece between the two windows is missing the weather stripping on one side and is bent which is forcing the trim piece to fall out whenever the rear window is scrolled down. Not only that but as I was scrolling down the rear window today, I noticed that it was installed improperly since the window moves around, back and forth and side to side unlike the passenger side which is pretty solid. 2) As I scrolled down the window in the door, I also noticed that it wasn't installed properly either. 3) As you open the door about 30 degrees from the parallel to the car, you feel the interference in the door latch and it makes a small screeching noise. Till you push it the rest of the way and it opens fine. I am sorry my terminology isn't that great but I'm learning. O! And I'll just throw this out there but my gas gauge doesn't work (or "works when it wants to" according to the seller). I just figured it may be a bad sending unit.
[Re: johnscudashop]
#1267250
07/14/12 05:29 PM
07/14/12 05:29 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Nice find!! I love the look of a 68 Dart. I imagine you have big plans for it...
O yeah! Big time! I always enjoy your build thread and the attention to detail you have.
[Re: MuuMuu101]
#1267251
07/14/12 05:58 PM
07/14/12 05:58 PM
Posts: 6,005 Reno, Nevada
NV69B7RR
Reno, Nevada
How do the body lines on the door line up before closing, low I'd guess? Is the striker post cracked, in other words can it be moving around. A bodies are notorious for the striker cracking out. How does the door to fender gap look, even or not? The door is fairly easy to adjust, but you'll need a floor jack or two people to it.
Also on the pic of the key in the lock, the key is upside down, on Chryslers the long part goes on the bottom, keyed (grooved) part goes up.
I HIGHLY recommend getting a 1968 Dodge service manual, as it will show and explain how to make everything function as new. Buy the book not the CD, unless you can take your laptop with you.
[Re: NV69B7RR]
#1267252
07/14/12 06:51 PM
07/14/12 06:51 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Whoever reinstalled the locks on the newer door installed it upside down. Anyways either way I put the key into the passenger door it won't go in (actually it goes in less when put in correctly).
I have the 1969 Dodge Dart manual on a pdf and I do plan on getting the 68 manual soon.
As far as the door fitness goes, it doesn't look too bad but it does seem that the door is a little lower, barely. I don't have a floor jack but I can see if my brother can help me, maybe. I honestly don't know what a striker post is. Here are some pictures.
[Re: NV69B7RR]
#1267255
07/14/12 07:56 PM
07/14/12 07:56 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
The striker is the peg attached to the body that the door latches to. Examine the latch in the door to see if its rubbing on the striker. As the door closes it latches twice, the first leaves the door sticking out an inch, the second pulls it tight to the body. Its the second one that will make u slam it to close it. If the pass door works good, then close it slowly and see how the drivers door should be latching correctly and when it latches. But check for a crack around the striker first because if the striker is moving adjusting the door won't do you any good.
The 69 manual is basically the same, so save the $50 for something else. It should tell you how to adjust the glass & door.
The passenger door closes effortlessly. I barely have to push it and it goes in easily. If I put the same amount of effort in the driver door, the striker stops it immediately. And you can tell the striker is feeling it big time.
[Re: MuuMuu101]
#1267256
07/14/12 08:37 PM
07/14/12 08:37 PM
Posts: 1,680 Raleighwood
2Bad360sfromNC
Raleighwood
First off, the car looks like a good score. From your pics of the rear of the door and the striker, I'd say your hinge pins are worn. You can usually tell for sure by opening the door slightly, then grab the door edge and see if you can lift it up like there is a little up and down play in it. If you can feel it clunk a bit up and down, it'd basically be more worth it to change the hinge pins and/or bushings before you mess with adjusting the hinges. They can be a pain, but they shouldn't be very expensive. I'll also add to the earlier advice about cleaning the rust in the trunk. Once you are done, make sure you dry up all the water you clean it with. You can back it up in the sun with the trunk open to help with that, too. Obviously, now you will have wire-brushed through the rust and some paint, so you will have some bare metal. You will want to put some paint over that (not just primer--primer is usually porous). Otherwise, as temps and humidity change (especially if your car is outside all the time) the rust will show back up fairly quickly. Unless you are going for some perfect resto, I'd also throw those rubber trunk mats far away. If your trunk leaks or gets condensation in it, they will trap the moisture to the floor and rust it all over again. I got the cheap, thin carpet from the parts store and trimmed it to fit my Challenger. That stuff is breathable enough to not hold water under it, plus your stuff doesn't slide all over as bad back there. That reminds me of another thing...(this is becoming a book, but I hope it helps) Unlike new cars, the trunk walls are your actual outer quarter panels, so you don't want to go driving like Bo Duke with a big toolbox or a floor jack or something back there, or you will acquire some custom outward dents! If you have to carry that stuff, try to stow it so it can't fly around. That will hopefully save you some frustration down the road.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D) 1974 Challenger 360 2012 Challenger R/T 1991 Dakota 5.2
[Re: 2Bad360sfromNC]
#1267257
07/14/12 09:01 PM
07/14/12 09:01 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Once I get the power steering fixed, she is going to get washed and put back in the garage until I want to take her out for cruise ins or drives around town so weather shouldn't be too big of an issue. I'll throw the trunk mats away anyways. I knew the inner trunk walls were the quarter panels so I will find a way of securing some of the things I got in there. I'll play around with the door after dinner and reply back.
Edit: Just took another look at the door. There is almost no up and down play when dealing with the door. It seems like one of the door rollers just isn't spinning causing the stop at 30 degrees. Of course I can open the door completely without putting too much pressure on it.
