Holley base plate fix?
#1265833
07/11/12 08:08 PM
07/11/12 08:08 PM
Posts: 1,527 Michigan
GoDartGo
what I have here is a fracture that needs to be fixed.
Question being, is there a way to weld it?
Re: Holley base plate fix?
[Re: GoDartGo]
#1265834
07/11/12 08:10 PM
07/11/12 08:10 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
Its just aluminum, so you can weld it, but wow that a nasty one.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: GoDartGo]
#1265836
07/11/12 08:29 PM
07/11/12 08:29 PM
Challenger 1
Cincinnati, Ohio
it's a '70 383 4spd carb. is that worth the time and money to fix and sell?
No you can't weld it, It should be replaced.
[Re: Challenger 1]
#1265837
07/11/12 11:55 PM
07/11/12 11:55 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
It can be welded,have done more than one.You need somebody that is good a tig weldrer,most work is the finish machineing.
[Re: 451Mopar]
#1265839
07/12/12 08:59 AM
07/12/12 08:59 AM
62maxwgn
Blair County,PA
looks like it's cracked between the bores too? Is there anything special about that base plate compared to other Holley 4-bbls? You may be able to get another base plate at a swap meet or junk yard? I sold some old carbs at the swap meet really cheap just to get rid of the clutter.
That plate has a provision to mount an idle solenoid,most don't.
[Re: 451Mopar]
#1265840
07/14/12 02:37 PM
07/14/12 02:37 PM
Posts: 434 sweden
cuda-sweden
sweden
it has bigger secondaries than primarys and it has a vacuum fitting for the ac at the rear.
