Holley base plate fix? #1265833
07/11/12 08:08 PM
07/11/12 08:08 PM
GoDartGo Offline OP
GoDartGo  Offline OP
what I have here is a fracture that needs to be fixed.
Question being, is there a way to weld it?
Re: Holley base plate fix? [Re: GoDartGo] #1265834
07/11/12 08:10 PM
07/11/12 08:10 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Its just aluminum, so you can weld it, but wow that a nasty one.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Holley base plate fix? [Re: kilroy] #1265835
07/11/12 08:16 PM
07/11/12 08:16 PM
GoDartGo Offline OP
GoDartGo  Offline OP
it's a '70 383 4spd carb. is that worth the time and money
to fix and sell?
Re: Holley base plate fix? [Re: GoDartGo] #1265836
07/11/12 08:29 PM
07/11/12 08:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
to fix and sell?
No you can't weld it, It should be replaced.
Re: Holley base plate fix? [Re: Challenger 1] #1265837
07/11/12 11:55 PM
07/11/12 11:55 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
to fix and sell?
It can be welded,have done more than one.You need somebody that is good a tig weldrer,most work is the finish machineing.
Re: Holley base plate fix? [Re: GoDartGo] #1265838
07/12/12 03:08 AM
07/12/12 03:08 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
looks like it's cracked between the bores too?
Is there anything special about that base plate compared to other Holley 4-bbls?
You may be able to get another base plate at a swap meet or junk yard? I sold some old carbs at the swap meet really cheap just to get rid of the clutter.
Re: Holley base plate fix? [Re: 451Mopar] #1265839
07/12/12 08:59 AM
07/12/12 08:59 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
That plate has a provision to mount an idle solenoid,most don't.
Re: Holley base plate fix? [Re: 451Mopar] #1265840
07/14/12 02:37 PM
07/14/12 02:37 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
it has bigger secondaries than primarys and it has a vacuum fitting for the ac at the rear.
