Hemi crossram intake question. #1265380
07/10/12 10:42 PM
07/10/12 10:42 PM
New England
Tech Instructor Offline OP
New England
Is there any need for sealer on the intake bolts? It is a magnesium intake.
Re: Hemi crossram intake question. [Re: Tech Instructor] #1265381
07/10/12 11:13 PM
07/10/12 11:13 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
I never used any. Just remember to re-torque them each time you got out til they quit moving.
Re: Hemi crossram intake question. [Re: OUTLAWSSAA] #1265382
07/10/12 11:16 PM
07/10/12 11:16 PM
New England
New England
Re: Hemi crossram intake question. [Re: OUTLAWSSAA] #1265383
07/11/12 02:06 AM
07/11/12 02:06 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
what is the proper torque for the factory mag intake , where is it listed ?
thank you !
Re: Hemi crossram intake question. [Re: calrobb2000] #1265384
07/11/12 09:26 AM
07/11/12 09:26 AM
New Jersey
Craig Offline
Craig  Offline
New Jersey
I've always been told to just tighten them snug, same criss-cross in-out pattern as stock intake, the mag ones are easily cracked! I use a stubby ratchet with handle about 3" long and gently hand-tighten in steps. If the fit is good, it would seal without the bolts, just use them to keep pressure on the gaskets. Just beware the intake port bottoms tend to suck oil from the lifter valley, but this is corrected with correct machining, not manifold torque.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Re: Hemi crossram intake question. [Re: Craig] #1265385
07/11/12 09:39 AM
07/11/12 09:39 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I always put some sealer on the bolts. 2 reasons one it help stop from sucking any oil up the bolt and 2 it helps them from backing out.
JAKES AUTOMOTIVE
Re: Hemi crossram intake question. [Re: JAKE68] #1265386
07/11/12 11:04 AM
07/11/12 11:04 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The torque values for the intake are listed in the Mopar hemi engine manual. They take different inch pounds on different bolts. It takes time to do it right. And as a previous poster said you will have to retorque several times after some heat cycles. It's worth doing right. Don't work on a Mopar without the proper engine manual. It's cheap and it can only help you.
2011 Drag Pak Challenger
