Re: NOT HAPPY
[Re: MR_P_BODY]
#1264038
07/13/12 12:47 PM
07/13/12 12:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well so far I havent found the smoking gun(no pun intended)... I have the engine on the stand, all the exhaust ports are oil saturated, pulled the intake and it was sealing fine and all the intake runner are clean... I pulled the rockers and the hold downs(TD rockers) so I have to remove the hold downs to get to the head bolts...will pull the heads next
Re: NOT HAPPY
[Re: Thumperdart]
#1264040
07/13/12 12:51 PM
07/13/12 12:51 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Valve stem seals maybe? Did you grind through em when porting? Just ideas............
oil would be in the port at that point - no?
what was done in the honing process? Plateau?
Re: NOT HAPPY
[Re: DJVCuda]
#1264041
07/13/12 12:56 PM
07/13/12 12:56 PM
MR_P_BODY
I had the block bushed a few years ago and honed with plates... it sat for a few years so all I did was run a ball deglazer in it real quick then cleaned it and started the normal assm work
Re: NOT HAPPY
[Re: DJVCuda]
#1264042
07/13/12 12:58 PM
07/13/12 12:58 PM
Thumperdart
State of confusion
Thinking maybe ex. porting cut through............If the ring seal went south maybe?...........I know some don`t run ex. valve stem seals...........
Re: NOT HAPPY
[Re: greendart408]
#1264044
07/13/12 01:20 PM
07/13/12 01:20 PM
MR_P_BODY
Mr P, do you have holes drilled in the heads for oil drainback in the valve spring area? Or slots ground in them so the oil will drain?
Yes... each spring pocket is cut to drain oil.... Dom I ran seals on all the valves
Re: NOT HAPPY
[Re: MR_P_BODY]
#1264045
07/13/12 01:24 PM
07/13/12 01:24 PM
Thumperdart
State of confusion
I`m not the best at this stuff so hopefully you find it.............
Re: NOT HAPPY
[Re: Thumperdart]
#1264046
07/13/12 01:28 PM
07/13/12 01:28 PM
MR_P_BODY
LOL.... I guess I'm not either... otherwise I wouldnt be in this spot.... breaks over.. I'll pull the heads
Re: NOT HAPPY
[Re: WheelsUp73]
#1264048
07/13/12 03:37 PM
07/13/12 03:37 PM
MR_P_BODY
What heads are you running? Mabe the second ring was installed upside down? Just a guess. My eddy heads were ported into the rocker hold down bolt holes and it pulled oil in the cylinder past the hold down bolts.I replaced the bolts with studs and lock tite them into place and no more smoke but I had oil getting into the intake manifold. Hope you find the problem!
W-5 heads..... I'm calling it wasted out rings... there is almost no cross hatch left in the bores... they look shiney... the bit of oil thats on the pistons and exhaust valve(some on the intakes but not near as much) is sticky and can be wiped right off with a paper towel
Re: NOT HAPPY
[Re: Moparnut426]
#1264050
07/13/12 06:35 PM
07/13/12 06:35 PM
MR_P_BODY
Wasted, or Washed from fuel?
WOW, that didnt take long for those to do that. I guess [Edited by Moparts - Family Friendly Site - Keep it clean] happends and the bad rings are still better than windows in the pan.
Yes... wasted and washed out... all the above and all I can think of is they were washed due to a heavy amount of fuel... tomorrow I'm going out to Milan with Randy(labrat) so it can sit till Sunday... I have the pan off so I'll pull the pistons Sunday... order parts on Monday
Re: NOT HAPPY
[Re: BBLM23]
#1264052
07/13/12 06:53 PM
07/13/12 06:53 PM
MR_P_BODY
not happy...
Three pages and no one said which dwarf are you?!
Is there a dwarf named stupid... that would be me
Re: NOT HAPPY
[Re: MR_P_BODY]
#1264053
07/13/12 07:02 PM
07/13/12 07:02 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
not happy...
I wouldnt call ya stupid, but I think there is a Dopy,
LOL sorry, could be a little below the belt.
Re: NOT HAPPY
[Re: Moparnut426]
#1264054
07/13/12 07:07 PM
07/13/12 07:07 PM
MR_P_BODY
not happy...
Thats close enough...lol
