904 front pump bolts torque spec? #1263086
07/06/12 04:14 PM
07/06/12 04:14 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
My ATS book says 175 ft/lbs for the pump bolts. I have always tightened them with common sense. I was just looking thru the book and noticed this. It must be a misprint?? All of the inch/lbs measurements have an * behind them.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 904 front pump bolts torque spec? [Re: DemonDust] #1263087
07/06/12 05:29 PM
07/06/12 05:29 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Definitely a typo , that should be inch/lbs.
Re: 904 front pump bolts torque spec? [Re: JohnRR] #1263088
07/06/12 05:55 PM
07/06/12 05:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No doubt.... at that torque the bolt would need to
be 1" and not into alum.... I dont have a book handy
but I think its 20 ft/lbs
Re: 904 front pump bolts torque spec? [Re: MR_P_BODY] #1263089
07/06/12 07:11 PM
07/06/12 07:11 PM
Menomonee Falls
Menomonee Falls
Yeah I figured they meant inch/lbs. I converted it and it came out to around 15 ft/lbs. I've always used just a 3/8 ratchet to tighen them probably around 20-25 ft/lbs.
I did a double take when I seen that and for a breif second I thought have I been doing this wrong all these years. But then used common sense as I thought more in depth.
Just thought I'd bring it up since after all it is in the ATS manual, and someone new to the hobby might not realize what they are doing.
SDG Motorsports
Re: 904 front pump bolts torque spec? [Re: MR_P_BODY] #1263090
07/07/12 01:05 AM
07/07/12 01:05 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
5/16th bolt, 20ft #
Re: 904 front pump bolts torque spec? [Re: DemonDust] #1263091
07/07/12 01:09 AM
07/07/12 01:09 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
I must have the same book.(ATSG) Mine has 175 too. I put an asterisk beside it. Definately a misprint.
Yeah, it's got a smallblock.
Re: 904 front pump bolts torque spec? [Re: DemonDust] #1263092
07/07/12 10:15 AM
07/07/12 10:15 AM
NC
440Jim Offline
440Jim  Offline
NC
For comparison, this is from a factory service manual.
