Re: 904 front pump bolts torque spec?
[Re: JohnRR]
#1263088
07/06/12 05:55 PM
07/06/12 05:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Definitely a typo , that should be inch/lbs.
No doubt.... at that torque the bolt would need to be 1" and not into alum.... I dont have a book handy but I think its 20 ft/lbs
[Re: MR_P_BODY]
#1263089
07/06/12 07:11 PM
07/06/12 07:11 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Yeah I figured they meant inch/lbs. I converted it and it came out to around 15 ft/lbs. I've always used just a 3/8 ratchet to tighen them probably around 20-25 ft/lbs.
I did a double take when I seen that and for a breif second I thought have I been doing this wrong all these years. But then used common sense as I thought more in depth.
Just thought I'd bring it up since after all it is in the ATS manual, and someone new to the hobby might not realize what they are doing.
[Re: DemonDust]
#1263091
07/07/12 01:09 AM
07/07/12 01:09 AM
Posts: 1,532 off the grid
340B5
off the grid
I must have the same book.(ATSG) Mine has 175 too. I put an asterisk beside it. Definately a misprint.
Yeah, it's got a smallblock.
