quad shock (anti hop) setups v other traction systems #1262320
07/05/12 06:57 PM
07/05/12 06:57 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Ive been running a home made caltrac system for years after I got tired of bending front spring segments. I never really optimized it but it did work. But it rides tough and Im looking to change the attitude of the car from straight line to high po road car.
I looked up this thread https://board.moparts.org/ubbthreads/showflat.php?Number=5888138 but it was a little ambiguous and now that we have a handing forum I thought I would revive it. So my question is how does a quad shock setup like this http://firmfeel.com/QuadShock_abcefmjT.htm work for cornering and will it help me stop bending front segments if I go away from my 'caltrac' system.
I realize that several mustang styles used them but how about us.
Of course I will fabbing my own stuff but I theories first.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: quad shock (anti hop) setups v other traction systems [Re: kilroy] #1262321
07/05/12 07:18 PM
07/05/12 07:18 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
on a different note how about using a coilover with the leafs instead? I had two roadrunners that had the old coilovers (non adjustable) on them and they handled fine. I wonder why no one has matched the new coilovers of today with the leaf spring setup
Re: quad shock (anti hop) setups v other traction systems [Re: kilroy] #1262322
07/05/12 08:45 PM
07/05/12 08:45 PM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
I think a quad shock system can work well if the right shock is used, and you have room to package it effectively. However, I don't really see how it would fix a spring bending issue? A kicker shock can calm the hop effect, but if you're bending the front of the spring regularly, I'd look into other root causes. Is the spring correct for the application, is something causing a bind, etc....
I can't see a single good reason to combine coil overs with leafs other than to provide a band aid to worn out leafs. If your leaf springs are in good shape and have proper rates, there is absolutely no reason to add more spring to the suspension.
Re: quad shock (anti hop) setups v other traction systems [Re: kilroy] #1262323
07/05/12 08:51 PM
07/05/12 08:51 PM
AndyF Offline
AndyF  Offline
Firm Feel has worked on a quad shock setup. Give them a call, I'm sure they can tell you what works.
Re: quad shock (anti hop) setups v other traction systems [Re: AndyF] #1262324
07/05/12 10:19 PM
07/05/12 10:19 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
I see that, this is the pick and link I have posted....
BUT I hate being a jackazz and given em a call and pumping them for info when I have no plans on spending money with them . Makes me Feel like a hypocrite freeloader.
Im bending springs up right behind the shackle. No binding, it actually is to free and causing severe spring wrap up on heavy car. Though I have free up about 300lbs from the last time I bent springs.
The only way I know to combat this would be to put more leafs further up, like ss springs, but I dont want a really huge spring rate or body separation.
Re: quad shock (anti hop) setups v other traction systems [Re: kilroy] #1262325
07/06/12 10:53 AM
07/06/12 10:53 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Your loosing alot of tire space with that setup, no? If your have tire hop, look at other areas of the rear suspension first, rather then going to a offroading setup.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: quad shock (anti hop) setups v other traction systems [Re: DARTH V8Я] #1262326
07/06/12 11:58 AM
07/06/12 11:58 AM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
If done right you could put the second shock up between the frame and the spring or set it up inboard.
What got me to thinking about this was the last issue of mopar action and I thought if good enough for our nascar teams of the past (which were hardly off road setups) what about on a street car.
Re: quad shock (anti hop) setups v other traction systems [Re: kilroy] #1262327
07/06/12 03:05 PM
07/06/12 03:05 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What got me to thinking about this was the last issue of mopar action and I thought if good enough for our nascar teams of the past what about on a street car.
Problem with that was it didnt work and was tried by Trans Am guys back in the day. It causes binding because is doesnt flow well with leaf spring geometry. Im gonna use my pinion snubber until I can afford a 3 link with a Watts.
Mopar to the bone!!!
Re: quad shock (anti hop) setups v other traction systems [Re: kilroy] #1262328
07/06/12 09:49 PM
07/06/12 09:49 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
...I thought if good enough for our nascar teams of the past (which were hardly off road setups) what about on a street car.
Drum brakes, cast iron rocker arms, heavy pistons, heavy valves, antiquated shocks... were also all good enough for Nascar teams of the past.
Getting a good shock will help big time against wheel hop. Also springs with a thick front segment.
Is this wheel hop only under acceleration from a stop? Basically a drag race start?
I've got Hotchkis road race springs and Bilstein shocks. I don't see any wheel hop: http://youtu.be/TLOrFexa6Fk and back view: http://youtu.be/hfMf9NzpY7E
Maybe barrow a mini cam, video it, and see what's happening down there???
Re: quad shock (anti hop) setups v other traction systems [Re: autoxcuda] #1262329
07/07/12 02:36 AM
07/07/12 02:36 AM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Nothing now with my home made caltrac, and not so much then as more of a spring bending below front shackle issue. I just thought maybe that would take some of the hit out on the intial and then some out on braking but....
...It looks like what I really need to do is build a spring pack with a couple of spring extending clear to front shackle and tailor the height and rate to something softer.
Was just looking for some real world experience with them.
Re: quad shock (anti hop) setups v other traction systems [Re: kilroy] #1262330
07/07/12 05:06 PM
07/07/12 05:06 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Based on these comments, I'd say you've got a big problem with your homemade traction device binding your springs and reaching yield points in the main leaf. Is it really in both ends? If so, you do have major issues. Since you had asked about a cal-trac set up in a handling application some time ago, I think you may have answered your question as to why they aren't real popular.
Myself, I'm not a big fan of the cal-trac/slide-a-link set ups for the simple fact that they are designed to make symetrical (non mopar) springs act more like a asymetrical (mopar) springs. The mopar design is already there so it doesn't need the same type of tuning that a ford or chevy needs. BTW, you know the cal-trac designer is a Ford racer, yes?
Traction shocks may not prevent the damage from occuring, they just slow down the reaction to the load that creates the damage. Ultimately they will eventually run out of travel and the spring will bend again or you'll create a new binding point and bend somethng else.
Re: quad shock (anti hop) setups v other traction systems [Re: TC@HP2] #1262331
07/07/12 08:36 PM
07/07/12 08:36 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Kilroy, On your Charger are you running a super stock spring, I ask since you mentioned your going from drag racing to handling.
If you are dump the super stock springs, install an XHD set (I used two left springs to keep the rate same on both sides of the car, handling not drag racing here) Or you can go with some XV, Firm Feel Oval track or Hotchkis leafs out back first.
Dump the cal track deal that is only designed to stiffen up the front segment of the spring for a drag car on launch. It does nothing for handling to stiffen the front segment.
Get a good set of shocks QA1 or Bilstiens seem to be the ones to use.
I installed the XHD (2 left springs) with the Firm Feel adjustable rear leaf hangers with them installed at the 1" lower hole to bring the car down more. Lower CG = better handling.
My old setup was SS leafs, 275/60R15 drag radial tires
New tires all around are 255/50R16's on my 72 Road Runner. Car rides like a dream and I need to get the better shocks I still have them KYB's on the car until I free up some more $$$$. The car road on the street like a 1 ton truck with no load in the bed before now it rides more like a car should..........
Re: quad shock (anti hop) setups v other traction systems [Re: PHJ426] #1262332
07/07/12 09:05 PM
07/07/12 09:05 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Let me clear up some issues as it seems I have posted illiterately.
I WAS bending springs upward just behind the front hanger, NOT the rear shackle, BEFORE I installed my caltracs. I installed my caltrac to COUNTERACT this bending issue, which it has. Now Im NOT bending springs, but with the caltrac it slams around on the street so I was looking for an alternative. I AM running XHD mopar springs order sometime in the late 90's, NOT ss springs. Though I am running a left and a right (not two lefts which is brilliant by the way).
I hope this clears up some confusion, , and I do appreciate the ideas you all are putting forth. I will probably be implementing them soon in the form of rebuilt spring package and eventually shocks. Ill listen some more if anyone wishes to continue.
Re: quad shock (anti hop) setups v other traction systems [Re: kilroy] #1262333
07/07/12 09:12 PM
07/07/12 09:12 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
What gear, converter and HP are you running with the Charger?
Do you know when you are bending the spring on launch at the drag strip on a prepped track with slicks or?
Has the car ever been hit (accident with frame damage) in the back or any where?
Have you had the car on a 4 wheel alignment rack to confirm everything on the frame wise is straight and true?
Just for comparison the 72 RR above has a 508" sixpack with stage VI heads. Hyd flat tappet cam, 9.5" TC and a 2:94 gear in the 8 3/4" Obviously the XHD springs out back and currently there is NO pinion snubber, (factory or adjustable) or traction device (cal track or slapper bars) in the car.
So far I havent bent a "new" Mexican XHD leaf spring on this car to date. These springs have been on since the end of March this year and put probably close to 500 miles on it now in this configuration.
Re: quad shock (anti hop) setups v other traction systems [Re: kilroy] #1262334
07/08/12 01:12 PM
07/08/12 01:12 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Sounds like it is time to build up our own spring pack.
As a 73, you have dumped all the iso clamp crap?
To build a pack, choose the main leaf you want to run. Align your second leaf so the tip of its front edge is directly under the spring eye of the main leaf. Drill the new mounting hole to match the housing alignment bolt. Align the balance of the pack to similar spacing as it was before as you redrill each leaf to its new position. Add or subtract leafs until you reach a rate you're comfortable with.
If you want to copy the Hotchkis principle, you can cut a single leaf to be square on each end and mount on the top of the main leaf to run from the spring eye area to the axle housing pad.
Re: quad shock (anti hop) setups v other traction systems [Re: TC@HP2] #1262335
07/08/12 01:42 PM
07/08/12 01:42 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
I forget the 73 had that Iso spring deal here are the parts you need to remove that:
http://www.firmfeel.com/Isodeletekit_b73up.htm
Or just get all the parts used off of a 72 or 71 B body and your good to go.
And these hangars with the shorter length for the stock 22" front segment spring with the 2 different height holes for the front spring eye.
Will get that large B body closer to the ground.
Lower CG = better handling.......
http://www.firmfeel.com/leafhang_b.htm
Then after you get rid of that your rear springs will be exactly like on my 72 and I have not bent my new bought this year Made in Mexico XHD springs yet or build your own......those should not bend
Re: quad shock (anti hop) setups v other traction systems [Re: PHJ426] #1262336
07/08/12 05:57 PM
07/08/12 05:57 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I need to do something quick since my driveshaft is hitting the floor without a snubber. It actually tore a weight off my brand new driveshaft. Not impressed. I think these Hotchkis springs would be fine on a smaller tire that breaks loose easier. My 335s are like glue after first gear which is awesome but not awesome for these springs. So im gonna use a stock snubber with 2 poly bumpers that are 2" tall and about 1.25" from the floor and see how that works.
Re: quad shock (anti hop) setups v other traction systems [Re: 72Swinger] #1262337
07/08/12 06:26 PM
07/08/12 06:26 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Ya, the only thing that I havent got rid of are the front iso bushings in the Kmember and those are going out this winter. I hate the front shock selection for the 73 and up car, the shocks are so short. I have even gotten rid of the iso torsion bar holder and welded in old style tbar holders in the trans member so I could get the shorter tbars and better tbar rates that come with them.
In the back I got rid of the iso stuff years ago and, regardless of what controversy there is, I flipped the spring hangers and lowered the car 1.5" give or take (and love it!)
Im now running a 4speed but I was bending springs with an auto, I then switched to a homemade caltrac and a 4speed and have stopped bending but am unhappy with the spring/rear action. I also used to have a stock rear sway on the car when I was bending springs and I will probably be putting it back on soon once I rebuild the spring packs and take the homemade caltrac off.
Re: quad shock (anti hop) setups v other traction systems [Re: 72Swinger] #1262338
07/08/12 06:28 PM
07/08/12 06:28 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
I know where you are at. This is how you bend springs
Not laughing at your problem, i know how you feel. I stopped it with my home made caltrac but all posted above.....
Re: quad shock (anti hop) setups v other traction systems [Re: kilroy] #1262339
07/10/12 10:54 AM
07/10/12 10:54 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Shock trick for these - gusset the bottom of the control arm to box it in. Then hole saw the top of the control arm so it has a large enough hole to pass a shock body through it. Then buy 1st gen Camaro shocks. The lower bar mount of teh Camaro shock can be bolted to the added gusset, the upper bayonet mount fits right into the stock mopar hole. Loads of choices in shocks that way.
The leaf trick I described above is outlined in the Mopar Chassis manual. It is an old trick at making stock length leaf springs provide the same support as a super stock set without going to the shorter length and higher rate that come with SS packs.
If you really want to get gonzo, you can do what the 4x4 guys do and have the second leaf run full length and provide a second wrap around the eyes.
