Fuel Vapor Separator #1258262
06/27/12 12:46 PM
06/27/12 12:46 PM
Texas
K
Knappy Offline OP
Knappy  Offline OP
K
Texas
Does anyone make a fuel vapor separator for a 440 70 Challenger with 3/8 fuel lines and 1/4 return? The ones I have found all have 5/16 fuel inlet and outlets.
Steve
68 Coronet R/T Hemi
70 Challenger 440-6
70 Challenger R/T S/E 440-6
71 Challenger Convert.
70 Superbird 440-6
Re: Fuel Vapor Separator [Re: Knappy] #1258263
06/27/12 12:50 PM
06/27/12 12:50 PM
dogdays Offline
dogdays  Offline
I question the need. What the smaller lines will do is cause the fuel velocity to increase as it goes through the smaller tubes. This will increase the friction loss somewhat, but I doubt it will add so much loss that you can't get fuel through the lines.
Keep in mind that fuel is a liquid. Every foot of the fuel line contributes some friction loss or, for the engineers out there, head loss. So what this short length of smaller diameter line does is increase the head loss. It is equivalent to increaing the length of the fuel line by a few feet.
R.
Re: Fuel Vapor Separator [Re: Knappy] #1258264
06/27/12 01:06 PM
06/27/12 01:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
3/8" is only needed on the suction side(on big HP motors), the discharge side of the pump is best at 5/16", that's all you need.
All pumps for the most part no matter what there pumping should have a larger inlet than discharge. Our fuel pumps on our old cars are no different.
My 440 6 pak with factory 5/16" VS runs great with plenty of fuel from my mechanical pump on the motor.
Re: Fuel Vapor Separator [Re: Knappy] #1258265
06/27/12 02:24 PM
06/27/12 02:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
short answer - No
Re: Fuel Vapor Separator [Re: Knappy] #1258266
06/27/12 03:52 PM
06/27/12 03:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Steve
That's because the fuel line is only 3/8" between the tank pickup point and the pump , 5/16 line is the output side of the pump.
Re: Fuel Vapor Separator [Re: Knappy] #1258267
06/27/12 07:38 PM
06/27/12 07:38 PM
Forest Lake, Minnesota
superbeejim Offline
superbeejim  Offline
A few years ago I was looking for the same thing and found it. If you do a search on it you will find the part # that I found. Yes, Fram makes a fuel filter with 3/8" inlet and outlet and a 1/4" return line. No, it does not look exactly like the original and it doesnt have the mounting tab to bolt it to the fuel pump. But if you solder a tab on it and paint it black, it will make a reasonable looking substitute for a very cheap price
Re: Fuel Vapor Separator [Re: superbeejim] #1258268
06/27/12 08:06 PM
06/27/12 08:06 PM
Harlan, Ky
O
Orange_Duster Offline
O
Harlan, Ky
wix 33041
Re: Fuel Vapor Separator [Re: Orange_Duster] #1258269
06/28/12 09:14 AM
06/28/12 09:14 AM
Texas
K
Knappy Offline OP
Knappy  Offline OP
K
Texas
Thanks guys, did not realize the fuel pump had a 5/16 outlet. I am going to check out the WIX filter. I just did not want to slow the fuel delivery down.
Steve
68 Coronet R/T Hemi
70 Challenger 440-6
70 Superbird 440-6
Re: Fuel Vapor Separator [Re: Knappy] #1258270
06/28/12 09:21 AM
06/28/12 09:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Steve
Factory lines from the pump to the carbs are 5/16 , even on a hemi , so unless you bend up some custom lines , or one of the line makers does them in 3/8 , having a 3/8 filter isn't gaining you anything .
