Fuel Vapor Separator
#1258262
06/27/12 12:46 PM
06/27/12 12:46 PM
Posts: 109 Texas
Knappy
Texas
Does anyone make a fuel vapor separator for a 440 70 Challenger with 3/8 fuel lines and 1/4 return? The ones I have found all have 5/16 fuel inlet and outlets.
Steve
68 Coronet R/T Hemi 70 Challenger 440-6 70 Challenger R/T S/E 440-6 71 Challenger Convert. 70 Superbird 440-6
Re: Fuel Vapor Separator
[Re: Knappy]
#1258263
06/27/12 12:50 PM
06/27/12 12:50 PM
dogdays
I question the need. What the smaller lines will do is cause the fuel velocity to increase as it goes through the smaller tubes. This will increase the friction loss somewhat, but I doubt it will add so much loss that you can't get fuel through the lines. Keep in mind that fuel is a liquid. Every foot of the fuel line contributes some friction loss or, for the engineers out there, head loss. So what this short length of smaller diameter line does is increase the head loss. It is equivalent to increaing the length of the fuel line by a few feet. R.
[Re: Knappy]
#1258265
06/27/12 02:24 PM
06/27/12 02:24 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
short answer - No
[Re: Knappy]
#1258266
06/27/12 03:52 PM
06/27/12 03:52 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Steve
That's because the fuel line is only 3/8" between the tank pickup point and the pump , 5/16 line is the output side of the pump.
[Re: Orange_Duster]
#1258269
06/28/12 09:14 AM
06/28/12 09:14 AM
Posts: 109 Texas
Knappy
Texas
Thanks guys, did not realize the fuel pump had a 5/16 outlet. I am going to check out the WIX filter. I just did not want to slow the fuel delivery down.
Steve
[Re: Knappy]
#1258270
06/28/12 09:21 AM
06/28/12 09:21 AM
JohnRR
U.S.S.A.
Steve
Factory lines from the pump to the carbs are 5/16 , even on a hemi , so unless you bend up some custom lines , or one of the line makers does them in 3/8 , having a 3/8 filter isn't gaining you anything .
