Fender Tag - Different color than car? #125803
09/24/08 06:42 PM
09/24/08 06:42 PM
Hayes, Virginia
Winston Offline OP
Winston  Offline OP
Hayes, Virginia
I have a Challenger that has a blue fender tag, yet the car is green. Has anyone else heard of a fender tag being a different color than the car? It's a '74 model. The car is on Ebay, and I received this question about it and don't know the answer. Any information on this would be appreciated.
Winston '71 Barracuda Gran Coupe
Re: Fender Tag - Different color than car? [Re: Winston] #125804
09/24/08 06:47 PM
09/24/08 06:47 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Do the last six digits on the bottom line of the tag match the VIN tag on the dash?
The hose is covering the exterior color code so it's hard to determine the original color of the car that goes with the tag.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Fender Tag - Different color than car? [Re: Winston] #125805
09/24/08 06:48 PM
09/24/08 06:48 PM
Kirkland, Washington
Pacnorthcuda Offline
Does the VIN sequence (last 6 digits) match the VIN on the dash, the title, the door tag, and the body stampings?
Re: Fender Tag - Different color than car? [Re: Pacnorthcuda] #125806
09/24/08 06:54 PM
09/24/08 06:54 PM
Hayes, Virginia
Winston Offline OP
Winston  Offline OP
Hayes, Virginia
Yes, everything matches on the car. The color code is KG2 on the fender tag and car.
Re: Fender Tag - Different color than car? [Re: Winston] #125807
09/24/08 06:57 PM
09/24/08 06:57 PM
God's Country Maryland
GODSCOUNTRY340 Offline
At the factory the fender tag is attached with one screw, the painter painted the tag with the car ( the same color as the car), lifted the tag up at the loose end and painted under it. Then the tag is pushed back down and attached with the other unpainted screw.
Re: Fender Tag - Different color than car? [Re: Winston] #125808
09/24/08 07:01 PM
09/24/08 07:01 PM
Does the car appear to be a repaint? I am not sure what color KG2 is (others will chime in shortly) so I can say if that tag (or car) could be KG2 (I don't think the tag is because blues were B3, B5, B7)
The left hand screw (covered by the PS Hose) should be painted...is it? What color?
FOr whatever reason (and without more info) I am thinking your TAG was repainted ! (???)
Re: Fender Tag - Different color than car? [Re: Winston] #125809
09/24/08 07:15 PM
09/24/08 07:15 PM
You sure about the KG2??? The paint code is the first sequence (all the way on the left) 2nd row up from the bottom----thats says "KG2"? (just checking)
Re: Fender Tag - Different color than car? [Re: Pacnorthcuda] #125810
09/24/08 07:16 PM
09/24/08 07:16 PM
Hayes, Virginia
Winston Offline OP
Winston  Offline OP
Hayes, Virginia
I appreciate all the replies and helpful info.
KG2 is for Frosty Green Metallic.
The blue on the tag appears to be the same color blue found on the 318 engine.
Here is a pic I just took. The left screw is a little smaller than the right screw. The screw on the right appears to be more 'brown' or rusty.
Re: Fender Tag - Different color than car? [Re: Winston] #125811
09/24/08 07:27 PM
09/24/08 07:27 PM
Fair enough. The only explaination is the fender tag was repainted by a previous owner. Probably not real wise, but it happens (better than NO tag!!!) Shouldn't alarm potential bidders, once its explained that the numbers all match. (I don't know about engine tranny etc....but the tag/decal/title numbers match.
Re: Fender Tag - Different color than car? [Re: Pacnorthcuda] #125812
09/24/08 07:36 PM
09/24/08 07:36 PM
Hayes, Virginia
Winston Offline OP
Winston  Offline OP
Hayes, Virginia
Really appreciate the input. Yeah, all the numbers match, and it wouldn't surprise me if the broadcast sheet happened to be in the car. I've never looked, but the car is extra clean. Thanks again for all the help.
Winston
Re: Fender Tag - Different color than car? [Re: Winston] #125813
09/25/08 08:41 AM
09/25/08 08:41 AM
cataclysm80 Offline
cataclysm80  Offline
That's interesting.
Tav
Re: Fender Tag - Different color than car? [Re: cataclysm80] #125814
09/25/08 10:13 AM
09/25/08 10:13 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
strange, there doesn't appear to be a crease on that tag in the upper left corner where it would have been bent?
Re: Fender Tag - Different color than car? [Re: A12] #125815
09/25/08 10:16 AM
09/25/08 10:16 AM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
That's what I was thinking.
Re: Fender Tag - Different color than car? [Re: GODSCOUNTRY340] #125816
09/25/08 11:18 AM
09/25/08 11:18 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Sometimes.
My Lynch Rd. 1970 Superbee had the tag painted off the car (likely hung inside) and then fastened to the fender with two unpainted screws.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Fender Tag - Different color than car? [Re: DPelletier] #125817
09/25/08 11:22 AM
09/25/08 11:22 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
I see the code V1G on the tag. Gator Grain roofs had to only offered with certain colors- and doubt blue of any shade would be one of them. Not sure if this helps.
Re: Fender Tag - Different color than car? [Re: Kirby] #125818
09/25/08 12:18 PM
09/25/08 12:18 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
Actually for 1974 V1G was a green vinyl top. They switched over from using F in their paint codes too.
Re: Fender Tag - Different color than car? [Re: KISSAlien] #125819
09/25/08 12:52 PM
09/25/08 12:52 PM
minnesota
Kirby Offline
Kirby  Offline
minnesota
Didn't catch that it was a 74- oops
Re: Fender Tag - Different color than car? [Re: 70challrtse] #125820
09/25/08 02:20 PM
09/25/08 02:20 PM
cataclysm80 Offline
cataclysm80  Offline
I think the LA plant is one of the plants that bent the tag up. LA only made E bodies in 1970. This car was built in Hamtramck which is the only E body plant 71-74. I don't recall seeing any Hamtramck fender tags that are bent on the corner as described.
Tav
Re: Fender Tag - Different color than car? [Re: Kirby] #125821
09/25/08 03:38 PM
09/25/08 03:38 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Gator grain on a frinds B3 T/A.
Re: Fender Tag - Different color than car? [Re: 62maxwgn] #125822
09/25/08 04:17 PM
09/25/08 04:17 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
It was available on all the blues (EB3, EB5 and EB7) depending on the interior color.
