Fender Tag - Different color than car?
#125803
09/24/08 06:42 PM
09/24/08 06:42 PM
Posts: 279 Hayes, Virginia
Winston
Hayes, Virginia
I have a Challenger that has a blue fender tag, yet the car is green. Has anyone else heard of a fender tag being a different color than the car? It's a '74 model. The car is on Ebay, and I received this question about it and don't know the answer. Any information on this would be appreciated.
Winston
'71 Barracuda Gran Coupe
Re: Fender Tag - Different color than car?
[Re: Winston]
#125804
09/24/08 06:47 PM
09/24/08 06:47 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Do the last six digits on the bottom line of the tag match the VIN tag on the dash?
The hose is covering the exterior color code so it's hard to determine the original color of the car that goes with the tag.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: Pacnorthcuda]
#125806
09/24/08 06:54 PM
09/24/08 06:54 PM
Winston
Hayes, Virginia
Yes, everything matches on the car. The color code is KG2 on the fender tag and car.
Winston
[Re: Winston]
#125807
09/24/08 06:57 PM
09/24/08 06:57 PM
Posts: 2,512 God's Country Maryland
GODSCOUNTRY340
At the factory the fender tag is attached with one screw, the painter painted the tag with the car ( the same color as the car), lifted the tag up at the loose end and painted under it. Then the tag is pushed back down and attached with the other unpainted screw.
[Re: Pacnorthcuda]
#125810
09/24/08 07:16 PM
09/24/08 07:16 PM
Winston
Hayes, Virginia
I appreciate all the replies and helpful info. KG2 is for Frosty Green Metallic. The blue on the tag appears to be the same color blue found on the 318 engine.
Here is a pic I just took. The left screw is a little smaller than the right screw. The screw on the right appears to be more 'brown' or rusty.
Winston
[Re: Pacnorthcuda]
#125812
09/24/08 07:36 PM
09/24/08 07:36 PM
Winston
Hayes, Virginia
Really appreciate the input. Yeah, all the numbers match, and it wouldn't surprise me if the broadcast sheet happened to be in the car. I've never looked, but the car is extra clean. Thanks again for all the help.
Winston
Winston
[Re: A12]
#125815
09/25/08 10:16 AM
09/25/08 10:16 AM
Posts: 2,852 Dallas, TX
70challrtse
super gas
super gas
Dallas, TX
strange, there doesn't appear to be a crease on that tag in the upper left corner where it would have been bent?
That's what I was thinking.
[Re: GODSCOUNTRY340]
#125816
09/25/08 11:18 AM
09/25/08 11:18 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Sometimes.
My Lynch Rd. 1970 Superbee had the tag painted off the car (likely hung inside) and then fastened to the fender with two unpainted screws.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 70challrtse]
#125820
09/25/08 02:20 PM
09/25/08 02:20 PM
Posts: 4,165 Florida
cataclysm80
I think the LA plant is one of the plants that bent the tag up. LA only made E bodies in 1970. This car was built in Hamtramck which is the only E body plant 71-74. I don't recall seeing any Hamtramck fender tags that are bent on the corner as described.
Tav
