how to tell what heads I have by looking at them #1257226
06/25/12 05:20 PM
06/25/12 05:20 PM
Martinsburg WV
moparman111 Offline OP
Martinsburg WV
Hi, I recently purchased a 67 Cuda with a 318 in it. I know it is a 318 as being under the car it was visible. As far as the owner knew the engine had a choppy cam and 360 heads. Well they werent very mechanically inclined and inturn the intake needs to be changed. It currently has a Edelbrock LD4B intake on it now. I want to replace it with a new Edelbrock but the two choices I see are a #2176 and #7176. The obvious is the #2176 as it works with all small blocks but is the less powerful. Plus it requires the newer style stat housing. But the #7176 is the more HP intake plus it usees my same stat housing.
Can someone more knowledgable please tell me if there is a way by looking at casting #'s for me to confirm what the previous owner told me that they are 360 heads so I can buy the better #7176 intake? I just dont want to buy the #7176 and not be able to use it:(.
Thank you ALL
Robert
moparman111@msn.com
Re: how to tell what heads I have by looking at them [Re: moparman111] #1257227
06/25/12 05:23 PM
06/25/12 05:23 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Pull a valve cover and look at the casting number , also there is a big letter where the plugs are, what is it ?
Re: how to tell what heads I have by looking at them [Re: JohnRR] #1257228
06/25/12 07:29 PM
06/25/12 07:29 PM
Martinsburg WV
Martinsburg WV
John good idea. Here is what reads at the spark plugs.
On the back by spark plug at cylinder #8 reads either a 24 or 25. Hard to tell what it is but deffinitely one of those.
On the front of the D-side next to cylinder #1 is a giant 3. I wish they would have had a giant J as I think they are the best heads to have but can someone please tell me if these are in fact 360 heads? Thank you John and to everyone else for your helpful info:)
Re: how to tell what heads I have by looking at them [Re: moparman111] #1257229
06/25/12 07:46 PM
06/25/12 07:46 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
as said..pull a valve cover at look for the casting number...
Tony
70 AARCuda Vitamin C
Re: how to tell what heads I have by looking at them [Re: 70AARcuda] #1257230
06/25/12 07:56 PM
06/25/12 07:56 PM
Martinsburg WV
Martinsburg WV
Those bigger numbers dont tell? Thanks
Re: how to tell what heads I have by looking at them [Re: moparman111] #1257231
06/25/12 08:11 PM
06/25/12 08:11 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
well..compare those numbers to this chart and see if they tell ya anything...LOL
http://www.mymopar.com/headcastnumb.htm
Tony
Re: how to tell what heads I have by looking at them [Re: moparman111] #1257232
06/25/12 08:25 PM
06/25/12 08:25 PM
Martinsburg WV
Martinsburg WV
I pulled both sides. The casting numbers are very small and hard to read on the p-side. I couldnt make them all out. But the ones on the D-side were a bit easier to read. Here is what I believe them to be:
1. D-side 2843675 (I am pretty sure on those)
2. P-side #345876 or #345875 (The first digit isnt readable and the last is either a 6 or a 5.
Well the P-side doesnt show up at all. The driverside does and shows a 318 head. I guess it is the Edelbrock #2176 for now.:(
I am better to know before I buy. Thank you guys for your help:)
Re: how to tell what heads I have by looking at them [Re: moparman111] #1257233
06/25/12 08:35 PM
06/25/12 08:35 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
measure the intake port. if they are 7/8 x 1 7/8 they are 318s and I bet they are. if they are 1 x 2 they are 360 heads. if they do turn out to be 318s that LD4B intake is hard to beat.
I am truckless..
Re: how to tell what heads I have by looking at them [Re: 340SHORTY] #1257234
06/25/12 09:23 PM
06/25/12 09:23 PM
Martinsburg WV
Martinsburg WV
Thanks shorty. The LD4B is whats on it now. But since the previous owner(s) stripped out both stat housing bolt holes and it seems to have a warped stat housing surface. Even if you tighten it down all the way it still leaks at the very back towards the carb:(.
Re: how to tell what heads I have by looking at them [Re: moparman111] #1257235
06/25/12 09:49 PM
06/25/12 09:49 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Easy to put 2 heli-coils in and sand/file the mounting surface flat. Probably a warped thermostat housing, not a warped mounting surface though.
When you work on Spaceships for a living, how bad can a workday be?
Re: how to tell what heads I have by looking at them [Re: dart440] #1257236
06/25/12 09:53 PM
06/25/12 09:53 PM
Martinsburg WV
Martinsburg WV
The previous owner did a poor job at installing two helicors. I think they drilled them out to large. Also I tried a new stat housing and the problem persisted.:(
With the rear gasket area (previous owner just tried to use sealant on the outside to fix leak) leaking oil I thought if I were going to pull to install a new gasket I would install a new intake to.
Re: how to tell what heads I have by looking at them [Re: moparman111] #1257237
06/25/12 10:03 PM
06/25/12 10:03 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
With an aluminum manifold, the bolt holes could be welded up and redrilled/tapped. You can check the mating surface by lightly running a fine file across it and see if there are high/low spots. If there are, file the surface flat. Could it be leaking around the poorly installed heli-coils and running toward the back?
I liked the LD340 I had... I'd spend the $$$ fixing that one over purchasing a different manifold unless you're looking for something that makes more power, like an air gap.
Re: how to tell what heads I have by looking at them [Re: moparman111] #1257238
06/25/12 10:33 PM
06/25/12 10:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
While your at it don't be in to much of a hurry to ditch that LD4B it;s a good intake...
Re: how to tell what heads I have by looking at them [Re: moparman111] #1257239
06/25/12 11:22 PM
06/25/12 11:22 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Dibs on the LD4B! I got dibs!
That is a good manifold, might be worth a little repair work.
It takes gasoline to interest me.
Re: how to tell what heads I have by looking at them [Re: moparman111] #1257240
06/25/12 11:55 PM
06/25/12 11:55 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Actually Magnum heads are the best factory cast iron heads to have, in stock form
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: how to tell what heads I have by looking at them [Re: VL21] #1257241
06/25/12 11:56 PM
06/25/12 11:56 PM
Martinsburg WV
Martinsburg WV
Dang I had no idea this manifold was so sought after. I will work with it a bit more before I ditch it. Glad I didnt go ahead and jump to the 2176. If this intake is such a great one why doesnt Edelbrock make them anymore? Thanks guys.
Re: how to tell what heads I have by looking at them [Re: moparman111] #1257242
06/26/12 12:29 AM
06/26/12 12:29 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I've have one of these intakes on a 318 I have it it really works well, wakes that old 318 up. Great throttle response and power!! Also have a set of headers on the engine. Otherwise stock.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
