Page 3 of 4 1 2 3 4
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256199
06/26/12 01:27 PM
06/26/12 01:27 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
WOW
Awesome car!
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256200
06/26/12 09:47 PM
06/26/12 09:47 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Great Looking ride there. Looks like a lot of fun.
Just curious, why all steel except for the hood?
Nobody makes parts for these cars...I guess because they make carbon/fiberglass bodies for Pro Stock?
Unless someone knows of a company that does I am unaware of anyone that makes parts for them.
Doors would be my best investment right now, they are about 40lb each after ALOT of work...
Here's an older link http://www.insidecompracing.com/showthread.php?t=5400&highlight=Dodge+Stratus
You never know, it may still be available.
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256201
06/28/12 11:49 PM
06/28/12 11:49 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
That Stratus is awesome. The detail is incredible.
Re: Dodge Stratus...so close but so far away [Re: Dave Watt] #1256202
06/29/12 12:30 AM
06/29/12 12:30 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Very Nice!! What you at in SE wa?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Dodge Stratus...so close but so far away [Re: HOTMOPR] #1256203
07/06/12 09:13 PM
07/06/12 09:13 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Yea Pasco aka Tri-Cities
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256204
07/07/12 10:39 AM
07/07/12 10:39 AM
K&Q va.
BIGBLOCK_KAT Offline
K&Q va.
Forest, the car looks great I was getting some photos off my old.computer and seen the stratus when you had the floors cut out. You definitely are a stickler for attention to detail. I thought vfn or someone made f/g doors.... no interchange with the avenger? Keep us posted.
Re: Dodge Stratus...so close but so far away [Re: SCDaytona] #1256205
07/07/12 12:21 PM
07/07/12 12:21 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
not so sure about the 1 on the end but my buddy has the jegs front end on his car..
quote]http://i1123.photobucket.com/albums/l548/bigmike540/utf-8BVW5uYW1lZC5qcGc-1.jpg
Re: Dodge Stratus...so close but so far away [Re: earthmover] #1256206
07/07/12 10:28 PM
07/07/12 10:28 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
One step closer got the 46" carbon wheel tubs installed today in the blistering heat.
Re: Dodge Stratus...so close but so far away [Re: SCDaytona] #1256207
07/07/12 10:50 PM
07/07/12 10:50 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
96 Degrees? I can't wait till it gets that cool in the daytime here. It was 95 in my garage w/ my(undersized) A/C hammering away. 104 outside.
That is one fantastic looking car. It seems you settle for nothing less than perfection.
Yeah, it's got a smallblock.
Re: Dodge Stratus...so close but so far away [Re: 340B5] #1256208
09/02/12 12:39 AM
09/02/12 12:39 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Finished the doors today. All the tin from the wheel tubs forward is done. Just gotta build a rear firewall and trunk tin. Then I can start on wiring and fire it up.
Gutted factory doors, driverside is on pins for easy removal.
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256209
09/02/12 12:59 AM
09/02/12 12:59 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Finished the Dash too...
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256210
09/02/12 01:09 AM
09/02/12 01:09 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
did you bend the tube for the windows are is that a kit???love the car by the way.....
Re: Dodge Stratus...so close but so far away [Re: earthmover] #1256211
09/02/12 12:36 PM
09/02/12 12:36 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
No I bent the tube its 3/8" chromoly...probably should have used 5/16".
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256212
09/02/12 01:12 PM
09/02/12 01:12 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Beautiful work. I can't wait to see it finished.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dodge Stratus...so close but so far away [Re: pittsburghracer] #1256213
09/03/12 01:57 PM
09/03/12 01:57 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
Wow
Re: Dodge Stratus track debut [Re: Chad Bittle] #1256214
10/08/12 12:21 AM
10/08/12 12:21 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Made it out to the track and got my competiton license and did a little racing the next day.
Car went straight to 6.14 at 113 in the 1/8 with my baby small block outta the trailer with a 100% new car.
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256215
10/08/12 01:16 AM
10/08/12 01:16 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Awesome! Glad you got it out and it sounds like its working well! Congrats from the wet side of the state..
Re: Dodge Stratus...so close but so far away [Re: HOTMOPR] #1256216
10/08/12 09:24 AM
10/08/12 09:24 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Beautiful car, great build...thanks for posting, keep up the good work
Rich H.
Esse Quam Videri
Re: Dodge Stratus...so close but so far away [Re: ZIPPY] #1256217
08/26/13 09:50 PM
08/26/13 09:50 PM
ohio
all spooled up Offline
ohio
how have u been doing with silver bullet
Re: Dodge Stratus track debut [Re: Forest] #1256218
08/26/13 10:41 PM
08/26/13 10:41 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Nice car
You mentioned awhile back body mounting hoops are mounted in "pinch welds"? Care to explain that term?
Page 3 of 4 1 2 3 4
