Engine Diapers #1255337
06/21/12 11:18 PM
06/21/12 11:18 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
Who runs one? What brand is it? How does it fit? What's it on (engine, headers and chassis)?
I'm in the market, any advice is appreciated to help me from wasting money on a bad one.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Engine Diapers [Re: Triple Threat] #1255338
06/21/12 11:27 PM
06/21/12 11:27 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
diapers are a pita. do what ever it takes and build some form of belly pan that removes quickly. it will cost more, but in the long run you'll be happier.
Re: Engine Diapers [Re: Deepockets] #1255339
06/21/12 11:46 PM
06/21/12 11:46 PM
Renton Washington
Renton Washington
With Stock suspension and in chassis headers that's going to be a chore. If anyone has pictures of one I'd love to see it. I have access to a metal brake, welder etc if it can be done.
1:8 LOWER ENGINE CONTAINMENT DEVICE
"In classes where specified, must utilize an NHRA-accepted lower
engine oil-retention device. SFI Spec 7.1 or 7.2 Lower Engine
Containment Device permitted. A properly fitting lower engine
ballistic/restraint device mandatory. The NHRA Technical staff can
accept or reject any device. Any device that fails to perform as
required must be replaced or repaired to the satisfaction of the
Technical staff prior to any furthur runs. When used, an SFI Spec
7.1 or 7.2 Lower Engine Containment Device must cover the sides
of the block and pan up to within one inch of the head mating
surface and extend to within 1 1/2 inches of the front and rear of the
cylinder case area. SFI Spec 7.1 devices must be
updated/recertified by the original manufacturer at one-year
intervals. In classes where specified, a belly pan may be used in
lieu of a device attached to the engine. The belly pan must extend
from framerail to framerail and extend forward of the harmonic
balancer and to the rear of the engine block and must incorporate a
minimum 2-inch-high lip on all sides unless specified in Class
Requirements. Minimum number of slots or holes in the walls to
clear frame, steering, or lines permitted. A nonflammable, oilabsorbent
liner mandatory inside of retention device."
-Dustin
Re: Engine Diapers [Re: Triple Threat] #1255340
06/22/12 12:12 AM
06/22/12 12:12 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Dustin... I got mine from DRE diapers.. it fits fairly well and he added some kevlar patches where the header tube comes within 2" of the block..
The Duster is a stock frame deal with a modified K member and a rack for steering, so mine doesnt have the same interference as your car will... but all in all, I'm happy with the purchase and feel a little bit safer should the block window or something..
Sorry no pics, as its really hard to see underneath the headers and oil lines.. but if its helpful, I think I paid like $300 for mine..
Re: Engine Diapers [Re: Triple Threat] #1255341
06/22/12 09:37 AM
06/22/12 09:37 AM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
Dustin, DRE made mine: 68 Dart SB w/motor plates & Milodon SS Oil Pan (the type with the centerlink going thru it).
It was the first fabication of that type for DRE so it cost a bit more plus they added lots of heat cloth due to very close header clearance. I had to fabricate my own solution for the centerlink cut-outs. It took alot of time but the results are very good and the diaper fits like a glove. Total Cost around $600.00
Small price to pay for the extra level of safety in my opinion.
Also, Dennis at DRE could not have been more helpful & accomodating.
Brett Miller 447 W9
Re: Engine Diapers [Re: mcduff] #1255342
06/22/12 11:27 AM
06/22/12 11:27 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I too will recommend DRE. Dennis is a racer and great guy. I see him at most of the DIV 3 points races and is always willing to take break from his own car to help others get blankets installed. Many times he has come to the aid of someone who did not pass tech due to missing diaper, and got them legal to race!
Re: Engine Diapers [Re: ProStDodge] #1255343
06/23/12 01:01 PM
06/23/12 01:01 PM
Ohio
3404 Offline
3404  Offline
Ohio
I have a DRE also and have no problem with it. I know a Chassis guy that made a pretty fancy belly pan for his car and had to remove it because around 145 MPH it wanted to lift the front end of the car.
Re: Engine Diapers [Re: Triple Threat] #1255344
06/23/12 07:08 PM
06/23/12 07:08 PM
Indiana
MFR426 Offline
MFR426  Offline
Indiana
We just got one from Russlerii.com that has been talked about here on Moparts. It fit great and is easy to put on. The best part is the cost at $ 158.00 compared to the $450-650 that DRE wanted. He makes them custom to your specs. He is hard to catch on the phone but you can get him. I am very pleased with it and feel a lot safer with it on!
Thanks!
Re: Engine Diapers [Re: MFR426] #1255345
06/24/12 12:16 AM
06/24/12 12:16 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I went with the DRE. More expensive, but we had a ton of mods; dragster pan, sight glass, drag link tube, external oil lines; kickout, etc. I had to send the pan to Dennis, but the fit is good. Had one burn-through from the headers and he fixed it for free and added more Kevlar patches. It was sagging a little more than I liked due to the length, so I added a layer of Masonite under the absorbent pad. The other thing I did was add a stud to the header flange between #6 & #8, and #5 & #7 so the strap pulls straight up and not over the rear spark plugs.
Re: Engine Diapers [Re: Triple Threat] #1255346
06/24/12 11:31 AM
06/24/12 11:31 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Here's my belly pan w/ my Bob's Pro Fab front end
Re: Engine Diapers [Re: DavidDean] #1255347
06/24/12 01:31 PM
06/24/12 01:31 PM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
Thats a nice drip pan...Would not stand a chance in containing either of my last 2 engine explosions. Both put rods out the side of the block just at and above the oil pan rail / block intersection resulting in oil & coolant blowing out all over the inner fender area and onto the tires, almost put me into the wall..... Diaper is the only containment device that stands a chance in a chassis car unless you find a way to get the pan sides up to cover the block.
Brett Miller 447 W9
Re: Engine Diapers [Re: mcduff] #1255348
06/24/12 03:19 PM
06/24/12 03:19 PM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
Dustin, are you installing one for your own piece of mind or has there been a rule change to require you to have one?
Re: Engine Diapers [Re: w2stroker] #1255349
07/03/12 03:18 PM
07/03/12 03:18 PM
Renton Washington
Renton Washington
Piece of mind, and its required to run Super Street.
Just talked to Dennis@DRE, said mine would need to be custom due the drag link and such of factory steering. $550 and I either have to send him the Pan, as he's never built one before, or a blue print for it with all the dimensions.
Will call around some more later.
-Dustin
Re: Engine Diapers [Re: Triple Threat] #1255350
07/03/12 03:37 PM
07/03/12 03:37 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I had a DRE. Fit like a glove, easy to take off. Money well spent.
2011 Drag Pak Challenger
