Uht - oh..... NOW what do I do??? (steel brake line) #1255312
06/21/12 10:49 PM
06/21/12 10:49 PM
Tennessee
WyleECoyote Offline OP
Tennessee
Although the fitting broke loose, as it backed down the steel line, it is starting to grab it and twist it.
NOW what do I do!!??
I can't replace the whole line, its a 72 Imperial so there's like 900-feet of it wrapped all around the whole front end!
Is there a way to replace like the last 6-inches that is curved and have a fitting along the frame?
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Uht - oh..... NOW what do I do??? (steel brake line) [Re: WyleECoyote] #1255313
06/21/12 10:58 PM
06/21/12 10:58 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
They always do that to me, even if they don't look rusty. You could cut the line further back, flare it and splice the line with a flare union, but I would just replace it.
It's long, but not that long of a run. The line runs under the radiator back to the prop valve on the driver's side frame rail.
Re: Uht - oh..... NOW what do I do??? (steel brake line) [Re: WyleECoyote] #1255314
06/21/12 11:02 PM
06/21/12 11:02 PM
grab the brass fitting lightly but securely with your vice grips & work it back & forth lightly & hope it will let loose from the line
Re: Uht - oh..... NOW what do I do??? (steel brake line) [Re: 440newport] #1255315
06/21/12 11:22 PM
06/21/12 11:22 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
This would be the easiest. Just make sure you make a proper double flare. They make tools designed to flare it right on the car.
It's Swifty! Swifty, you toad sucker!
Re: Uht - oh..... NOW what do I do??? (steel brake line) [Re: WyleECoyote] #1255316
06/21/12 11:52 PM
06/21/12 11:52 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
To late now but, pull the clip and spin the hose off the line(I'm guessing the hose is what you are replacing in the first place?). Then a little heat and the fitting would spin freely on the line. Now you have to fix (as stated) or replace the line.
Re: Uht - oh..... NOW what do I do??? (steel brake line) [Re: Dcuda69] #1255317
06/21/12 11:55 PM
06/21/12 11:55 PM
Tennessee
Tennessee
Hey! - Can I STILL do that?? The twist looks worse in the photo with the dirt, rust & Kroil. It barely started to twist and I stopped. Has the integrity of the line been compromised too far with a little twist?
Re: Uht - oh..... NOW what do I do??? (steel brake line) [Re: WyleECoyote] #1255318
06/22/12 02:40 AM
06/22/12 02:40 AM
When in doubt, throw it out Especially on brake lines and women
Re: Uht - oh..... NOW what do I do??? (steel brake line) [Re: Cab_Burge] #1255319
06/22/12 04:07 AM
06/22/12 04:07 AM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
You MIGHT be able to save it. Pull the clip holding the end of the rubber line to the bracket, push it out of the bracket and twist the rubber line off instead of turning the fitting on the steel line. Reverse to install. I presume you are replacing the rubber lines?
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: Uht - oh..... NOW what do I do??? (steel brake line) [Re: MoPar Jamie] #1255320
06/22/12 06:25 AM
06/22/12 06:25 AM
places
79powerwagon Offline
places
Just replace the line. Why do people try to save the old stuff like this? It makes no sense! Fix it right, fix it once, and be done with it.
Re: Uht - oh..... NOW what do I do??? (steel brake line) [Re: 79powerwagon] #1255321
06/22/12 08:00 AM
06/22/12 08:00 AM
Tennessee
Tennessee
I went to fine lines and didn't see a pre-bent selection for 72 Imperials. A quick Google search didn't turn much up either. Anyone know of other vendors they can recommend?
Thanks.
Wile E. Coyote
Re: Uht - oh..... NOW what do I do??? (steel brake line) [Re: WyleECoyote] #1255322
06/22/12 08:25 AM
06/22/12 08:25 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Yes you can!
You just don't want to.
Yep, cut back, install nut, flare, connect to short length of new tube.
It's a DOUBLE 45 degree flare. Not a single.
For what it's worth, the clueless morons at the parts store don't know their brake lines from their azz. They'll hand you everything but the right one.
Tell them it's 3/16ths line with 3/8-24 FLARE (not bubble) fittings in the length you need. They come in 10" multiples.
Good luck with those morons.
Re: Uht - oh..... NOW what do I do??? (steel brake line) [Re: WyleECoyote] #1255323
06/22/12 08:32 AM
06/22/12 08:32 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
As far as i know no one makes lines for them.They will custom bend lines if you send them spec from the old one.The line might last but then again it might not.Its really not that hard to bend new lines.NAPA used to make what they called easy bend tubing.It was a bit easier to bend than reg steel tubing.Ive replaced tons of lines including fuel lines at home and at work.You dont have to be perfect when doing them.But you can get a new line bent real close.Its cheap but does take some time to do.Just use a good flaring tool.I always put a dab of antisieze on new lines and fitting when I install them.Makes it a breeze to remove when you have to.Rocky
Chrysler Firepower
