Re: Uht - oh..... NOW what do I do??? (steel brake line)
[Re: WyleECoyote]
#1255314
06/21/12 11:02 PM
06/21/12 11:02 PM
RapidRobert
grab the brass fitting lightly but securely with your vice grips & work it back & forth lightly & hope it will let loose from the line
[Re: Dcuda69]
#1255317
06/21/12 11:55 PM
06/21/12 11:55 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
To late now but, pull the clip and spin the hose off the line(I'm guessing the hose is what you are replacing in the first place?). Then a little heat and the fitting would spin freely on the line. Now you have to fix (as stated) or replace the line.
Hey! - Can I STILL do that?? The twist looks worse in the photo with the dirt, rust & Kroil. It barely started to twist and I stopped. Has the integrity of the line been compromised too far with a little twist?
[Re: Cab_Burge]
#1255319
06/22/12 04:07 AM
06/22/12 04:07 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
You MIGHT be able to save it. Pull the clip holding the end of the rubber line to the bracket, push it out of the bracket and twist the rubber line off instead of turning the fitting on the steel line. Reverse to install. I presume you are replacing the rubber lines?
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: 79powerwagon]
#1255321
06/22/12 08:00 AM
06/22/12 08:00 AM
WyleECoyote
Tennessee
I went to fine lines and didn't see a pre-bent selection for 72 Imperials. A quick Google search didn't turn much up either. Anyone know of other vendors they can recommend? Thanks.
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
[Re: WyleECoyote]
#1255322
06/22/12 08:25 AM
06/22/12 08:25 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I can't replace the whole line, its a 72 Imperial so there's like 900-feet of it wrapped all around the whole front end!
Yes you can! You just don't want to.
Yep, cut back, install nut, flare, connect to short length of new tube.
It's a DOUBLE 45 degree flare. Not a single.
For what it's worth, the clueless morons at the parts store don't know their brake lines from their azz. They'll hand you everything but the right one.
Tell them it's 3/16ths line with 3/8-24 FLARE (not bubble) fittings in the length you need. They come in 10" multiples. Good luck with those morons.
[Re: WyleECoyote]
#1255323
06/22/12 08:32 AM
06/22/12 08:32 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
As far as i know no one makes lines for them.They will custom bend lines if you send them spec from the old one.The line might last but then again it might not.Its really not that hard to bend new lines.NAPA used to make what they called easy bend tubing.It was a bit easier to bend than reg steel tubing.Ive replaced tons of lines including fuel lines at home and at work.You dont have to be perfect when doing them.But you can get a new line bent real close.Its cheap but does take some time to do.Just use a good flaring tool.I always put a dab of antisieze on new lines and fitting when I install them.Makes it a breeze to remove when you have to.Rocky
Chrysler Firepower
