Lakewood bellhousings #1254672
06/20/12 10:33 PM
06/20/12 10:33 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
How has everyone found the fit and alignment of the lakewood bellhousings for big blocks to be? I want to get one for my hemi but have heard many stories of them being out of alignment.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Lakewood bellhousings [Re: 73cuda340] #1254673
06/20/12 10:45 PM
06/20/12 10:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats what the offset dowel pins are for... you should
check it anyways for run out
Re: Lakewood bellhousings [Re: MR_P_BODY] #1254674
06/20/12 10:51 PM
06/20/12 10:51 PM
long island NY
Ari440 Online content
Ari440  Online Content
long island NY
how do you do that ?
Im looking for a 4 speed setup on my ROAD RUNNER
1.39 9.85 - 137 mph
Re: Lakewood bellhousings [Re: Ari440] #1254675
06/20/12 10:57 PM
06/20/12 10:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mount a dial indicator on the back of the crank and
indicate the inside of the hole for the trans...
slowly turn the crank around and see if it has run
out... you want like .003 or less if I remember that
number right
Re: Lakewood bellhousings [Re: MR_P_BODY] #1254676
06/20/12 11:04 PM
06/20/12 11:04 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The bore needs to be .008 TIR and the face should be within .006. I got my stock bellhousing to .002 in the bore TIR and .004 on the face. Get Rob MC's alignment dowels, dont mess with stock ones. The stock ones are a real pain to get out. Tim
Re: Lakewood bellhousings [Re: 73cuda340] #1254677
06/20/12 11:23 PM
06/20/12 11:23 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
also, if you are going w/a new bell housing, it will be quicktime. Since lakewood bought quicktime I don't believe they sell the lakewood can anymore.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Lakewood bellhousings [Re: oldiron] #1254678
06/20/12 11:32 PM
06/20/12 11:32 PM
Des Moines, IA
CoreyWilson Offline
CoreyWilson  Offline
Des Moines, IA
Not sure on the Mopar Quicktime bell, but fwiw, my clutch guy recommended I get a Lakewood asap while there were still some left with the NP435 truck trans pattern so I wouldn't have to drill the pattern in a car bellhousing. He said on the Ford trucks he's worked with it takes some work to get a dual disk clutch to work properly and a triple disk is almost impossible as the Quicktime is smaller.
Re: Lakewood bellhousings [Re: CoreyWilson] #1254679
06/21/12 03:32 PM
06/21/12 03:32 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
The spec is to get it within .005 because that's how much 'wiggle room' comes stock between the bell and dowels. On a lakewood you can snug a couple bolts and tap it around until it's perfect then weld up two tight ID washers on two of the opposite holes to permanantly locate it to the block. At least thats how I did mine- cheaper than offset dowels.
I Might get flamed for that haha
Good luck
Radar
Re: Lakewood bellhousings [Re: radar] #1254680
06/21/12 03:36 PM
06/21/12 03:36 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I had to use the dowels with the most offset to get it within spec
Re: Lakewood bellhousings [Re: sshemi] #1254681
06/21/12 03:57 PM
06/21/12 03:57 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
If you have a 143-tooth flywheel then you'll need a Lakewood as Quicktime doesn't make one for that size.
Re: Lakewood bellhousings [Re: Stanton] #1254682
06/21/12 04:52 PM
06/21/12 04:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
143 tooth wheels create problems with stock Hemi manifolds due to the starter being further out .
That's if one is to believe what they read on the internet ...
Just an FYI
Re: Lakewood bellhousings [Re: JohnRR] #1254683
06/21/12 08:03 PM
06/21/12 08:03 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
383, Hemi 4-Speed, AlterKtion, D60
