Lakewood bellhousings
#1254672
06/20/12 10:33 PM
06/20/12 10:33 PM
Posts: 1,180 clarks summit pa
73cuda340
clarks summit pa
How has everyone found the fit and alignment of the lakewood bellhousings for big blocks to be? I want to get one for my hemi but have heard many stories of them being out of alignment.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Lakewood bellhousings
[Re: 73cuda340]
#1254673
06/20/12 10:45 PM
06/20/12 10:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats what the offset dowel pins are for... you should check it anyways for run out
[Re: Ari440]
#1254675
06/20/12 10:57 PM
06/20/12 10:57 PM
MR_P_BODY
how do you do that ?
Im looking for a 4 speed setup on my ROAD RUNNER
Mount a dial indicator on the back of the crank and indicate the inside of the hole for the trans... slowly turn the crank around and see if it has run out... you want like .003 or less if I remember that number right
[Re: 73cuda340]
#1254677
06/20/12 11:23 PM
06/20/12 11:23 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
also, if you are going w/a new bell housing, it will be quicktime. Since lakewood bought quicktime I don't believe they sell the lakewood can anymore.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: Stanton]
#1254682
06/21/12 04:52 PM
06/21/12 04:52 PM
Posts: 75,068 U.S.S.A.
JohnRR
U.S.S.A.
If you have a 143-tooth flywheel then you'll need a Lakewood as Quicktime doesn't make one for that size.
143 tooth wheels create problems with stock Hemi manifolds due to the starter being further out .
That's if one is to believe what they read on the internet ...
Just an FYI
