A hypothetical question for you all to chew on. #1251006
06/14/12 04:04 PM
06/14/12 04:04 PM
Missouri
StrokerPost Offline OP
Missouri
Suppose you were wanting to build a bracket car to run in the 9.50 range, all other things being the same, i.e. weight-say 3200 lbs, auto trans-you pick which one, stuff like that, and it HAD to be a hemi, which would be the better, easiest, most cost effective way to go, old style RB block style or new school Gen 3? Maybe this has come up before, but I didnt see it. I've been impressed by the performance of the Gen 3 motor, but dollar for dollar can it match the old hemi? I'm just gonna sit back and listen to you guys.
Thanks.
Ken.
Re: A hypothetical question for you all to chew on. [Re: StrokerPost] #1251007
06/14/12 04:10 PM
06/14/12 04:10 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Nope. Unless someone starts making gen 3 stuff that can match the gen 2’s displacements.
This post is available in double vision where drunk.
Re: A hypothetical question for you all to chew on. [Re: StrokerPost] #1251008
06/14/12 04:17 PM
06/14/12 04:17 PM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
I say Gen III. I obviously have a swayed opinion on the topic though.
Can you have power adders? Tell me more what your class restriction are. I'm running a 6.1 with forged drop in pistons(stock forged crank stock powdered rods), ported heads, custom cam, TTi headers, and a Kenne Bell supercharger 10 lbs of boost. Making approximately 640 to the wheels. I'm at 3200 lbs as well. that puts me in the ball park of where you want to be. If I had better rods I could turn the wick up to 18-22 lbs and make so monster power, but my build was a so called budget build. I have close to 18 in the motor and power adder.
I know tons of guys running new Chargers, challengers, and 300 that are in the 10.5 range and they are 4400lbs. One of the guys is running it N/A alumin block 46X CI motor. The other are NO2 cars, etc. If it's a budget build just get a short block like my 6.1 port the heads, change the cam, and put the bottle on it and you will make ur number.
I chose to go supercharger b/c of the wow factor.
Re: A hypothetical question for you all to chew on. [Re: StrokerPost] #1251009
06/14/12 05:03 PM
06/14/12 05:03 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
The Gen2 hemi will always win the wow factor hands down! But, I'm going to use the Gen3 for my new car. I want to use new technology (electronic injection, computer/distributorless ignition). Time to keep up with the times.
The dinosaurs didn't change with the times...and look what happened to them!
Re: A hypothetical question for you all to chew on. [Re: cagebob1] #1251010
06/14/12 05:06 PM
06/14/12 05:06 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Re: A hypothetical question for you all to chew on. [Re: cagebob1] #1251011
06/14/12 05:27 PM
06/14/12 05:27 PM
Backwater, PA
bwdst6 Offline
bwdst6  Offline
Backwater, PA
You know there are any number of aftermarket companies out there that you can buy parts from to put efi, crank triggers, etc on a gen2 hemi.
Re: A hypothetical question for you all to chew on. [Re: cagebob1] #1251012
06/14/12 05:41 PM
06/14/12 05:41 PM
New York
polyspheric Offline
polyspheric  Offline
New York
And a real Ardun trumps that.
Depends on whether you're trying to impress 15 year olds at the Dairy Queen, or build a fast car.
Boffin Emeritus
Re: A hypothetical question for you all to chew on. [Re: polyspheric] #1251013
06/14/12 06:02 PM
06/14/12 06:02 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Dollar for Dollar to run 9.50? I can't see how a Gen 2 hemi could compete with a Gen 3 hemi.
Even in the block price alone, you'd be WAY ahead with a Gen 3.
No way would it be as cool. No way could it compete in blown nitro form, but to run 9.50? Hard to pass up...
Same reason every chevy guy in the world runs a LSX now instead of the old 454.
Re: A hypothetical question for you all to chew on. [Re: W9 Dart] #1251014
06/14/12 06:28 PM
06/14/12 06:28 PM
Missouri
Missouri
Ok I will clarify this a bit more. First, this IS purely hypothetical, nothing I will be doing..........at least anytime soon. No power adders here, just heads up, pure motor, cubic inch to cubic inch. One thing that appeals to me about the Gen 3 is the weight as compared to a Gen 2, also the size makes it a winner, but I'm still interested in the best over all performer in this comparison. I'm in no rush to do either cuz I know that every month that goes by the Gen 3 will have more and more available, but the possibilities are already impressive.
BTW, what is currently the largest displacement you can achieve with the Gen 3?
Re: A hypothetical question for you all to chew on. [Re: StrokerPost] #1251015
06/14/12 06:50 PM
06/14/12 06:50 PM
Renton Washington
Triple Threat Offline
Renton Washington
Arrington www.shophemi.com offers a 440" 6.1 based hemi
"440 HEMI (7.2) - 6.1 to 440 short block. 4.060 Bore x 4.250 Stroke"
I think that a 426-440" Gen 3 with some compression a real camshaft and a set of Apache heads should get you there.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: A hypothetical question for you all to chew on. [Re: Triple Threat] #1251016
06/14/12 08:20 PM
06/14/12 08:20 PM
dogdays Offline
dogdays  Offline
The G3 weighs at least 200 lb less than the G2. You said cubic inch for cubic inch, which I take to mean no humongous elephant motor competing with a 430 inch G3.
30 years ago, a friend of mine ran a 433 bigblock chevy powered camaro into the 9s. I bet the latest Hemi heads flow better than the old rectangular ports, and the new "Hemi" chamber is much better than the bbchevy open chamber head which had to have a mountain range in the middle to get compression. That camaro weighed in at around 2950 lb. I don't think a 433 inch G3 Hemi would have any trouble laying waste to that car, meaning I can't see why you couldn't get into the 9s normally aspirated using a stock block.
Now you could also do it with an elephant motor but the $$$ would indeed be more and you'd have more problems with weight transfer, engine fitment, etc.
Just my
R.
Re: A hypothetical question for you all to chew on. [Re: dogdays] #1251017
06/14/12 08:30 PM
06/14/12 08:30 PM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
The gen 3 alumin block can get in the high 469 ci range. This with some nice ported heads (6.1, apache, or the new aftermarket heads) will net you in the very low 9s.
Re: A hypothetical question for you all to chew on. [Re: W9 Dart] #1251018
06/14/12 09:10 PM
06/14/12 09:10 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You should be able to build a Gen 3 for the price of a Gen 2 valvetrain.
Kevin
Re: A hypothetical question for you all to chew on. [Re: dogdays] #1251019
06/14/12 09:33 PM
06/14/12 09:33 PM
MN
hemidup Offline
hemidup  Offline
MN
Just my
R.
Just for s n grins we weighed our Gen 3 Drag Pak motor and it came in at 460 lbs. Our Gen 2 426/484 stoker with K heads came in at 720 lbs. With the new Gen 3 aluminum block could put 468 cubes down to 370 lbs.
Jerry Williams.
Re: A hypothetical question for you all to chew on. [Re: hemidup] #1251020
06/14/12 09:36 PM
06/14/12 09:36 PM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
Bingo ^^^^
Re: A hypothetical question for you all to chew on. [Re: StrokerPost] #1251021
06/14/12 10:20 PM
06/14/12 10:20 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Ken, how have you been?
If I didn't already have the small block stuff I'd do a gen III without any second thoughts. The gen IIs are cool but the thought of making 700 hp on pump gas and only weighing 450 lbs appeals to me. Anything I would build would be a street/strip deal. My wife and I drive the Dart all over the place, it never runs hot, starts easy too. The best thing is I can drop the exhaust off and run low 6.70s in the heat.
Speaking of the Dart, when do you want to come to I-57 and drive it?
Justin
Re: A hypothetical question for you all to chew on. [Re: StrokerPost] #1251022
06/14/12 10:27 PM
06/14/12 10:27 PM
Texas
racer_amx Offline
racer_amx  Offline
Texas
Im voting for the gen3 as well
Re: A hypothetical question for you all to chew on. [Re: racer_amx] #1251023
06/14/12 10:40 PM
06/14/12 10:40 PM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
You gotta love gen 3 power, reliability, and advanced tech. Last week end I drove the car on a 300 mile road trip. At 70 mph it averaged 16 mpg. This video was started in 2nd gear.
[IMG]http://i157.photobucket.com/albums/t73/jbellyus/88a95a76.mp4[/IMG]
Re: A hypothetical question for you all to chew on. [Re: W9 Dart] #1251024
06/15/12 10:32 AM
06/15/12 10:32 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
If its going in that dart only a gen 2 would look right.
2011 Drag Pak Challenger
Re: A hypothetical question for you all to chew on. [Re: rickseeman] #1251025
06/15/12 11:35 AM
06/15/12 11:35 AM
Backwater, PA
bwdst6 Offline
bwdst6  Offline
Backwater, PA
Last weekend for the Mopar Action event at Maple Grove someone had a gen3 hemi in a white 70 something Duster. Ran high 12’s… BFD! Of course everyone was interested in how he got it in there, what tranny he bolted it to, etc, etc. It was quite popular, just not that fast. In fact the only gen3 I saw there that was running mid 9’s was Barton’s drag pack. And I don’t see too many people being able to build something of that caliber.
