Cable vs. Mechanical Linkage? #1245875
06/05/12 07:19 PM
06/05/12 07:19 PM
oregon
ramcharger1964 Offline OP
oregon
Had it recommended by more than 1 person that I should ditch the cable throttle system on my max wedge crossrammed 64. They said for safety reasons - If somtheing happens and the throttle sticks, springs break, cable, snaps, etc. - then you can use your toe to manually pull the throttle back up.
Anyone use these or have pic's. Any manufacturers??
Hell B!tch Racing Co.
Re: Cable vs. Mechanical Linkage? [Re: ramcharger1964] #1245876
06/05/12 07:42 PM
06/05/12 07:42 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
There were many issues with stuck throttles on linkages. The engine mount would break and the engine would torque over, pulling the throttle open more.
Race cars are required to have redundant (2) throttle springs. You could even connect one to each carb and a third to the linkage, if you really want backup.
I would worry about the guys suggesting this, not changing your setup...
Re: Cable vs. Mechanical Linkage? [Re: ramcharger1964] #1245877
06/05/12 09:59 PM
06/05/12 09:59 PM
I wouldn't switch to mechanical linkage with a crossram, NO STINKING WAY Make sure your cable is in good shape, take it off the car and feel the restitance when sliding it in and out, if it doesn't have any tight spots put it back on and run it If it has tight spots replace it with a good one that doesn't have sticky or tight spots
Re: Cable vs. Mechanical Linkage? [Re: ramcharger1964] #1245878
06/05/12 10:25 PM
06/05/12 10:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In real quick cars(dont know the ET) its a must to
have a mech linkage with a toe loop
Re: Cable vs. Mechanical Linkage? [Re: ramcharger1964] #1245879
06/06/12 06:33 AM
06/06/12 06:33 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I did it on my 63 Dodge crossram. Pain in the but. Bigger hole in the firewall to make it have the correct geometry with the stock pedal. I went back to the cable.
Doug
Re: Cable vs. Mechanical Linkage? [Re: MR_P_BODY] #1245880
06/06/12 04:23 PM
06/06/12 04:23 PM
I'm under the impression it is required to have a toe strap (loop) on any mechanical throotle linkage, not required on cable linkage. I don't remember any requiements based on how fast the cars are to have mechanical throttle linkage
Re: Cable vs. Mechanical Linkage? [Re: Cab_Burge] #1245881
06/06/12 04:38 PM
06/06/12 04:38 PM
oregon
oregon
I think I am going to try putting in a fairly heavy spring on the pivot of the crossram linkage (nothing real heavey but just a good backup spring)
I don't want to add any springs or even heavier springs directly to the carb linkage itself - I was told it will prematurely wear the rods of the assembly - This came from Damon Kuhn so I believe it!
Re: Cable vs. Mechanical Linkage? [Re: ramcharger1964] #1245882
06/06/12 04:50 PM
06/06/12 04:50 PM
I used the stock return springs (one on each carb)and bracket on my M.W NHRA stocker for many years, no problems with use or tech
Re: Cable vs. Mechanical Linkage? [Re: Cab_Burge] #1245883
06/06/12 05:39 PM
06/06/12 05:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe any car faster than 6.50(1/4 mile) must
have a mech linkage... but it might be any pro mod
funny car or top fueler.... cable... you cant lift
it with a toe loop
Re: Cable vs. Mechanical Linkage? [Re: MR_P_BODY] #1245884
06/06/12 05:49 PM
06/06/12 05:49 PM
oregon
oregon
I actually had a jerk inspector at PIR make me install 2 additional springs - one on each of my carbs.......
