New K-frame bolts? #1245734
06/05/12 10:09 AM
06/05/12 10:09 AM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Where can I buy new k-frame bolts? E-Body.
Re: New K-frame bolts? [Re: cudabitten] #1245735
06/05/12 10:10 AM
06/05/12 10:10 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Are your old ones lost or stripped?
Re: New K-frame bolts? [Re: cudabitten] #1245736
06/05/12 11:12 AM
06/05/12 11:12 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Tom Race Specialities
MLR426
Re: New K-frame bolts? [Re: MLR426] #1245737
06/05/12 12:53 PM
06/05/12 12:53 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Who dat?
I figured it out... not the top hit on Google but it does show up.
R/T Specialties
Re: New K-frame bolts? [Re: cudabitten] #1245738
06/05/12 01:10 PM
06/05/12 01:10 PM
NY usa
540challenger Offline
NY usa
I got mine off of e-bay
Re: New K-frame bolts? [Re: 540challenger] #1245739
06/05/12 08:20 PM
06/05/12 08:20 PM
tx
N
nobrakesneeded Offline
N
tx
Is there anything special about the k member bolts? Couldn't a grade 8 of the appropriate size be used just as well?
Re: New K-frame bolts? [Re: nobrakesneeded] #1245740
06/05/12 08:30 PM
06/05/12 08:30 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
There's a shoulder on the bolt that's sized to the hole in the K-frame...
When I dropped my K-frame the other day, I found that one of the bolts had been replaced with a bumper bolt or similar large thread bolt, but it didn't have the shoulder. If three aren't good enough to locate the K, I guess I should buy one.
Re: New K-frame bolts? [Re: nobrakesneeded] #1245741
06/05/12 09:25 PM
06/05/12 09:25 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
The shoulder on the bolts are important to locate the K-frame and prevent movement. Remember that the K-frame locates the lower control arm and, hence, is important in maintaining alignment and steering geometry.
Re: New K-frame bolts? [Re: cudabitten] #1245742
03/24/13 12:05 AM
03/24/13 12:05 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Anybody know the size/threads of these k bolts?
Re: New K-frame bolts? [Re: jcc] #1245743
03/26/13 02:46 AM
03/26/13 02:46 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
5/8-11 x 2" with special shoulder as mentioned above. See description including photo here:
www.amkproducts.com > pdf catalog > page 109-127 > scroll to bottom of page 114.
Probably any vendor of this item has bought it from AMK and is re-selling.
Re: New K-frame bolts? [Re: kentj340] #1245744
03/26/13 01:52 PM
03/26/13 01:52 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Thank you.
I am puzzled by the original need for a shoulder bolt, it doesn't seem to me that a shoulder bolt allows for any extra manufacturing tolerances, and regarding shear strength in a massive wreck because a grade 8 5/8" threaded bolt versus a 3/4" shoulder, not sure its enough to matter unless hitting the wall at daytona is a concern. Looked at my RMS Alter K and I believe it has 3 large holes and one smaller hole FWIW in the K. The bolts are only attached to 14g? Sheet metal anyway. The only case i can visualize if the factory suspected k frame to chassis movement over the course of say 100K miles, and felt the shoulder style would survive longer.
Re: New K-frame bolts? [Re: jcc] #1245745
03/26/13 02:23 PM
03/26/13 02:23 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: New K-frame bolts? [Re: jcc] #1245746
03/26/13 08:09 PM
03/26/13 08:09 PM
dogdays Offline
dogdays  Offline
It's not shear strength.
It's location as the bolt is tightened up. My Taurus subframe has two pilot holes into which one sticks a particular diameter rod before the subframe bolts are tightened. Then they are removed after the bolts are torqued to spec. These shoulder bolts do the same thing except without the hassle of inserting the rods. After they are torqued down, friction keeps the subframe in the right place.
R.
Re: New K-frame bolts? [Re: dogdays] #1245747
03/26/13 11:09 PM
03/26/13 11:09 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
It's not shear strength...After they are torqued down, friction keeps the subframe in the right place.
Yes, friction is how bolted connections do their job. My car was driven almost 160,000 miles before starting restoration, and from the looks of the still-fresh gloss black paint under the K-frame bolt washers, there was no movement of the K-frame, at least relative to the bolts.
FWIW, engineering specs for bolted connections (American Institute of Steel Construction/American Society for Testing of Materials) prohibit paint within the connection parts, though, since paint could decrease the friction.
