Re: New K-frame bolts?
[Re: cudabitten]
#1245735
06/05/12 10:10 AM
06/05/12 10:10 AM
moparpollack
Lil Herman
Lil Herman
85086
Are your old ones lost or stripped?
[Re: cudabitten]
#1245736
06/05/12 11:12 AM
06/05/12 11:12 AM
Posts: 4,799 ILL
MLR426
ILL
Where can I buy new k-frame bolts? E-Body.
Tom Race Specialities
MLR426
[Re: nobrakesneeded]
#1245741
06/05/12 09:25 PM
06/05/12 09:25 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Is there anything special about the k member bolts? Couldn't a grade 8 of the appropriate size be used just as well?
The shoulder on the bolts are important to locate the K-frame and prevent movement. Remember that the K-frame locates the lower control arm and, hence, is important in maintaining alignment and steering geometry.
[Re: cudabitten]
#1245742
03/24/13 12:05 AM
03/24/13 12:05 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Anybody know the size/threads of these k bolts?
[Re: jcc]
#1245743
03/26/13 02:46 AM
03/26/13 02:46 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
5/8-11 x 2" with special shoulder as mentioned above. See description including photo here: www.amkproducts.com > pdf catalog > page 109-127 > scroll to bottom of page 114. Probably any vendor of this item has bought it from AMK and is re-selling.
[Re: kentj340]
#1245744
03/26/13 01:52 PM
03/26/13 01:52 PM
jcc
Bitopia
Thank you.
I am puzzled by the original need for a shoulder bolt, it doesn't seem to me that a shoulder bolt allows for any extra manufacturing tolerances, and regarding shear strength in a massive wreck because a grade 8 5/8" threaded bolt versus a 3/4" shoulder, not sure its enough to matter unless hitting the wall at daytona is a concern. Looked at my RMS Alter K and I believe it has 3 large holes and one smaller hole FWIW in the K. The bolts are only attached to 14g? Sheet metal anyway. The only case i can visualize if the factory suspected k frame to chassis movement over the course of say 100K miles, and felt the shoulder style would survive longer.
[Re: jcc]
#1245746
03/26/13 08:09 PM
03/26/13 08:09 PM
dogdays
It's not shear strength. It's location as the bolt is tightened up. My Taurus subframe has two pilot holes into which one sticks a particular diameter rod before the subframe bolts are tightened. Then they are removed after the bolts are torqued to spec. These shoulder bolts do the same thing except without the hassle of inserting the rods. After they are torqued down, friction keeps the subframe in the right place. R.
[Re: dogdays]
#1245747
03/26/13 11:09 PM
03/26/13 11:09 PM
kentj340
Cut and Shoot, TX
It's not shear strength...After they are torqued down, friction keeps the subframe in the right place.
Yes, friction is how bolted connections do their job. My car was driven almost 160,000 miles before starting restoration, and from the looks of the still-fresh gloss black paint under the K-frame bolt washers, there was no movement of the K-frame, at least relative to the bolts.
FWIW, engineering specs for bolted connections (American Institute of Steel Construction/American Society for Testing of Materials) prohibit paint within the connection parts, though, since paint could decrease the friction.
