BOG OFF THE LINE #1245693
06/05/12 01:46 AM
06/05/12 01:46 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
I HAVE A 67 CUDA 440 APPROX 500 HP. AUTOMATIC WITH 8 INCH CONVERTOR AND TRANS BRAKE. 2 STEP IS AT 2300 ON THE BUTTON. I CHANGED TO E85 WITH A CARB I HAD RUN FOR YEARS. I RELEASE THE BRAKE AT THE LINE AND THE FRONTEND COMES UP AND FOR SPLIT SECOND IT BOGS AND THEN IT HAULS THE MAIL.1.63 60 FOOT AND RUNS 11.16 AT 120.46. JUST WONDERING WHERE TO START.
Re: BOG OFF THE LINE [Re: rickb67] #1245694
06/05/12 01:50 AM
06/05/12 01:50 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
try bigger squirters..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: BOG OFF THE LINE [Re: HOTMOPR] #1245695
06/05/12 02:01 AM
06/05/12 02:01 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Also jet extentions in the secondarys.
Re: BOG OFF THE LINE [Re: dartman366] #1245696
06/05/12 03:45 AM
06/05/12 03:45 AM
Re: BOG OFF THE LINE [Re: Cab_Burge] #1245697
06/05/12 11:44 AM
06/05/12 11:44 AM
USA
BB Dart 69 Offline
BB Dart 69  Offline
USA
WHAT size needle & seat? Is this a e-85 carb.
Re: BOG OFF THE LINE [Re: BB Dart 69] #1245698
06/05/12 02:52 PM
06/05/12 02:52 PM
The needles and seast shouldn't affect the intitial hit, but they could
Re: BOG OFF THE LINE [Re: Cab_Burge] #1245699
06/05/12 03:57 PM
06/05/12 03:57 PM
USA
BB Dart 69 Offline
BB Dart 69  Offline
USA
I was thinking not enough volume. Main well feed not big enough or wrong boosters.
Re: BOG OFF THE LINE [Re: BB Dart 69] #1245700
06/05/12 04:25 PM
06/05/12 04:25 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
It either needs one of two things, both meaning more fuel. Jet extensions or increase the fuel pressure from the pump to the regulator and from run as much fuel pressure from the regulator to the carb as you can without pushing past the floats. Somewhere near nine pounds is usually where the floats give up. Had this exact issue on alchol and it was the fuel pressure from the pump to the regulator. Minimum 23 lbs. Give it a shot and let us know.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: BOG OFF THE LINE [Re: Cab_Burge] #1245701
06/05/12 05:27 PM
06/05/12 05:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
HIGHLY unlikely... there should be plenty of volume
in the bowls even with the stock .110 N/S for coming
off the line... cheapest thing to try is the jet
extensions (race car should have them anyways)...
then squirters
Re: BOG OFF THE LINE [Re: Irun5snd8th] #1245702
06/05/12 05:34 PM
06/05/12 05:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Better recalibrate your gauge... even Holley will
tell you 7.5 is on the edge... when I use to flow
fuel pumps at work 7.5 was the max allowed pressure
Re: BOG OFF THE LINE [Re: MR_P_BODY] #1245703
06/05/12 09:35 PM
06/05/12 09:35 PM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
IT IS A E85 CARB I HAD A GUY CONVERT IT IN DENVER. I SHOULD HAVE ALREADY HAD EXTENSIONS IN THE CARB. THAT WILL BE FIRST THING I DO THAT AND INCREASE FUEL PRESSURE TO 7 FROM 6 LBS. IN TWO WEEKS A BUDDY IS DRIVING THE CAR AND I WILL BE WRENCHING. SO WILL SEE. THANKS GUYS
Re: BOG OFF THE LINE [Re: rickb67] #1245704
06/05/12 10:09 PM
06/05/12 10:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What kind of altitude did you run before and now...
it can be dog lean
Re: BOG OFF THE LINE [Re: MR_P_BODY] #1245705
06/05/12 11:42 PM
06/05/12 11:42 PM
PA
ajcasini Offline
ajcasini  Offline
PA
What type of carb is this your are running? What IAB and IFR are in the carburator? Also check Float level, if its too high it can spill over into the carb if too low you can starve it for fuel.
Any other specs you can provide would help find a solution.
Re: BOG OFF THE LINE [Re: ajcasini] #1245706
09/17/12 09:49 PM
09/17/12 09:49 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
I'm having a similar problem this past weekend so i'll give it a
Re: BOG OFF THE LINE [Re: racerx] #1245707
09/18/12 03:03 AM
09/18/12 03:03 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Spent labor day weekend at TVD racing. Fuel presure at 7 and jet extensions installed.Went from 1.58 to 1.60 60ft times to 1.52 1.53. Car ran best of 10.89 at 123 mph prior was 11.11 at 120. Son kept car and trailer in Sioux Falls cause i was going back this weekend to do some more tweaking but had a front runner seperate so had to load up for the weekwnd :rant.New tire ordered so am going to Oahe speedway this next weekend.
Re: BOG OFF THE LINE [Re: rickb67] #1245708
09/18/12 08:43 AM
09/18/12 08:43 AM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
My first pass Friday, Bog off the line, wth? Larry came over and sprayed the squirter out with brake parts cleaner and bog gone...
